[Geoserver-users] getfeatureinfo from other database table
Hello everyone,
I would like to know if I can make a getfeatureinfo, from wms layer, taking
also data from other database tables (tables with relations).
Thanks a lot
View this message in context: http://old.nabble.com/getfeatureinfo-from-other-database-table-tp30473679p30473679.html
On Thu, Dec 16, 2010 at 4:35 PM, paolotome <paolo_tome@anonymised.com> wrote:
Hello everyone,
There is no explicit support for this, but maybe you can get away
using sql views?
http://gridlock.openplans.org/geoserver/trunk/doc/en/user/data/sqlview.html
Mind, this is new functionality in the 2.1 series
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Thanks for your interest. the link you suggested is very interesting. That's
the solution I was looking for and I could not find. I hope to be able to
use this method!
thanks again, your help is always very important
Paolo
Hello everyone,
taking
using sql views?
Ing. Andrea Aime
fax: +39 0584962313
Lotusphere 2011
Register now for Lotusphere 2011 and learn how
to connect the dots, take your collaborative environment
to the next level, and enter the era of Social Business.
http://p.sf.net/sfu/lotusphere-d2d
Geoserver-users mailing list
View this message in context: http://old.nabble.com/getfeatureinfo-from-other-database-table-tp30473679p30479764.html
hello,
I created a test query from a MySQL database. The connection to the database
seems to occur correctly. But there is a problem: as you can see from the
photo, the_geom field is treated as a "bit " field.
Is there a way to change the formatting of the_geom field? (double checked
and corrected, as suggested by the guide, it does not work).
thanks again
http://old.nabble.com/file/p30487170/sql.jpg
That's the solution I was looking for and I could not find. I hope to be
able to use this method!
Paolo
wrote:
Hello everyone,
taking
using sql views?
Ing. Andrea Aime
fax: +39 0584962313
Lotusphere 2011
View this message in context: http://old.nabble.com/getfeatureinfo-from-other-database-table-tp30473679p30487170.html
