[Geoserver-users] GetFeatureInfo POST request with JSON data
Hello, I’m trying to implement a GetFeatureInfo request using HTTP POST with the data in JSON format.
Instead of doing something like:
$http.get(‘http://geoserver/GetFeatureInfo&service=WMS&version=1.1.1&BBOX=-9.268684387207031%2C38.697769425719144%2C-9.048957824707031%2C38.78580303175891&width=2560&height=1315&query_layers=Pingo+Doce%2CTarget+ACP&layers=Pingo+Doce%2CTarget+ACP&info_format=application%2Fjson&feature_count=50&x=1476&y=579&cql_filter=(1%3D1)%3B(whatever+%3E+100)’);
I want to be doing a POST request as such:
$http.post(url,
request: ‘GetFeatureInfo’,
service: ‘WMS’,
version: ‘1.1.1’,
BBOX: bbox,
width: width,
height: height,
query_layers: layersString,
info_format: ‘application/json’,
feature_count: ‘50’,
x: x,
y: y,
cql_filter: filtersString
{“headers” : { “Content-Type” : “application/json; charset=UTF-8” }
However, it appears that GeoServer is expecting a XML input or something, the response I get is:
ows:ExceptionTextorg.xmlpull.v1.XmlPullParserException: only whitespace content allowed before start tag and not - (position: START_DOCUMENT seen -… @1:1)
only whitespace content allowed before start tag and not - (position: START_DOCUMENT seen -… @1:1) </ows:ExceptionText>
</ows:Exception>
Is it not possible to make a POST request with JSON data? L
Thanks in advance and sorry if I wasn’t very clear.
Cosme Benito
On Fri, Dec 19, 2014 at 1:53 PM, Cosme Benito <cosme.benito@anonymised.com>
$http.post(url,
request: 'GetFeatureInfo',
            service: 'WMS',
            version: '1.1.1',
            BBOX: bbox,
            width: width,
            height: height,
            info_format: 'application/json',
            feature_count: '50',
            x: x,
            y: y,
{"headers" : { "Content-Type" : "application/json; charset=UTF-8" }
<ows:ExceptionText>org.xmlpull.v1.XmlPullParserException: only whitespace
-... @1:1)
START_DOCUMENT seen -... @1:1) </ows:ExceptionText>
</ows:Exception>
No, it's not possible, GetFeatureInfo is only defined as a GET request.
As an out of WMS standard addition, you can do a form POST with the same
parameters as the GET request.
There is no support for either XML or JSON (well, posting JSON is not
supported by any OGC protocol at all).
Please, notice that GeoSolutions will be closed for seasonal holidays
from December the 24th to January the 6th
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I didn’t realize about the WMS POST capability. Is that in the docs? I guess this would be useful for including very long requests (e.g. long filter expressions) ?
On Fri, Dec 19, 2014 at 5:49 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=164703151&iu=/4140/ostg.clktrk
Geoserver-users mailing list
On Fri, Dec 19, 2014 at 1:53 PM, Cosme Benito <cosme.benito@anonymised.com> wrote:
$http.post(url,
service: ‘WMS’,
version: ‘1.1.1’,
BBOX: bbox,
width: width,
height: height,
x: x,
y: y,
</ows:Exception>
No, it’s not possible, GetFeatureInfo is only defined as a GET request.
As an out of WMS standard addition, you can do a form POST with the same parameters as the GET request.
There is no support for either XML or JSON (well, posting JSON is not supported by any OGC protocol at all).
Ing. Andrea Aime
@geowolf
Technical Lead
