I’ve just made a fresh install of 2.7.1 and I get a render error when using GetFeatureInfo.
I get the same error with the example data tiger:poly_landmarks with both WMS 1.1.1 and 1.3.0.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
Rendering process failed
36
The logs says this:
java.lang.ArrayIndexOutOfBoundsException: 36
at org.geoserver.wms.featureinfo.VectorRenderingLayerIdentifier$FeatureInfoRenderListener.featureRenderer(VectorRenderingLayerIdentifier.java:578)
Is it just me or does someone else also experience this?
Any ideas?
Using Tomcat 7 on Windows.
/Olle
Hi Olle,
I tried to reproduce your issue: do you one GetFeatureInfo request that is failing?
Thanks
Mauro
2015-05-22 12:09 GMT+02:00 Olle Markljung <markljung@anonymised.com>:
36
The logs says this:
Any ideas?
/Olle
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
Geoserver-users mailing list
Yes,
I test through the Layer Preview page.
The error is not consistent. Sometimes it works.
Here is a request that failed:
http://localhost:8080/geoserver/tiger/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&FORMAT=image%2Fpng&TRANSPARENT=true&QUERY_LAYERS=tiger%3Apoly_landmarks&LAYERS=tiger%3Apoly_landmarks&STYLES&INFO_FORMAT=text%2Fhtml&FEATURE_COUNT=50&X=50&Y=50&SRS=EPSG%3A4326&WIDTH=101&HEIGHT=101&BBOX=-74.00033346313478%2C40.694517327392575%2C-73.96565786499025%2C40.729192925537106
Thanks for helping out!
On Fri, May 22, 2015 at 12:27 PM, Mauro Bartolomeoli <maurobartolomeoli@anonymised.com4…> wrote:
Hi Olle,
Thanks
Mauro
36
The logs says this:
Any ideas?
/Olle
I thought I verify with the windows installer version but didn’t find it.It is not in SourceForge (http://sourceforge.net/projects/geoserver/files/GeoServer/2.7.1/geoserver-2.7.1.exe)
I downloaded the 2.7.0 windows installer and there it works as expected.
I’ll check with the 2.7.0 war too.
/Olle
On Fri, May 22, 2015 at 12:36 PM, Olle Markljung <markljung@anonymised.com> wrote:
Yes,
On Fri, May 22, 2015 at 12:27 PM, Mauro Bartolomeoli <maurobartolomeoli@anonymised.com> wrote:
Hi Olle,
Thanks
Mauro
36
The logs says this:
Any ideas?
/Olle
Uhm… weird, that url works for me on 2.7.1 (Windows - standalone zip). One question: there was a failing attempt to produce the 2.7.1 with this bug.
I thought it was not published at all.
I will check the war distribution. Can you try to retest with the standalone zip: http://sourceforge.net/projects/geoserver/files/GeoServer/2.7.1/geoserver-2.7.1-bin.zip ?
Mauro
2015-05-22 12:36 GMT+02:00 Olle Markljung <markljung@anonymised.com>:
Yes,
Hi Olle,
Thanks
Mauro
36
The logs says this:
Any ideas?
/Olle
