[Geoserver-users] getting a problem
Welcome to GeoServer!
JAVA_HOME: C:\Program Files\Java\jre1.8.0_151
Please wait while loading GeoServer…
2020-12-03 18:44:30.689:INFO::main: Logging initialized @225ms to org.eclipse.jetty.util.log.StdErrLog
2020-12-03 18:44:30.798:WARN:oejx.XmlConfiguration:main: Property ‘jetty.port’ is deprecated, use ‘jetty.http.port’ instead
2020-12-03 18:44:30.798:WARN:oejx.XmlConfiguration:main: Property ‘http.timeout’ is deprecated, use ‘jetty.http.idleTimeout’ instead
2020-12-03 18:44:30.798:INFO:oejs.Server:main: jetty-9.4.18.v20190429; built: 2019-04-29T20:42:08.989Z; git: e1bc35120a6617ee3df052294e433f3a25ce7097; jvm 1.8.0_151-b12
2020-12-03 18:44:30.814:INFO:oejdp.ScanningAppProvider:main: Deployment monitor [file:///C:/Program%20Files/geoserver/webapps/] at interval 1
2020-12-03 18:44:31.423:INFO:oejw.StandardDescriptorProcessor:main: NO JSP Support for /geoserver, did not find org.eclipse.jetty.jsp.JettyJspServlet
2020-12-03 18:44:31.688:INFO:oejs.session:main: DefaultSessionIdManager workerName=node0
2020-12-03 18:44:31.688:INFO:oejs.session:main: No SessionScavenger set, using defaults
2020-12-03 18:44:31.688:INFO:oejs.session:main: node0 Scavenging every 660000ms
Dec 03, 2020 6:44:32 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup ‘XStreamPersisterInitializer’, but ApplicationContext is unset.
WARNING: Extension lookup ‘ExtensionFilter’, but ApplicationContext is unset.
WARNING: Extension lookup ‘ExtensionProvider’, but ApplicationContext is unset.
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
log4j:ERROR setFile(null,true) call failed.
java.io.FileNotFoundException: C:\Program Files\geoserver\data_dir\logs\geoserver.log (Access is denied)
at java.io.FileOutputStream.open0(Native Method)
at java.io.FileOutputStream.open(Unknown Source)
at java.io.FileOutputStream.(Unknown Source)
at org.apache.log4j.FileAppender.setFile(FileAppender.java:294)
at org.apache.log4j.RollingFileAppender.setFile(RollingFileAppender.java:207)
at org.apache.log4j.FileAppender.activateOptions(FileAppender.java:165)
at org.apache.log4j.config.PropertySetter.activate(PropertySetter.java:307)
at org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:172)
at org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:104)
at org.apache.log4j.PropertyConfigurator.parseAppender(PropertyConfigurator.java:842)
at org.apache.log4j.PropertyConfigurator.parseCategory(PropertyConfigurator.java:768)
at org.apache.log4j.PropertyConfigurator.configureRootCategory(PropertyConfigurator.java:648)
at org.apache.log4j.PropertyConfigurator.doConfigure(PropertyConfigurator.java:514)
at org.apache.log4j.PropertyConfigurator.configure(PropertyConfigurator.java:440)
at org.geoserver.logging.LoggingUtils.configureGeoServerLogging(LoggingUtils.java:94)
at org.geoserver.logging.LoggingUtils.initLogging(LoggingUtils.java:218)
at org.geoserver.logging.LoggingStartupContextListener.contextInitialized(LoggingStartupContextListener.java:74)
at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:957)
at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:553)
at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:922)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:365)
at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1497)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1459)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:852)
at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:278)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:545)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:46)
at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:192)
at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:502)
at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:151)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:172)
at org.eclipse.jetty.deploy.providers.WebAppProvider.fileAdded(WebAppProvider.java:416)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:65)
at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:610)
at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:529)
at org.eclipse.jetty.util.Scanner.scan(Scanner.java:392)
at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:313)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:145)
at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:576)
at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:238)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:167)
at org.eclipse.jetty.server.Server.start(Server.java:418)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:119)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:113)
at org.eclipse.jetty.server.Server.doStart(Server.java:382)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1572)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1512)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1511)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:220)
at org.eclipse.jetty.start.Main.start(Main.java:490)
at org.eclipse.jetty.start.Main.main(Main.java:77)
2020-12-03 18:44:32.195:INFO:oejshC.geoserver:main: Initializing Spring root WebApplicationContext
Dec 03, 2020 6:44:33 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup ‘GeoServerSecurityProvider’, but ApplicationContext is unset.
03 Dec 18:44:33 INFO [org.geoserver] - GeoServer configuration lock is enabled
03 Dec 18:44:33 INFO [org.geoserver] - Loading catalog…
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘burg’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘capitals’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘dem’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘cite_lakes’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘grass’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘green’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘generic’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘giant_polygon’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘line’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘poi’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘polygon’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘point’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘poly_landmarks’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘pophatch’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘rain’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘raster’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘restricted’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘simple_roads’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘simple_streams’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘tiger_roads’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘population’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded default workspace cite
03 Dec 18:44:33 INFO [org.geoserver] - Loaded workspace ‘nurc’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded workspace ‘sde’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded workspace ‘it.geosolutions’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded workspace ‘cite’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded workspace ‘sf’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded workspace ‘tiger’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded workspace ‘topp’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded coverage store ‘arcGridSample’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded coverage ‘Arc_Sample’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘Arc_Sample’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded coverage store ‘img_sample2’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded coverage ‘Pk50095’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘Pk50095’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded coverage store ‘mosaic’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded coverage ‘mosaic’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘mosaic’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded coverage store ‘worldImageSample’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded coverage ‘Img_Sample’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘Img_Sample’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded data store ‘sf’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘archsites’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘archsites’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘bugsites’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘bugsites’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘roads’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘roads’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘restricted’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘restricted’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘streams’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘streams’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded coverage store ‘sfdem’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded coverage ‘sfdem’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘sfdem’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded data store ‘nyc’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘giant_polygon’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘giant_polygon’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘poi’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘poi’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘tiger_roads’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘tiger_roads’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘poly_landmarks’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘poly_landmarks’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded data store ‘states_shapefile’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘states’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘states’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded data store ‘taz_shapes’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘tasmania_cities’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘tasmania_cities’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘tasmania_roads’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘tasmania_roads’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘tasmania_water_bodies’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘tasmania_water_bodies’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘tasmania_state_boundaries’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘tasmania_state_boundaries’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer group ‘spearfish’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer group ‘tasmania’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer group ‘tiger-ny’
03 Dec 18:44:34 INFO [org.geoserver] - Read catalog in 1.131 s
03 Dec 18:44:34 INFO [org.geoserver] - Loaded service ‘WMTSInfoImpl-6bf8d24b:17628bd79da:-8000’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded service ‘wcs’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded service ‘wfs’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded service ‘wms’, enabled
03 Dec 18:44:34 INFO [config.GeoserverXMLResourceProvider] - Will look for ‘geowebcache.xml’ in directory ‘C:\Program Files\geoserver\data_dir\gwc’.
03 Dec 18:44:34 INFO [config.GeoserverXMLResourceProvider] - Found configuration file in gwc
03 Dec 18:44:34 WARN [config.XMLConfiguration] - ********************************************************************************
03 Dec 18:44:34 WARN [config.XMLConfiguration] - *** GWC configuration validation error: cvc-elt.1: Cannot find the declaration of element ‘gwcConfiguration’.
03 Dec 18:44:34 WARN [config.XMLConfiguration] - *** Will try to use configuration anyway. Please check the order of declared elements against the schema.
03 Dec 18:44:34 INFO [config.XMLConfiguration] - Initializing GridSets from gwc
03 Dec 18:44:34 INFO [config.XMLConfiguration] - Initializing layers from gwc
03 Dec 18:44:35 INFO [gwc.layer] - Initializing GWC configuration based on GeoServer’s Catalog
03 Dec 18:44:35 INFO [gwc.layer] - GeoServer TileLayer store base directory is: gwc-layers
03 Dec 18:44:35 INFO [gwc.layer] - Loading tile layers from gwc-layers
03 Dec 18:44:35 INFO [gwc.layer] - Loaded 22 tile layers in 19.42 ms
03 Dec 18:44:35 INFO [storage.BlobStoreAggregator] - BlobStoreConfiguration gwc contained no blob store infos.
03 Dec 18:44:35 INFO [storage.DefaultStorageFinder] - **************************************************************************************************************************************
03 Dec 18:44:35 INFO [storage.DefaultStorageFinder] - *** Found Java environment variable GEOSERVER_DATA_DIR set to C:\Program Files\geoserver\data_dir, using it as the default prefix. ***
03 Dec 18:44:35 INFO [gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
03 Dec 18:44:35 INFO [config.GeoserverXMLResourceProvider] - Will look for ‘geowebcache-diskquota.xml’ in directory ‘C:\Program Files\geoserver\data_dir\gwc’.
03 Dec 18:44:35 INFO [config.GeoserverXMLResourceProvider] - Will look for ‘geowebcache-diskquota-jdbc.xml’ in directory ‘C:\Program Files\geoserver\data_dir\gwc’.
03 Dec 18:44:35 INFO [diskquota.ConfigLoader] - DiskQuota configuration is not readable: gwc/geowebcache-diskquota.xml
03 Dec 18:44:35 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
03 Dec 18:44:35 INFO [diskquota.DiskQuotaMonitor] - 0 layers configured with their own quotas.
03 Dec 18:44:35 INFO [diskquota.DiskQuotaMonitor] - 22 layers attached to global quota 500.0 MB
03 Dec 18:44:35 INFO [diskquota.DiskQuotaMonitor] - Disk quota periodic enforcement task set up every 10 SECONDS
03 Dec 18:44:35 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
03 Dec 18:44:35 INFO [georss.GeoRSSPoller] - Initializing GeoRSS poller in a background job…
03 Dec 18:44:35 INFO [georss.GeoRSSPoller] - No enabled GeoRSS feeds found, poller will not run.
03 Dec 18:44:35 INFO [wms.WMSService] - Will NOT recombine tiles for non-tiling clients.
03 Dec 18:44:35 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
03 Dec 18:44:36 INFO [geoserver.config] - Initiated CatalogTimeStampUpdater
03 Dec 18:44:36 WARN [gce.imagemosaic] - Unable to set ordering between tiff readers spi
03 Dec 18:44:38 INFO [geoserver.security] - Start reloading user/groups for service named default
03 Dec 18:44:38 INFO [geoserver.security] - Reloading user/groups successful for service named default
03 Dec 18:44:38 INFO [geoserver.security] - AuthenticationCache Initialized with 1000 Max Entries, 300 seconds idle time, 600 seconds time to live and 3 concurrency level
03 Dec 18:44:38 INFO [geoserver.security] - AuthenticationCache Eviction Task created to run every 600 seconds
2020-12-03 18:44:38.474:INFO:oejsh.ContextHandler:main: Started o.e.j.w.WebAppContext@anonymised.com{GeoServer,/geoserver,file:///C:/Program%20Files/geoserver/webapps/geoserver/,AVAILABLE}{C:\Program Files\geoserver\webapps\geoserver}
2020-12-03 18:44:59.507:WARN:oejx.XmlConfiguration:main:
java.security.PrivilegedActionException: java.io.IOException: Unable to establish loopback connection
Caused by:
at sun.nio.ch.PipeImpl$Initializer.run(Unknown Source)
at sun.nio.ch.PipeImpl.(Unknown Source)
at sun.nio.ch.SelectorProviderImpl.openPipe(Unknown Source)
at java.nio.channels.Pipe.open(Unknown Source)
at sun.nio.ch.WindowsSelectorImpl.(Unknown Source)
at sun.nio.ch.WindowsSelectorProvider.openSelector(Unknown Source)
at java.nio.channels.Selector.open(Unknown Source)
at org.eclipse.jetty.io.SelectorManager.newSelector(SelectorManager.java:384)
at org.eclipse.jetty.io.ManagedSelector.doStart(ManagedSelector.java:109)
at org.eclipse.jetty.io.SelectorManager.doStart(SelectorManager.java:262)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:110)
at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:282)
at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:81)
at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:236)
at org.eclipse.jetty.server.Server.doStart(Server.java:396)
Caused by:
java.net.ConnectException: Connection timed out: connect
at sun.nio.ch.Net.connect0(Native Method)
at sun.nio.ch.Net.connect(Unknown Source)
at sun.nio.ch.SocketChannelImpl.connect(Unknown Source)
at java.nio.channels.SocketChannel.open(Unknown Source)
at sun.nio.ch.PipeImpl$Initializer$LoopbackConnector.run(Unknown Source)
java.lang.reflect.InvocationTargetException
Caused by: java.security.PrivilegedActionException: java.io.IOException: Unable to establish loopback connection
… 7 more
Caused by: java.io.IOException: Unable to establish loopback connection
… 9 more
Caused by: java.net.ConnectException: Connection timed out: connect
… 35 more
… 7 more
… 9 more
… 35 more
Usage: java -jar $JETTY_HOME/start.jar [options] [properties] [configs]
java -jar $JETTY_HOME/start.jar --help # for more information
please help me how to execute it.
You must make sure that the user running GeoServer has permission to write to the data directory.
Ian
Please keep discussion on the list,
That is fine but you must give write and create permission for that directory to the user which is running geoserver (it might be you or a local service user depending on how you are running GeoServer).
Ian
Ian Turton
