[Geoserver-users] getting a problem
The row that matters is
java.io.FileNotFoundException: C:\Program Files\geoserver\data_dir\logs\geoserver.log (Access is denied)
Do not install Geoserver into Program Files, or at least place the data directory into some other place.
-Jukka Rahkonen-
Lähettäjä: sukumar mondal <mondalsukumar9999@…84…>
Lähetetty: torstai 3. joulukuuta 2020 15.20
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: [Geoserver-users] getting a problem
Welcome to GeoServer!
JAVA_HOME: C:\Program Files\Java\jre1.8.0_151
Please wait while loading GeoServer…
2020-12-03 18:44:30.689:INFO::main: Logging initialized @225ms to org.eclipse.jetty.util.log.StdErrLog
2020-12-03 18:44:30.798:WARN:oejx.XmlConfiguration:main: Property ‘jetty.port’ is deprecated, use ‘jetty.http.port’ instead
2020-12-03 18:44:30.798:WARN:oejx.XmlConfiguration:main: Property ‘http.timeout’ is deprecated, use ‘jetty.http.idleTimeout’ instead
2020-12-03 18:44:30.798:INFO:oejs.Server:main: jetty-9.4.18.v20190429; built: 2019-04-29T20:42:08.989Z; git: e1bc35120a6617ee3df052294e433f3a25ce7097; jvm 1.8.0_151-b12
2020-12-03 18:44:30.814:INFO:oejdp.ScanningAppProvider:main: Deployment monitor [file:///C:/Program%20Files/geoserver/webapps/] at interval 1
2020-12-03 18:44:31.423:INFO:oejw.StandardDescriptorProcessor:main: NO JSP Support for /geoserver, did not find org.eclipse.jetty.jsp.JettyJspServlet
2020-12-03 18:44:31.688:INFO:oejs.session:main: DefaultSessionIdManager workerName=node0
2020-12-03 18:44:31.688:INFO:oejs.session:main: No SessionScavenger set, using defaults
2020-12-03 18:44:31.688:INFO:oejs.session:main: node0 Scavenging every 660000ms
Dec 03, 2020 6:44:32 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup ‘XStreamPersisterInitializer’, but ApplicationContext is unset.
WARNING: Extension lookup ‘ExtensionFilter’, but ApplicationContext is unset.
WARNING: Extension lookup ‘ExtensionProvider’, but ApplicationContext is unset.
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
log4j:ERROR setFile(null,true) call failed.
at java.io.FileOutputStream.open0(Native Method)
at java.io.FileOutputStream.open(Unknown Source)
at java.io.FileOutputStream.(Unknown Source)
at org.apache.log4j.FileAppender.setFile(FileAppender.java:294)
at org.apache.log4j.RollingFileAppender.setFile(RollingFileAppender.java:207)
at org.apache.log4j.FileAppender.activateOptions(FileAppender.java:165)
at org.apache.log4j.config.PropertySetter.activate(PropertySetter.java:307)
at org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:172)
at org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:104)
at org.apache.log4j.PropertyConfigurator.parseAppender(PropertyConfigurator.java:842)
at org.apache.log4j.PropertyConfigurator.parseCategory(PropertyConfigurator.java:768)
at org.apache.log4j.PropertyConfigurator.configureRootCategory(PropertyConfigurator.java:648)
at org.apache.log4j.PropertyConfigurator.doConfigure(PropertyConfigurator.java:514)
at org.apache.log4j.PropertyConfigurator.configure(PropertyConfigurator.java:440)
at org.geoserver.logging.LoggingUtils.configureGeoServerLogging(LoggingUtils.java:94)
at org.geoserver.logging.LoggingUtils.initLogging(LoggingUtils.java:218)
at org.geoserver.logging.LoggingStartupContextListener.contextInitialized(LoggingStartupContextListener.java:74)
at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:957)
at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:553)
at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:922)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:365)
at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1497)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1459)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:852)
at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:278)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:545)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:46)
at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:192)
at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:502)
at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:151)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:172)
at org.eclipse.jetty.deploy.providers.WebAppProvider.fileAdded(WebAppProvider.java:416)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:65)
at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:610)
at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:529)
at org.eclipse.jetty.util.Scanner.scan(Scanner.java:392)
at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:313)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:145)
at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:576)
at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:238)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:167)
at org.eclipse.jetty.server.Server.start(Server.java:418)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:119)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:113)
at org.eclipse.jetty.server.Server.doStart(Server.java:382)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1572)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1512)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1511)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:220)
at org.eclipse.jetty.start.Main.start(Main.java:490)
at org.eclipse.jetty.start.Main.main(Main.java:77)
2020-12-03 18:44:32.195:INFO:oejshC.geoserver:main: Initializing Spring root WebApplicationContext
Dec 03, 2020 6:44:33 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup ‘GeoServerSecurityProvider’, but ApplicationContext is unset.
03 Dec 18:44:33 INFO [org.geoserver] - GeoServer configuration lock is enabled
03 Dec 18:44:33 INFO [org.geoserver] - Loading catalog…
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘burg’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘capitals’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘dem’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘cite_lakes’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘grass’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘green’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘generic’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘giant_polygon’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘line’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘poi’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘polygon’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘point’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘poly_landmarks’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘pophatch’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘rain’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘raster’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘restricted’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘simple_roads’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘simple_streams’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘tiger_roads’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded style ‘population’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded default workspace cite
03 Dec 18:44:33 INFO [org.geoserver] - Loaded workspace ‘nurc’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded workspace ‘sde’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded workspace ‘it.geosolutions’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded workspace ‘cite’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded workspace ‘sf’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded workspace ‘tiger’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded workspace ‘topp’
03 Dec 18:44:33 INFO [org.geoserver] - Loaded coverage store ‘arcGridSample’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded coverage ‘Arc_Sample’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘Arc_Sample’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded coverage store ‘img_sample2’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded coverage ‘Pk50095’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘Pk50095’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded coverage store ‘mosaic’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded coverage ‘mosaic’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘mosaic’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded coverage store ‘worldImageSample’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded coverage ‘Img_Sample’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘Img_Sample’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded data store ‘sf’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘archsites’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘archsites’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘bugsites’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘bugsites’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘roads’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘roads’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘restricted’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘restricted’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘streams’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘streams’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded coverage store ‘sfdem’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded coverage ‘sfdem’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘sfdem’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded data store ‘nyc’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘giant_polygon’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘giant_polygon’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘poi’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘poi’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘tiger_roads’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘tiger_roads’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘poly_landmarks’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘poly_landmarks’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded data store ‘states_shapefile’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘states’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘states’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded data store ‘taz_shapes’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘tasmania_cities’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘tasmania_cities’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘tasmania_roads’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘tasmania_roads’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘tasmania_water_bodies’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘tasmania_water_bodies’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded feature type ‘tasmania_state_boundaries’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer ‘tasmania_state_boundaries’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer group ‘spearfish’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer group ‘tasmania’
03 Dec 18:44:34 INFO [org.geoserver] - Loaded layer group ‘tiger-ny’
03 Dec 18:44:34 INFO [org.geoserver] - Read catalog in 1.131 s
03 Dec 18:44:34 INFO [org.geoserver] - Loaded service ‘WMTSInfoImpl-6bf8d24b:17628bd79da:-8000’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded service ‘wcs’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded service ‘wfs’, enabled
03 Dec 18:44:34 INFO [org.geoserver] - Loaded service ‘wms’, enabled
03 Dec 18:44:34 INFO [config.GeoserverXMLResourceProvider] - Will look for ‘geowebcache.xml’ in directory ‘C:\Program Files\geoserver\data_dir\gwc’.
03 Dec 18:44:34 INFO [config.GeoserverXMLResourceProvider] - Found configuration file in gwc
03 Dec 18:44:34 WARN [config.XMLConfiguration] - ********************************************************************************
03 Dec 18:44:34 WARN [config.XMLConfiguration] - *** GWC configuration validation error: cvc-elt.1: Cannot find the declaration of element ‘gwcConfiguration’.
03 Dec 18:44:34 WARN [config.XMLConfiguration] - *** Will try to use configuration anyway. Please check the order of declared elements against the schema.
03 Dec 18:44:34 INFO [config.XMLConfiguration] - Initializing GridSets from gwc
03 Dec 18:44:34 INFO [config.XMLConfiguration] - Initializing layers from gwc
03 Dec 18:44:35 INFO [gwc.layer] - Initializing GWC configuration based on GeoServer’s Catalog
03 Dec 18:44:35 INFO [gwc.layer] - GeoServer TileLayer store base directory is: gwc-layers
03 Dec 18:44:35 INFO [gwc.layer] - Loading tile layers from gwc-layers
03 Dec 18:44:35 INFO [gwc.layer] - Loaded 22 tile layers in 19.42 ms
03 Dec 18:44:35 INFO [storage.BlobStoreAggregator] - BlobStoreConfiguration gwc contained no blob store infos.
03 Dec 18:44:35 INFO [storage.DefaultStorageFinder] - **************************************************************************************************************************************
03 Dec 18:44:35 INFO [storage.DefaultStorageFinder] - *** Found Java environment variable GEOSERVER_DATA_DIR set to C:\Program Files\geoserver\data_dir, using it as the default prefix. ***
03 Dec 18:44:35 INFO [gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
03 Dec 18:44:35 INFO [config.GeoserverXMLResourceProvider] - Will look for ‘geowebcache-diskquota.xml’ in directory ‘C:\Program Files\geoserver\data_dir\gwc’.
03 Dec 18:44:35 INFO [config.GeoserverXMLResourceProvider] - Will look for ‘geowebcache-diskquota-jdbc.xml’ in directory ‘C:\Program Files\geoserver\data_dir\gwc’.
03 Dec 18:44:35 INFO [diskquota.ConfigLoader] - DiskQuota configuration is not readable: gwc/geowebcache-diskquota.xml
03 Dec 18:44:35 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
03 Dec 18:44:35 INFO [diskquota.DiskQuotaMonitor] - 0 layers configured with their own quotas.
03 Dec 18:44:35 INFO [diskquota.DiskQuotaMonitor] - 22 layers attached to global quota 500.0 MB
03 Dec 18:44:35 INFO [diskquota.DiskQuotaMonitor] - Disk quota periodic enforcement task set up every 10 SECONDS
03 Dec 18:44:35 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
03 Dec 18:44:35 INFO [georss.GeoRSSPoller] - Initializing GeoRSS poller in a background job…
03 Dec 18:44:35 INFO [georss.GeoRSSPoller] - No enabled GeoRSS feeds found, poller will not run.
03 Dec 18:44:35 INFO [wms.WMSService] - Will NOT recombine tiles for non-tiling clients.
03 Dec 18:44:35 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
03 Dec 18:44:36 INFO [geoserver.config] - Initiated CatalogTimeStampUpdater
03 Dec 18:44:36 WARN [gce.imagemosaic] - Unable to set ordering between tiff readers spi
03 Dec 18:44:38 INFO [geoserver.security] - Start reloading user/groups for service named default
03 Dec 18:44:38 INFO [geoserver.security] - Reloading user/groups successful for service named default
03 Dec 18:44:38 INFO [geoserver.security] - AuthenticationCache Initialized with 1000 Max Entries, 300 seconds idle time, 600 seconds time to live and 3 concurrency level
03 Dec 18:44:38 INFO [geoserver.security] - AuthenticationCache Eviction Task created to run every 600 seconds
2020-12-03 18:44:38.474:INFO:oejsh.ContextHandler:main: Started o.e.j.w.WebAppContext@…10604…{GeoServer,/geoserver,file:///C:/Program%20Files/geoserver/webapps/geoserver/,AVAILABLE}{C:\Program Files\geoserver\webapps\geoserver}
2020-12-03 18:44:59.507:WARN:oejx.XmlConfiguration:main:
java.security.PrivilegedActionException: java.io.IOException: Unable to establish loopback connection
Caused by:
at sun.nio.ch.PipeImpl$Initializer.run(Unknown Source)
at sun.nio.ch.PipeImpl.(Unknown Source)
at sun.nio.ch.SelectorProviderImpl.openPipe(Unknown Source)
at java.nio.channels.Pipe.open(Unknown Source)
at sun.nio.ch.WindowsSelectorImpl.(Unknown Source)
at sun.nio.ch.WindowsSelectorProvider.openSelector(Unknown Source)
at java.nio.channels.Selector.open(Unknown Source)
at org.eclipse.jetty.io.SelectorManager.newSelector(SelectorManager.java:384)
at org.eclipse.jetty.io.ManagedSelector.doStart(ManagedSelector.java:109)
at org.eclipse.jetty.io.SelectorManager.doStart(SelectorManager.java:262)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:110)
at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:282)
at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:81)
at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:236)
at org.eclipse.jetty.server.Server.doStart(Server.java:396)
Caused by:
java.net.ConnectException: Connection timed out: connect
at sun.nio.ch.Net.connect0(Native Method)
at sun.nio.ch.Net.connect(Unknown Source)
at sun.nio.ch.SocketChannelImpl.connect(Unknown Source)
at java.nio.channels.SocketChannel.open(Unknown Source)
at sun.nio.ch.PipeImpl$Initializer$LoopbackConnector.run(Unknown Source)
java.lang.reflect.InvocationTargetException
Caused by: java.security.PrivilegedActionException: java.io.IOException: Unable to establish loopback connection
… 7 more
Caused by: java.io.IOException: Unable to establish loopback connection
… 9 more
Caused by: java.net.ConnectException: Connection timed out: connect
… 35 more
… 7 more
… 9 more
… 35 more
Usage: java -jar $JETTY_HOME/start.jar [options] [properties] [configs]
java -jar $JETTY_HOME/start.jar --help # for more information
please help me how to execute it.
