Hi folks,
Anyone else seeing this – if a style is not in a workspace (so it can be used globally), the layer preview errors?
If I move the style into the same workspace as the layer, it works fine.
I’m on GS 2.18.
Kind Regards,
Neil Saunders
Business Consultant
How was your Lotsearch experience? Click here.
Lotsearch Pty Ltd Level 3, 68 Alfred Street, Milsons Point, NSW 2061 +61 (0)2 8287 0680
+61 (0) 413 379 883 support@anonymised.com www.lotsearch.com.au
CONFIDENTIAL INFORMATION This transmission may be privileged and may contain confidential information intended only for the recipient(s) named above. Any other distribution, re-transmission, copying or disclosure of this message is strictly prohibited. If you have received this transmission in error, please notify me immediately by telephone or return email, and delete this message from your system. Thank you.
No, it’s new to me, I use global styles all the time.
What’s special about your setup? Thinking out loud, what GeoServer version, which plugins installed, what security setup?
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Andrea,
I’m using the geosolutionsit Docker – 2.18 like this:
docker run -d --name geoserver2 -v /home/ec2-user/reports:/var/local/geoserver/reports -p 80:8080 -e GEOSERVER_DATA_DIR=/var/local/geoserver/reports geosolutionsit/geoserver
I’m creating an isolated workspace for the data. The styles are not assigned to a workspace so they can be used by multiple isolated workspaces. No extra plugins. No security changes at this point.
Neil Saunders
Business Consultant
+61 (0) 413 379 883 support@…9733… www.lotsearch.com.au
Sent: Wednesday, 24 February 2021 3:01 AM
To: Neil Saunders <neil.saunders@…9733…>
Subject: Re: [Geoserver-users] Global Styles not showing in preview
On Fri, Feb 19, 2021 at 4:23 AM Neil Saunders <neil.saunders@…9733…> wrote:
Hi folks,
I’m on GS 2.18.
Kind Regards,
Neil Saunders
Business Consultant
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ah, that explains it. The layer preview GetMap requests are using the global WMS endpoint, if the style being edited is not in a workspace
Workspace isolated layers are not reachable there (they are only from the workspace specific service).
Isolated workspaces usage is pretty uncommon, typically used to publish the same INSPIRE theme multiple times from the same server (or so I hear, I never used them myself).
Not surprised this did not come up before.
Can you write a fix? If so it would be in this area:
https://github.com/geoserver/geoserver/blob/e701004e988a8d0a9b7d993090c9a96dcf155e12/src/web/wms/src/main/java/org/geoserver/wms/web/data/OpenLayersPreviewPanel.java#L202
Not entirely trivial mind, the code is already trying to setup a workspace specific service if the style is in a workspace, it should
also try to recognize the possibility of using a layer (and then check its workspace), or layer group that is in a workspace (but it might also not be).
See also https://github.com/geoserver/geoserver/blob/master/CONTRIBUTING.md
