I have a simple question regarding geoserver graphic card usage.
Does geoserver or one of its image extensions depend of a good graphic card?
We are configuring a web server machine with a Matrox® G200eR2 with 16MB.
Is it enough to run geoserver and its image processing capabilities?
Maybe the next question is not simple:
How to measure how much graphic card geoserver needs?
Rodrigo C. Antonialli
Rio Claro - SP - Brasil
LinkedIn: http://www.linkedin.com/in/rcaprofile
Contato: (19) 8136-2347
rcantonialli@anonymised.com
Skype: rc_antonialli
Hello Rodriko,
as far as I know, GeoServer does not depend from a graphic card. Our server has low-end onboard graphics, just for a little bit administration and thats it.
I also couldn’t imagine where graphic cards could be used but if you would use the gpu for rendering the images.
Stefan
From: Rodrigo Antonialli [mailto:rcantonialli@…84…]
Sent: Friday, March 08, 2013 3:29 PM
To: Geoserver
Subject: [bulk]: [Geoserver-users] Graphic Card and Geoserver
rcantonialli@…84…
On Fri, Mar 8, 2013 at 3:28 PM, Rodrigo Antonialli <rcantonialli@anonymised.com…> wrote:
Nope, as far as I know all GeoServer does happens against the CPU, there is
no usage whatsoever of the graphics card
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Stefan,
Thanks for your reply!
I thought that, for example, GEOS and JAI could use some graphic card capabilities to some image operation. But I really don’t know much about them =)
On Fri, Mar 8, 2013 at 11:52 AM, Stefan Engelhardt (HBT) <Stefan.Engelhardt@anonymised.com> wrote:
Hello Rodriko,
Stefan
From: Rodrigo Antonialli [mailto:rcantonialli@anonymised.com]
To: Geoserver
Thanks!
As I told Stefan, I thought that it could use, so better asking! =)
On Fri, Mar 8, 2013 at 11:56 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, Mar 8, 2013 at 3:28 PM, Rodrigo Antonialli <rcantonialli@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Mar 8, 2013 at 12:01 PM, Rodrigo Antonialli
<rcantonialli@anonymised.com>wrote:
not GEOS... GDAL!
