Hi Alexander,
thanks for reporting that.
Do you have any chance to open a JIRA and contribute your patch as a PR with a test?
Daniele
On Tue, Jul 9, 2019 at 3:46 PM alexander-petkov <greenkov@anonymised.com> wrote:
If a multidimensional file has more than 32 bands, the index in getImageIndex
in GeoSpatialImageReader.java is returned like this:
[32 33 34 … n 0 1 2 3 … 31]
Sorting the index prior to returning it fixes the InvalidRangeException
error:
public List getImageIndex(Query filterQuery) throws IOException {
List descs = slicesCatalog.getGranules(filterQuery);
List indexes = new ArrayList();
for (CoverageSlice desc : descs) {
Integer index =
(Integer)
desc.getOriginator().getAttribute(CoverageSlice.Attributes.INDEX);
indexes.add(index);
Collections.sort(indexes);
return indexes;
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
