[Geoserver-users] gridset definition via rest
Have you tried WMTS GetCapabilities http://demo.opengeo.org/geoserver/gwc/service/wmts?REQUEST=GetCapabilities
-Jukka Rahkonen-
Rot Ulet wrote:
is there a possibility to retrieve the gridset definition of a geowebcached layer via rest call? I have searched the doc and browse the rest api without finding a solution.
The goal is to retrieve the list of layer scales in order to parameter OpenLayer properly.
Rot.
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic patterns at an interface-level. Reveals which users, apps, and protocols are consuming the most bandwidth. Provides multi-vendor support for NetFlow, J-Flow, sFlow and other flows. Make informed decisions using capacity planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-users mailing list
but how can I get the resolutions or scale denominators from the tile
definitions?
Rot.
Le 02/06/2016 16:02, Rahkonen Jukka (MML) a écrit :
-Jukka Rahkonen-
Rot Ulet wrote:
Rot.
Ok ... forget what I said ... I should open my eyes a bit wider!
Rot.
-Jukka Rahkonen-
Rot Ulet wrote:
Rot.
