[Geoserver-users] GS 1.7 installation problem Tomcat 6, Ubuntu Intrepid
Hi list,
I cant seem to get GS 1.7 (war) working in Tomcat 6 (.deb), Ubuntu
Intrepid (x86_64). This is the error:
java.util.ServiceConfigurationError: javax.imageio.spi.ImageWriterSpi:
Provider
it.geosolutions.imageio.stream.output.spi.FileImageOutputStreamExtImplSpi could not be instantiated: java.lang.ClassCastException: Cannot cast it.geosolutions.imageio.stream.output.spi.FileImageOutputStreamExtImplSpi to javax.imageio.spi.ImageWriterSpi
and it's caused by:
Does this sound familiar to anyone? I have no major problems with
running it in Tomcat 5.5.
Thanx, Roald
Roald de Wit
Software Engineer
roald.dewit@anonymised.com
Commercial Support for Open Source GIS Software
http://lisasoft.com/LISAsoft/SupportedProducts/
Extra info:
Running GS 1.7 only fails using the following version of Java:
        java version "1.6.0_0"
        IcedTea6 1.3.1 (6b12-0ubuntu6) Runtime Environment (build
        1.6.0_0-b12)
        OpenJDK 64-Bit Server VM (build 1.6.0_0-b12, mixed mode)
When using Sun's Java, I don't have any problems.
        java version "1.6.0_10"
        Java(TM) SE Runtime Environment (build 1.6.0_10-b33)
        Java HotSpot(TM) 64-Bit Server VM (build 11.0-b15, mixed mode)
Cheers, Roald
On Thu, 2008-10-30 at 11:04 +1030, Roald de Wit wrote:
Hi list,
Provider
and it's caused by:
Thanx, Roald
Roald de Wit
Software Engineer
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Roald de Wit
Software Engineer
Hi Roald,
Unfortunately this a common problem: problems resulting from using a jvm other than the one provided by sun.
I think in this case it is due to the use of jai image extensions which i *think* depend on classes provided only by the sun jvm. Not sure about that though.
Regardless we recommend the sun vm and warn people using other virtual machines that its "at their own risk". Probably not the answer you were looking for :(.
-Justin
Roald de Wit wrote:
Extra info:
        1.6.0_0-b12)
Cheers, Roald
Hi list,
Provider
and it's caused by:
Thanx, Roald
Roald de Wit
Software Engineer
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Roald,
we have worked some days ago on imageio-ext project to fix the spi names.
With the next release the problem should be solved.
Daniele
On Thu, Oct 30, 2008 at 2:14 AM, Roald de Wit <roald.dewit@anonymised.com> wrote:
Extra info:
java version “1.6.0_0”
1.6.0_0-b12)
When using Sun’s Java, I don’t have any problems.
java version “1.6.0_10”
Java™ SE Runtime Environment (build 1.6.0_10-b33)
Java HotSpot™ 64-Bit Server VM (build 11.0-b15, mixed mode)
Cheers, Roald
Hi list,
Provider
and it’s caused by:
Thanx, Roald
Roald de Wit
Software Engineer
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
Roald de Wit
Software Engineer
Eng. Daniele Romagnoli
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
