[Geoserver-users] GWC CPU to 100% / hung / gmaps service
Sorry for # of questions from me recently … trying to get my first geoserver instance running (and one question resulted in legitimate bug report) …
I am now having an issue with GWC … specifically using the gmaps service … taking a thread to 100% CPU use and hanging … with no more response from the service. Any pointers toward debugging this?
This seems to happen randomly … sometimes it will happen quickly after a tomcat restart … sometimes I won’t see it again for a few hours. Not a huge load on server. Just me in development zooming and panning the maps, requesting tiles from the gmaps gwc service.
jstack can’t even seem to walk the stack in the hung thread. I get a “Error occurred during stack walking: java.lang.NullPointerException” from jstack on the specific PID
Platform: Ubuntu 12.04 running in AWS. One layer doing this is postgis-backed layer. The other is an image mosaic layer (with meta info in postgis).
Other gwc services seem to continue ok … I can access the gwc WMS service, etc.
Thanks again,
Mike Grogan
On Mon, Aug 19, 2013 at 7:52 PM, Mike Grogan <d.michael.grogan@anonymised.com>wrote:
Sorry for # of questions from me recently ... trying to get my first
report) ...
I am now having an issue with GWC ... specifically using the gmaps service
... taking a thread to 100% CPU use and hanging ... with no more response
This seems to happen randomly ... sometimes it will happen quickly after a
tomcat restart ... sometimes I won't see it again for a few hours. Not a
jstack can't even seem to walk the stack in the hung thread. I get a
"Error occurred during stack walking: java.lang.NullPointerException" from
Hmm... not sure, but have you tried sending sigquit instead? Quoting from
http://www.crazysquirrel.com/computing/java/basics/java-thread-dump.jspx
kill -QUIT process_id
There process_id is the process number of the running Java process. The
thread dump will be sent to wherever standard out is redirected too.
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I have gotten a thread dump with “kill -3”. Care to take a look at it?
  • Mike
On Mon, Aug 19, 2013 at 2:19 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Mon, Aug 19, 2013 at 7:52 PM, Mike Grogan <d.michael.grogan@anonymised.com> wrote:
Hmm… not sure, but have you tried sending sigquit instead? Quoting from http://www.crazysquirrel.com/computing/java/basics/java-thread-dump.jspx
There process_id is the process number of the running Java process. The thread dump will be sent to wherever standard out is redirected too.
Ing. Andrea Aime
@geowolf
Technical Lead
This looks like it may be getting stuck in a TimerTask in LRUAuthenticationCacheImpl.java that is searching for expired authentication tokens. The stack from the process utilizing 100% CPU is consistently:
“Timer-0” daemon prio=10 tid=0x00007f57495e1800 nid=0x6d0e runnable [0x00007f5743546000]
java.lang.Thread.State: RUNNABLE
at org.geoserver.security.auth.LRUAuthenticationCacheImpl$1.run(LRUAuthenticationCacheImpl.java:66)
at java.util.TimerThread.mainLoop(Timer.java:555)
at java.util.TimerThread.run(Timer.java:505)
In this case, my process id was 27918, which matches the hex 6d0e above. I see this consistently after tomcat restart, though, obviously, the PID/nid changes. Each time, though, the trace for PID/nid returns the TimerTask above.
Looking at the source, this is a TimerTask for adding authentication tokens to be removed.
So, Andrea, I know you and I just discussed gwc and security not working well together earlier. I do still have auth on my data layers … and am considering some workarounds outside of geoserver to help me.
Do you think this issue goes away once I remove all the authentication to the data layers?
Even if it does, could there be cause for concern outside of my GWC services? Could I have stumbled upon a race condition or similar that might impact other things? Could this impact any geoserver layers, etc., requiring authentication even outside of GWC?
Mike Grogan
On Mon, Aug 19, 2013 at 2:32 PM, Mike Grogan <d.michael.grogan@anonymised.com> wrote:
  • Mike
Ing. Andrea Aime
@geowolf
Technical Lead
Hello,
We have had this issue with a version 2.2.0 after upgrading the major cause of the huge number of threads disappeared,
but we still have the issue that from time to time a timer thread was using 100% CPU.
What we saw is that often (always) the CPU issue appears after an outOf memory problem, than an other issue caused this.
In our case this happend after a java.lang.OutOfMemoryError: Java heap space on a rendering task, we are still looking
what could trigger this issue.
Eric
"Timer-0" daemon prio=10 tid=0x00007f57495e1800 nid=0x6d0e runnable [0x00007f5743546000]
So, Andrea, I know you and I just discussed gwc and security not working well together earlier. I do still have auth on my data layers ... and am considering some workarounds outside of geoserver to help me.
Mike Grogan
On Mon, Aug 19, 2013 at 2:32 PM, Mike Grogan <d.michael.grogan@anonymised.com <mailto:d.michael.grogan@anonymised.com>> wrote:
    I have gotten a thread dump with "kill -3". Care to take a look at it?
    - Mike
            legitimate bug report) ...
            service ... taking a thread to 100% CPU use and hanging ... with
            this?
            after a tomcat restart ... sometimes I won't see it again for a
            service.
            get a "Error occurred during stack walking:
            java.lang.NullPointerException" from jstack on the specific PID
        from
        more information.
        Ing. Andrea Aime
        @geowolf
        Technical Lead
        phone: +39 0584 962313 <tel:%2B39%200584%20962313>
        fax: +39 0584 1660272 <tel:%2B39%200584%201660272>
        mob: +39 339 8844549 <tel:%2B39%20%C2%A0339%208844549>
Introducing Performance Central, a new site from SourceForge and
AppDynamics. Performance Central is your source for news, insights,
analysis and resources for efficient Application Performance Management.
Visit us today!
http://pubads.g.doubleclick.net/gampad/clk?id=48897511&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Eric Smets eric.smets@anonymised.com
FKS bvba - Formal and Knowledge Systems http://www.fks.be/
Schampbergstraat 32 Tel: ++32-(0)11-21 49 11
B-3511 Hasselt Fax: ++32-(0)11-22 04 19
Hi guys,
I’m interested to know whether either of you came up with any further leads on this issue. I’m experiencing a similar thing, using version 2.3.5.
My instance of GeoServer is primarily used to serve tiles of weather-related GeoTIFF (relatively small in size) layers which are created and aged dynamically using the REST API. Authentication is required (implemented using “data security” rules on workspaces) and is provided with each request by means of HTTP header proxy authentication.
Under light to moderate load GeoServer operates normally for anywhere between minutes and hours before OGC service requests suddenly hang, despite the Tomcat being responsive to other requests.
A thread dump shows many threads in the WAITING state stemming from org.geoserver.security.auth.LRUAuthenticationCacheImpl.
Andrew
On 20/08/2013 17:11, Eric Smets wrote:
Hello,
Eric
Mike Grogan
  • Mike
Ing. Andrea Aime
@geowolf
Technical Lead
Visit us today!
[http://pubads.g.doubleclick.net/gampad/clk?id=48897511&iu=/4140/ostg.clktrk](http://pubads.g.doubleclick.net/gampad/clk?id=48897511&iu=/4140/ostg.clktrk)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Eric Smets                                    [eric.smets@anonymised.com](mailto:eric.smets@anonymised.com)
FKS bvba - Formal and Knowledge Systems       [http://www.fks.be/](http://www.fks.be/)
Visit us today!
On Mon, Aug 19, 2013 at 10:33 PM, Mike Grogan <d.michael.grogan@anonymised.com>wrote:
consistently:
        at
TimerTask above.
Yep, I noticed. Not sure why this is happening, haven't wrote that code
myself, but that thing
just loops over authentication cache keys, my only guess is that they might
be accumulating faster
than we can expire them, which might be compatible with a tilecache like
workload when many
parallel requests are coming in, under the assumption that each one for
some reason creates
a new entry.
By looking at the code, it seems that might happen if the client does not
send back the
_geoserver_security_cache_key attribute...
the data layers?
This one seems more related to the client and maybe the fact you're trying
to authenticate from it?
I cannot be more precise without spending time in a serious investigation,
the code in question has been
written by Justin and Christian (cc'ed) so I'm not familiar with it.
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Hi all
The code was written by me. I is hard to find the problem but looking at the code in
org.geoserver.security.auth.AuthenticationCacheKey
I see the equals(…) implementation comparing strings with == instead of using String.equals(). Maybe the cache is filled up.
Proposal:
I can send you an AuthenticationCacheKey.class file. You have to replace this file in the main-.jar file contained in your WEB-INF/lib folder. (The jar is a zip file, use your preferred zip tool).
After replacement, restart Geoserver and look at the results.
Let me know
Christian
On Wed, Aug 21, 2013 at 9:42 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Mon, Aug 19, 2013 at 10:33 PM, Mike Grogan <d.michael.grogan@anonymised.com> wrote:
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Yep, I noticed. Not sure why this is happening, haven’t wrote that code myself, but that thing
just loops over authentication cache keys, my only guess is that they might be accumulating faster
than we can expire them, which might be compatible with a tilecache like workload when many
parallel requests are coming in, under the assumption that each one for some reason creates
a new entry.
By looking at the code, it seems that might happen if the client does not send back the
_geoserver_security_cache_key attribute…
This one seems more related to the client and maybe the fact you’re trying to authenticate from it?
I cannot be more precise without spending time in a serious investigation, the code in question has been
written by Justin and Christian (cc’ed) so I’m not familiar with it.
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Aug 21, 2013 at 2:14 PM, Christian Mueller <
christian.mueller@anonymised.com> wrote:
Hi all
the code in
I see the equals(..) implementation comparing strings with == instead of
Hmmm... the code seems correct to me?
        AuthenticationCacheKey otherKey = (AuthenticationCacheKey) other;
        return (filterName == otherKey.filterName
            || (filterName != null &&
filterName.equals(otherKey.filterName)))
            && (cacheKey == otherKey.cacheKey
            || (cacheKey != null && cacheKey.equals(otherKey.cacheKey)));
First tries to see if it's the same string, or if both are null, if not,
ensures the filterName
is not null, then uses equals.
information.
Ing. Andrea Aime
@geowolf
Technical Lead
-1 to me, the code is correct. Perhaps I should not work on 3 projects concurrently.
@Andrew
Do you see some lines in the log file like
21 Aug 15:34:57 DEBUG [geoserver.security] - Number of expired authentication tokens found: 0
21 Aug 15:34:57 DEBUG [geoserver.security] - End searching for expired authentication tokens
(Maybe you have to set your logging profile to VERBOSE_LOGGING.properties in the global settings page).
Christian
On Wed, Aug 21, 2013 at 2:34 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Wed, Aug 21, 2013 at 2:14 PM, Christian Mueller <christian.mueller@anonymised.com.5445…> wrote:
Hi all
Hmmm… the code seems correct to me?
|| (filterName != null && filterName.equals(otherKey.filterName)))
First tries to see if it’s the same string, or if both are null, if not, ensures the filterName
Ing. Andrea Aime
@geowolf
Technical Lead
I see the same thing as Andrew on 2.3.3 and 2.3.4
I would be willing to swap the class file and give it a try if you want, Christian, though I just see your e-mail voting yourself -1 … thinking existing code was ok.
At first, this seemed almost random. It was happening really with close to 0 load on the geoserver. It was just me on a development box zooming and panning my map. Of course, in my case, my Google maps-based client did make multiple simultaneous requests to load tiles from the gwc gmaps service, but just a few at a time. It seemed that, if I hit it just right (or wrong, I guess) in making new requests, it would lock up. Sometimes this was even after everything had been idle with no requests at all for many minutes or more. I could initiate new requests after none had happened for a while and, bam, 100% cpu use and no response from gwc instantly. This is what made this seem like a race condition … I would have to hit stuff just at the right time it seemed to make it happen. Sometimes I could get this to happen within a few minutes … sometimes it would take me an hour or so to make this happen.
So, I wrote some crude bash scripts that would make about 30 simultaneous requests continuously via wget. With this, I can often (but not always) get the 100% cpu lockup from LRUAuthenticationCacheImpl within 2 minutes. This sort of suggests to me that this problem is occurring whenever there is an incoming request happening at the exact instant with the TimerTask firing. I haven’t dug through the code enough to prove this, but that is what it feels like.
While Andrew has seen this with header proxy authentication, I have seen it with both basic and authkey plugin authentication, though it seems to be more reproducible with the authkey.
Andrea speaks of having the client return geoserver_security_cache_key. Can you provide a bit more info? What would you expect the client to provide back to geoserver? Especially in the authkey case where it’s one request and done.
Mike Grogan
On Wed, Aug 21, 2013 at 8:14 AM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi all
Proposal:
Let me know
Christian
a new entry.
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Mike
geoserver_security_cache_key is for internal use only.
About your bash scripts. Can you reproduce the race condition using basic auth (standard) and the Geoserver demo data. If you can, it would be nice if you can send me these scripts.
Christian
On Wed, Aug 21, 2013 at 4:04 PM, Mike Grogan <d.michael.grogan@anonymised.com> wrote:
Mike Grogan
Hi all
Proposal:
Let me know
Christian
a new entry.
Ing. Andrea Aime
@geowolf
Technical Lead
Not sure whether this is helpful, or indicates anything significant, but I’ve attached the truncated output of kill -3 which I ran against my “hung” GeoServer JVM this morning. It’s only 410 lines long - the ellipses indicate essentially repeated traces.
A summary of the first few sections is as follows:
Full thread dump Java HotSpot(TM) 64-Bit Server VM (19.1-b02 mixed mode):
"http-bio-8180-exec-31" daemon prio=10 tid=0x00002aaac1c66000 nid=0xac0 waiting on condition [0x00000000520a0000]
java.lang.Thread.State: TIMED_WAITING (parking)
at sun.misc.Unsafe.park(Native Method)
- parking to wait for <0x0000000783995318> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:198)
at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2025)
at java.util.concurrent.LinkedBlockingQueue.poll(LinkedBlockingQueue.java:424)
at org.apache.tomcat.util.threads.TaskQueue.poll(TaskQueue.java:86)
at org.apache.tomcat.util.threads.TaskQueue.poll(TaskQueue.java:32)
at java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:945)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:907)
at java.lang.Thread.run(Thread.java:662)
... 5-10 similar to the above
"http-bio-8180-exec-23" daemon prio=10 tid=0x0000000059641800 nid=0xa22 waiting on condition [0x0000000051998000]
java.lang.Thread.State: WAITING (parking)
- parking to wait for <0x0000000783a48450> (a java.util.concurrent.locks.ReentrantReadWriteLock$FairSync)
at java.util.concurrent.locks.LockSupport.park(LockSupport.java:158)
at java.util.concurrent.locks.AbstractQueuedSynchronizer.parkAndCheckInterrupt(AbstractQueuedSynchronizer.java:811)
at java.util.concurrent.locks.AbstractQueuedSynchronizer.doAcquireShared(AbstractQueuedSynchronizer.java:941)
at java.util.concurrent.locks.AbstractQueuedSynchronizer.acquireShared(AbstractQueuedSynchronizer.java:1261)
at java.util.concurrent.locks.ReentrantReadWriteLock$ReadLock.lock(ReentrantReadWriteLock.java:594)
at org.geoserver.security.auth.LRUAuthenticationCacheImpl.get(LRUAuthenticationCacheImpl.java:148)
at org.geoserver.security.filter.GeoServerSecurityFilter.authenticateFromCache(GeoServerSecurityFilter.java:92)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:47)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
... several hundred similar to the above
Andrew
kill-3.txt (30.5 KB)
On 22/08/2013 00:38, Christian Mueller wrote:
Hi Mike
Christian
Mike Grogan
Hi all
Proposal:
Let me know
Christian
a new entry.
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Aug 21, 2013 at 4:38 PM, Christian Mueller <
Hi Mike
Christian,
I had another quick look at the code during a build, and I'm starting to
question the need of that cleanup thread,
I have the impression in the end it's only causing trouble.
Rationale:
* the map is a LRU one, with 1000 entries, so it purges unused items by
itself
* if an item that's expired is looked up, it gets removed anyways by the
lookup code
So, why should we do a "stop the world" operation like the one the timed
cleaner is doing?
(while it's running, no one else can authenticate)
information.
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Aug 22, 2013 at 11:08 AM, Andrea Aime
<andrea.aime@anonymised.com>wrote:
Christian,
Rationale:
itself
lookup code
cleaner is doing?
Ah, another bit. Since we have Guava stuck in the classpath, we could
probably make good use of it
and replace the LRUMap with a concurrent LRU map as built by the
CacheBuilder, have a look:
http://docs.guava-libraries.googlecode.com/git-history/v10.0.1/javadoc/com/google/common/cache/CacheBuilder.html
With this data structure I believe we could also get rid of the
ReadWriteLock and increase concurrency.
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea
The problem is that most cache implementations have global expire time settings. We need global expire times as default but it must be possible to assign expire times to individual entries. As an example, digest authentication has its own expire times and it does not make sense if the cache has expire times larger than the configured expire times of the digest authentication filter. A cache entry created by digest authentication has expire times limited by the digest authentication configuration.
The cleaner thread is here to guarantee that an unused authentication token is not cached for a long time period, this is a security risk.
I am thinking about using Collections.synchronizedMap(…) and to kick out all the locking stuff.
What do you think ?
On Thu, Aug 22, 2013 at 11:13 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Aug 22, 2013 at 11:08 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Christian,
Ah, another bit. Since we have Guava stuck in the classpath, we could probably make good use of it
and replace the LRUMap with a concurrent LRU map as built by the CacheBuilder, have a look:
With this data structure I believe we could also get rid of the ReadWriteLock and increase concurrency.
Ing. Andrea Aime
@geowolf
Technical Lead
I had another quick look at the code during a build, and I’m starting to question the need of that cleanup thread,
I have the impression in the end it’s only causing trouble.
Rationale:
  • the map is a LRU one, with 1000 entries, so it purges unused items by itself
  • if an item that’s expired is looked up, it gets removed anyways by the lookup code
So, why should we do a “stop the world” operation like the one the timed cleaner is doing?
(while it’s running, no one else can authenticate)
On Thu, Aug 22, 2013 at 11:52 AM, Christian Mueller <
Hi Andrea
configuration.
I am thinking about using Collections.synchronizedMap(..) and to kick out
Ugh, it would limit scalability quite a bit. The Guava CacheBuilder should
be a much more performant solution.
Once built you can treat it as a regular map, it handles LRU and
concurrency internally.
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Hello,
We had/have on a production machine the same issue.
Following the discuss we looked into the implementation of LRUAuthenticationCacheImpl
The origin of the problem is not clear but the result is only one loop over the keys.
LRUAuthenticationCacheImpl. Some addional logging is also added but could be removed
The changed snipped follows
    TimerTask removeExpiredTask = new TimerTask() {
         @Override
         public void run() {
             LOGGER.fine("Start searching for expired authentication tokens");
             writeLock.lock();
             try {
                  int removed = 0;
                  long currentTime=System.currentTimeMillis();
                  if (cache.size() > 50) LOGGER.info("AuthKey Cache entries: " + cache.size());
                  Iterator<AuthenticationCacheEntry> iter = cache.values().iterator();
                  while (iter.hasNext())
                     if (iter.next().hasExpired(currentTime))
                        iter.remove();
                        removed++;
                 LOGGER.fine("Number of expired authentication tokens found: " + removed);
             } finally {
                 writeLock.unlock();
             LOGGER.fine("End searching for expired authentication tokens");
Op 22/08/2013 11:58, Andrea Aime schreef:
On Thu, Aug 22, 2013 at 11:52 AM, Christian Mueller <christian.mueller@anonymised.com <mailto:christian.mueller@anonymised.com>> wrote:
    Hi Andrea
    configuration.
Ugh, it would limit scalability quite a bit. The Guava CacheBuilder should be a much more performant solution.
Once built you can treat it as a regular map, it handles LRU and concurrency internally.
Ing. Andrea Aime
@geowolf
Technical Lead
Visit us today!
Hi Eric
Only to be sure, the above code snippet solves the issue ?
If it does, I will publish a modified class file for the other users to test.
My current idea was to remove the time task completely, but your solution would be better and safer.
Please let me know
On Thu, Aug 22, 2013 at 4:09 PM, Eric Smets <eric.smets@…5451…> wrote:
Hello,
@Override
public void run() {
LOGGER.fine(“Start searching for expired authentication tokens”);
writeLock.lock();
try {
int removed = 0;
Iterator iter = cache.values().iterator();
iter.remove();
removed++;
} finally {
writeLock.unlock();
LOGGER.fine(“End searching for expired authentication tokens”);
On Thu, Aug 22, 2013 at 11:52 AM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Visit us today!
Eric Smets                                    [eric.smets@anonymised.com](mailto:eric.smets@...5451...)
Visit us today!
Hi Andrea
Ing. Andrea Aime
@geowolf
Technical Lead
Hi all
I attached LRUAuthenticationCacheImpl.class and LRUAuthenticationCacheImpl$1.class for testing. These classes includes the code snippet proposed by Eric. Please replace these classes in
WEB-INF/lib/main-.jar
Let me know about the results.
If the problem persists, I will publish a version without the timer task. This should resolve the issue. The disadvantage would be that authentication tokens are hold in memory longer than needed, the functionality would not change.
Christian
LRUAuthenticationCacheImpl.class (6.24 KB)
LRUAuthenticationCacheImpl$1.class (2.36 KB)
On Thu, Aug 22, 2013 at 5:18 PM, Eric Smets <eric.smets@anonymised.com> wrote:
Op 22/08/2013 16:30, Christian Mueller schreef:
Hi Eric
We have only tested this modification, this came up after an internal discussion.
We can not confirm that this solves the original issue, but this solution should do a better job.
We could use the testscript from Andrew to confirm the solution.
Please let me know
On Thu, Aug 22, 2013 at 4:09 PM, Eric Smets <eric.smets@anonymised.com> wrote:
Hello,
@Override
public void run() {
writeLock.lock();
try {
int removed = 0;
iter.remove();
removed++;
} finally {
writeLock.unlock();
On Thu, Aug 22, 2013 at 11:52 AM, Christian Mueller <christian.mueller@anonymised.com445…> wrote:
Visit us today!
Visit us today!
Hi Andrea
Ing. Andrea Aime
@geowolf
Technical Lead
