Hi guys,
I have a problem with Integrated GeowebCache.
Seeding Layers fails and here is the stack trace.
I have tried Vector and Raster layers a like. If it's important I have
changed the GEOWEBCACHE_CACHE_DIR=/serverDir/ externalized.
I have tried to have the raster style from the defaul Global workspace to
same workspace as Layer and nothing works.
Opening the Layer Preview through the GWC and WMS endpoint and zooming
around actually creates the tiles.
Seeding fails.
Prior to this Exception I have the following in the logs.
2017-09-29 11:41:09,759 INFO [org.geotools.referencing.factory] -
*user_projections/epsg_operations.properties was not found*, using the
default set of coordinate operation overrides (normally empty)
2017-09-29 11:41:09,760 INFO [org.geotools.referencing.factory] - Using
"file:/opt/tomcat2/webapps/geoserver/WEB-INF/lib/gs-main-2.11.2.jar!/org/vfny/geoserver/crs/epsg_operations.properties"
as EPSG factory.
and
2017-09-29 11:41:37,242 DEBUG [org.geotools.referencing.factory] - Failure
in the primary factory: No code "EPSG:900913" from authority "European
Petroleum Survey Group" found for object of type "IdentifiedObject". Now
trying the fallback factory...
2017-09-29 11:41:37,249 DEBUG [org.geotools.referencing.factory] - Failure
"CoordinateReferenceSystem". Now trying the fallback factory...
This issue is killing me. Kindly assist.
Kind Regards,
Steve Omondi
GIS & DB Developer/DBA
Ramani Online, Ramani Geosystems
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html
