On Tue, Jan 6, 2015 at 6:50 PM, Jim Hughes <jnh5y@anonymised.com> wrote:
I'm working on a project aimed at persisting raster data in a cloud-based
storage solution. For our purposes, we expect to be storing varying
resolutions of an image pyramid.
For separate, programmatic concerns, we are interested in querying to find
out which level of the image pyramid will completely cover a desired
bounding box. I'm wondering what is the most natural way to answer that
question.
I've considered CSW, and it doesn't seem to be a perfect fit. On the
other hand, one could image writing a GeoTools DataStore which could answer
WFS requests in a hacky way. Is there a more typical way to answer a
question about a portion of a raster?
You could also consider writing a WPS process that answers the question
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
