Hi Andrea,
Log when I publish the first layer : ------------------------------------------------------------------------------------------------------------------------------------------------------
28 Sep 10:47:16 INFO [catalog.rest] - PUT file, mimetype: text/plain; charset=UTF-8
28 Sep 10:47:16 INFO [catalog.rest] - Auto-configuring datastore: ShpDirUrbis
28 Sep 10:47:20 INFO [catalog.rest] - Added feature type MuNeighbour
28 Sep 10:47:21 INFO [catalog.rest] - PUT layer MuNeighbour
28 Sep 10:47:21 INFO [org.geoserver] - Loaded feature type 'null', enabled
28 Sep 10:47:21 WARN [catalog.impl] - Failed to load actual store for FeatureTypeInfoImpl[null]
28 Sep 10:47:21 INFO [catalog.rest] - PUT FeatureTypeShpDirUrbis,MuNeighbour updated metadata only
28 Sep 10:47:21 ERROR [jdbcconfig.config] - Problem while reinitializing Logging from JDBC Config. Log configuration may not be correct.
java.lang.NullPointerException
at sun.reflect.GeneratedMethodAccessor328.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.geoserver.jdbcconfig.config.JDBCGeoServerFacade.reinitializeLogging(JDBCGeoServerFacade.java:99)
at org.geoserver.jdbcconfig.config.JDBCGeoServerFacade.setGeoServer(JDBCGeoServerFacade.java:132)
at org.geoserver.config.impl.GeoServerImpl.setFacade(GeoServerImpl.java:71)
at org.geoserver.jdbcconfig.JDBCGeoServerLoader.loadGeoServer(JDBCGeoServerLoader.java:102)
at org.geoserver.config.GeoServerLoader.reload(GeoServerLoader.java:208)
at org.geoserver.jdbcconfig.JDBCGeoServerLoader.reload(JDBCGeoServerLoader.java:143)
at org.geoserver.config.GeoServerLoaderProxy.reload(GeoServerLoaderProxy.java:66)
at org.geoserver.config.impl.GeoServerImpl.reload(GeoServerImpl.java:452)
at org.geoserver.catalog.rest.CatalogReloader.reloadCatalog(CatalogReloader.java:76)
at org.geoserver.catalog.rest.CatalogReloader$1.handlePost(CatalogReloader.java:56)
at org.restlet.Finder.handle(Finder.java:296)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
28 Sep 10:47:21 INFO [gwc.layer] - GeoServer TileLayer store base directory is: /srv/data/geoserver/gwc-layers
28 Sep 10:47:21 INFO [gwc.layer] - Loading tile layers from /srv/data/geoserver/gwc-layers
28 Sep 10:47:21 INFO [gwc.layer] - Initializing GWC configuration based on GeoServer's Catalog
28 Sep 10:47:21 INFO [gwc.layer] - GWC configuration based on GeoServer's Catalog loaded successfuly
28 Sep 10:47:23 INFO [gwc.layer] - Truncating default style for layer Urbis:MuNeighbour, as it changed from polygon to UrbisMuNeighbourZoomAttrLblNAMEFRPolygon0.4
28 Sep 10:47:23 INFO [geoserver.gwc] - Saving GeoSeverTileLayer Urbis:MuNeighbour
28 Sep 10:47:23 INFO [catalog.rest] - PUT layer MuNeighbour
The second one : ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
28 Sep 10:47:24 INFO [catalog.rest] - PUT style UrbisHighwaysZoomLineSized
28 Sep 10:47:26 INFO [catalog.rest] - PUT file, mimetype: text/plain; charset=UTF-8
28 Sep 10:47:26 INFO [catalog.rest] - Using existing datastore: ShpDirUrbis
28 Sep 10:47:30 INFO [catalog.rest] - Added feature type Highways
28 Sep 10:47:31 INFO [catalog.rest] - PUT layer Highways
28 Sep 10:47:31 INFO [org.geoserver] - Loaded feature type 'null', enabled
28 Sep 10:47:31 WARN [catalog.impl] - Failed to load actual store for FeatureTypeInfoImpl[null]
28 Sep 10:47:31 INFO [catalog.rest] - PUT FeatureTypeShpDirUrbis,Highways updated metadata only
28 Sep 10:47:31 ERROR [jdbcconfig.config] - Problem while reinitializing Logging from JDBC Config. Log configuration may not be correct.
28 Sep 10:47:31 INFO [gwc.layer] - GeoServer TileLayer store base directory is: /srv/data/geoserver/gwc-layers
28 Sep 10:47:31 INFO [gwc.layer] - Loading tile layers from /srv/data/geoserver/gwc-layers
28 Sep 10:47:31 INFO [gwc.layer] - Initializing GWC configuration based on GeoServer's Catalog
28 Sep 10:47:31 INFO [gwc.layer] - GWC configuration based on GeoServer's Catalog loaded successfuly
28 Sep 10:47:52 INFO [gwc.layer] - Truncating default style for layer Urbis:Highways, as it changed from line to UrbisHighwaysZoomLineSized
28 Sep 10:47:52 INFO [geoserver.gwc] - Saving GeoSeverTileLayer Urbis:Highways
28 Sep 10:47:52 INFO [catalog.rest] - PUT layer Highways
Log when I want to previsualize the layer MuNeightbour ( the first one ) : ----------------------------------------------------------------------------------------------------------------------------------
Error while getting feature type, flushing cache and retrying: Schema 'MuNeighbour' does not exist.
28 Sep 10:55:07 WARN [geoserver.catalog] - Unable to flush 'http://www.cirb.brussels/urbis:MuNeighbour
java.io.IOException: Schema 'MuNeighbour' does not exist.
at org.geotools.data.store.ContentDataStore.ensureEntry(ContentDataStore.java:620)
at org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:387)
at org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:354)
at org.geoserver.catalog.ResourcePool.flushState(ResourcePool.java:2335)
at org.geoserver.catalog.ResourcePool.flushDataStore(ResourcePool.java:2309)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:872)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:860)
at org.geoserver.catalog.impl.FeatureTypeInfoImpl.getFeatureType(FeatureTypeInfoImpl.java:109)
at sun.reflect.GeneratedMethodAccessor145.invoke(Unknown Source)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:146)
at com.sun.proxy.$Proxy71.getFeatureType(Unknown Source)
at org.geoserver.web.CatalogIconFactory.getSpecificLayerIcon(CatalogIconFactory.java:120)
at org.geoserver.web.demo.PreviewLayer.getIcon(PreviewLayer.java:76)
at org.geoserver.web.demo.MapPreviewPage$1.getComponentForProperty(MapPreviewPage.java:76)
at org.geoserver.web.wicket.GeoServerTablePanel$4.populateItem(GeoServerTablePanel.java:211)
at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:562)
at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:131)
at org.apache.wicket.Component.internalBeforeRender(Component.java:1071)
at org.apache.wicket.Component.beforeRender(Component.java:1105)
at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753)
at org.apache.wicket.Component.onBeforeRender(Component.java:3946)
at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:151)
at org.apache.wicket.markup.repeater.AbstractPageableView.onBeforeRender(AbstractPageableView.java:121)
at org.apache.wicket.Component.prepareForRender(Component.java:2292)
at org.apache.wicket.Component.prepareForRender(Component.java:2329)
at org.apache.wicket.ajax.AjaxRequestTarget.respondComponent(AjaxRequestTarget.java:830)
at org.apache.wicket.ajax.AjaxRequestTarget.respondComponents(AjaxRequestTarget.java:682)
at org.apache.wicket.ajax.AjaxRequestTarget.respond(AjaxRequestTarget.java:592)
at org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:105)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1258)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:650)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:76)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:620)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:318)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
28 Sep 10:55:08 INFO [geoserver.wms] -
Request: getServiceInfo
28 Sep 10:55:08 WARN [geoserver.catalog] - Error while getting feature type, flushing cache and retrying: Schema 'MuNeighbour' does not exist.
28 Sep 10:55:08 WARN [geoserver.catalog] - Unable to flush 'http://www.cirb.brussels/urbis:MuNeighbour
at org.geoserver.wms.map.GetMapKvpRequestReader.checkStyle(GetMapKvpRequestReader.java:1188)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:422)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:83)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1487)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:675)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:270)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
28 Sep 10:55:08 ERROR [geoserver.ows] -
java.lang.RuntimeException: Error getting FeatureType, this should never happen!
at org.geoserver.wms.map.GetMapKvpRequestReader.checkStyle(GetMapKvpRequestReader.java:1192)
Caused by: java.io.IOException: Schema 'MuNeighbour' does not exist.
at org.geotools.data.store.ContentDataStore.getSchema(ContentDataStore.java:338)
at org.geotools.data.store.ContentDataStore.getSchema(ContentDataStore.java:712)
at org.geotools.data.store.ContentDataStore.getSchema(ContentDataStore.java:103)
at org.geoserver.catalog.ResourcePool.getCacheableFeatureType(ResourcePool.java:898)
at org.geoserver.catalog.ResourcePool.tryGetFeatureType(ResourcePool.java:879)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:873)
Sorry for the message size.
Best regards,
Nicolas
[/uploads/default/original/2X/5/522e2e77acad9e9e76e5adb8e000a1109bd48936.png]
Nicolas GILLARD
Analyst Programmer
Projects - IS
Avenue des Arts 21, 1000 Bruxelles - cirb.brussels<http://cirb.brussels> - disclaimer<http:/cirb.brussels/disclaimer-1>
T +32 2 600 43 13 | G +32 479 57 92 04 | Helpdesk +32 2 801 00 00
Be green, leave it on the screen ! [/uploads/default/original/2X/4/4150cdfd6df3de09857f07b311579aaca6f60c4c.png] <http://www.linkedin.com/company/cirb_cibg> [/uploads/default/original/2X/f/ff34d9710e85ffbae4215766f91cb3c8a61e3dbf.png] <https://twitter.com/CIRB_CIBG> [/uploads/default/original/2X/7/7bfa6843c6ace4608a73f6a4926d5d56d793adf8.png] <http://www.environnement.brussels/thematiques/ville-durable/le-label-entreprise-ecodynamique>
A noter ! L'adresse email de votre correspondant CIRB a changé pour devenir @cirb.brussels.
Opgelet! Het e-mailadres van uw CIBG-contact is veranderd en eindigt voortaan op @cibg.brussels.
De : andrea.aime@anonymised.com [andrea.aime@anonymised.com] de la part de Andrea Aime [andrea.aime@anonymised.com]
Envoyé : lundi 28 septembre 2015 10:37
À : GILLARD Nicolas
Cc : geoserver-users@lists.sourceforge.net
Objet : Re: [Geoserver-users] Help : Geoserver publish shapefile -> Schema does not exist
On Mon, Sep 28, 2015 at 10:22 AM, GILLARD Nicolas <ngillard@anonymised.com<mailto:ngillard@anonymised.com>> wrote:
<ServiceExceptionReport version="1.1.1"><ServiceException>
</ServiceException></ServiceExceptionReport>
In geoserver logs :
28 Sep 09:46:36 WARN [geoserver.catalog] - Unable to flush 'http://www.cirb.brussels/urbis:MuNeighbour
Do you have a full stack trace? I don't have enough information to help with the above
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
