[Geoserver-users] help newbie
Hi I'm new to geosrever. I'm planning to develop a web-gis application with
these capabilities:
- visualization on google map
- spatial querying on the fly (like: which are the polygons that touch a
specific polygon)
I want to use postgre/postgis as repository for my spatial data, geoserver
and the google maps api.
I know that geoserver gets data directly from postgis and so my web app will
communicate with geoserver. But I don't undestand how it works when I have
to run a spatial query? Can geoserver do spatial querying?
thank's
bye
d.
View this message in context: http://www.nabble.com/help-newbie-tp24479616p24479616.html
You should look at the openlayers library for the front end. It will do all of what your application requires. It can use the google maps base map, and overlay vector data from geoserver or a variety of other sources on top of it.
As for running spatial queries against geoserver, yes it will do that. On the client side you have to build up a "filter" be it spatial or attribute based. Openlayers will translate the filter into a WFS request and pull the data in from geoserver, which can be getting the data directly from postgis.
For exactly how to build up filters you might want to check out the openlayers documentation, or start asking questions on their mailing list.
Hope that helps.
-Justin
these capabilities:
specific polygon)
thank's
bye
d.
Justin Deoliveira
OpenGeo - http://opengeo.org
thank's for tips!!
bye
Justin Deoliveira-6 wrote:
Hope that helps.
-Justin
with
these capabilities:
specific polygon)
geoserver
will
have
thank's
bye
d.
Justin Deoliveira
Enter the BlackBerry Developer Challenge
This is your chance to win up to $100,000 in prizes! For a limited time,
vendors submitting new applications to BlackBerry App World(TM) will have
the opportunity to enter the BlackBerry Developer Challenge. See full
prize
details at: http://p.sf.net/sfu/Challenge
Geoserver-users mailing list
View this message in context: http://www.nabble.com/help-newbie-tp24479616p24513854.html
