[Geoserver-users] Help please!!!!
Hi Claudius, how are you?
Dear, I have a problem on the geoserver, which I’ve been trying to solve for 5 days and I can’t find any kind of solution.
I can’t make the server read the data directory I point to.
In the logs, I get this message:
2021-12-05 19:42:38,249 WARN [geoserver.platform] - Found Servlet context parameter GEOSERVER_DATA_DIR set to /var/lib/geoserverv , which is not writeable
2021-12-05 19:42:38,250 INFO [geoserver.platform] - Falling back to embedded data directory: /var/lib/tomcat9/webapps/geoserversg/data
I already set permissions on the folder to tomcat:tomcat (750).
Wherever I put the data folder on the server, I always have the same message (whether on a secondary disk, on the root, or anywhere).
I’ve already tried to insert the path in the tomcat9.service file, but the problem persists.
I have installed tomcat9, java 11.
What else can I check to try to solve this problem?
Please give me some tips, possibilities to solve this problem. I don’t know what else to look at here. Any guidance, suggestion or observation, I know will have a great effect.
Best regards.
Maurício Vieira Cardoso Filho
Gerente TI Infra
Tel: +556137995051
email : mcardoso@anonymised.com;
skype: mauricio.cardoso1974
geoserver(2).log (55.7 KB)
Gerente TI Infra
Tel: +556137995051
Are you sure you are running tomcat as the tomcat user? Look to see who owns the default working directory
Ian
Ian Turton
Hi Ian… thanks for response.
Yes… user tomcat, group tomcat…
Is a mistery…750 permissions (tested with 777 too… 755…)… but, not resolve…
Em seg., 6 de dez. de 2021 13:20, Ian Turton <ijturton@anonymised.com> escreveu:
Ian
On Mon, 6 Dec 2021 at 15:44, Mauricio Vieira Cardoso Filho <mcardoso@anonymised.com> wrote:
Gerente TI Infra
Tel: +556137995051
---------- Forwarded message ---------
De: Mauricio Vieira Cardoso Filho <mcardoso@anonymised.com>
Date: dom., 5 de dez. de 2021 às 17:48
Subject: Help please!!!
To: <claudius.ptolomaeus@anonymised.com>
Best regards.
Gerente TI Infra
Tel: +556137995051
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ian Turton
HI Mauricio,
Based on description, it seems like you have a situation like this:
https://gis.stackexchange.com/questions/366331/geoserver-2-17-1-war-running-on-tomcat-9-not-finding-geoserver-data-dir-context
(on which Ian also suggested: try using different path separators).
Anyway, what it’s interesting about that thread in particular it’s that ChrisP (who created the question) also commented which was the solution
https://gis.stackexchange.com/a/366416
“…After adding LOCAL SERVICE with read/write permissons GeoServer was able to find and use the new data directory specified in web.xml correctly…”
Maybe that would help you
Regards
Jose
On Mon, Dec 6, 2021 at 1:45 PM Mauricio Vieira Cardoso Filho <mcardoso@anonymised.com> wrote:
Ian
Gerente TI Infra
Tel: +556137995051
Best regards.
Gerente TI Infra
Tel: +556137995051
Ian Turton
Hello,
I had the same problem last week (Debian Bullseye 11, Tomcat 9.4.03)
In my case it was about Tomcat permission ReadWritePaths parameter, it need to be added with new GEOSERVER_DATA path to tomcat service unit, for ex.:
'ReadWritePaths=/geoserver/home_data/data/'
--check your tomcat settings
# systemctl cat tomcat9.service
--add parameter ([Service] + parameter) and save
# systemctl edit tomcat9.service
[Service]
--It created file
/etc/systemd/system/tomcat9.service.d/override.conf
--reload
# systemctl daemon-reload
--check if parameter is there
ReadWritePaths=/etc/tomcat9/Catalina/
ReadWritePaths=/var/lib/tomcat9/webapps/
ReadWritePaths=/var/log/tomcat9/
[Install]
WantedBy=multi-user.target
# /etc/systemd/system/tomcat9.service.d/override.conf
[Service]
--restart tomcat
# systemctl stop tomcat9.service
# systemctl start tomcat9.service
Maybe it is not fully correct procedure, but it works for me. You can see more how to configure it here
https://www.2daygeek.com/linux-modifying-existing-systemd-unit-file/
milan
On 06.12.2021 17:34, Mauricio Vieira Cardoso Filho wrote:
Hi Ian... thanks for response.
Yes.. user tomcat, group tomcat...
Is a mistery...750 permissions (tested with 777 too.. 755...).. but, not resolve...
Em seg., 6 de dez. de 2021 13:20, Ian Turton <ijturton@anonymised.com <mailto:ijturton@anonymised.com>> escreveu:
    Ian
        Gerente TI Infra
        Tel: +556137995051
        <mailto:mcardoso@anonymised.com>;
        De: *Mauricio Vieira Cardoso Filho* <mcardoso@anonymised.com
        Subject: Help please!!!!
        <mailto:claudius.ptolomaeus@anonymised.com>>
        Dear, I have a problem on the geoserver, which I've been
        trying to solve for 5 days and I can't find any kind of solution.
        I can't make the server read the data directory I point to.
        anywhere).
        I've already tried to insert the path in the tomcat9.service
        I don't know what else to look at here. Any guidance,
        Best regards.
        Gerente TI Infra
        Tel: +556137995051
        - Earning your support instead of buying it, but Ian Turton:
        http://www.ianturton.com/talks/foss4g.html#/
        - The GeoServer user list posting guidelines:
        http://geoserver.org/comm/userlist-guidelines.html
        this:
        <mailto:Geoserver-users@lists.sourceforge.net>
    -- Ian Turton
- Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html
