[Geoserver-users] Help Required to Configure Sqlite Database
I would consider using GeoPackage http://docs.geoserver.org/latest/en/user/community/geopkg/index.html instead of SpatiaLite. No dll-hell with installation. For converting Spatialite db into GeoPackage you can use GDAL. GeoPackege works otherwise well as data source but as far as I know the driver is missing support for r-tree spatial index which means that with big tables and small bounding boxes it is much slower than it could be.
-Jukka Rahkonen-
I need a help for how to configure sqlite database in geoserver, while go through geoserver usermanual and followed the steps but no positive result.
Tried the below points:
  1. Copied spatialite libraries in geoserver/webapps/lib folder
  2. Then copied the supporting library files (DLL ) files into windows/system32 folder.
  3. But only Spatialie JNDI option enabled for creating new store.
  4. Configured the JNDI connection in apache tomcat server, but no positive result.
Thanks
Kamaal.m
Senior Software Engineer
CYIENT Ltd
DISCLAIMER:
This email message is for the sole use of the intended recipient(s) and may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message. Check all attachments for viruses before opening them. All views or opinions presented in this e-mail are those of the author and may not reflect the opinion of Cyient or those of our affiliates.
