[Geoserver-users] Help setting GEOWEBCACHE_CACHE_DIR properly
   Disregard my prior message, I missed Arne's note... Same applies for
GEOWEBCACHE_CACHE_DIR.
Jim
Jim Meyer
Java Programmer
ConceptSolutions, LLC
    We Make Business Intelligent
703.889.8434 [desk]
703.391.9041[fax]
www.Concept-Solutions.com
-----Original Message-----
[mailto:jim.meyer@anonymised.com]
Sent: Wednesday, August 12, 2009 10:17 AM
To: 'Arne Kepp'
Subject: Re: [Geoserver-users] Help setting GEOWEBCACHE_CACHE_DIR properly
   For glassfish, that link references... GEOSERVER_DATA_DIR is that the
same parameter as GEOWEBCACHE_CACHE_DIR?
Jim
Jim Meyer
Java Programmer
703.889.8434 [desk]
703.391.9041[fax]
Sent: Wednesday, August 12, 2009 9:56 AM
To: jim.meyer@anonymised.com
Ah... Glassfish.
http://docs.geoserver.org/1.7.x/en/user/data-directory/data-dir-setting.html
Same applies for GEOWEBCACHE_CACHE_DIR
-Arne
jim.meyer@anonymised.com wrote:
   I "grepped" in the glashfish logs directory for DefaultStorageFinder
and
messages there stating...
   *** Reverting to java.io.tmpdir /var/tmp//geowebcache
   In the Geoserver logs, I am seeing this message...
   Found no usable default cache prefixes !!! Please set
GEOWEBCACHE_CACHE_DIR if you would like a specific location
Jim
Jim Meyer
Java Programmer
703.889.8434 [desk]
703.391.9041[fax]
Sent: Wednesday, August 12, 2009 5:20 AM
I downloaded a fresh copy of the -bin version of GeoServer 1.7.4 and set
GEOWEBCACHE_CACHE_DIR in web.xml. This works, the log says
12 Aug 11:10:25 INFO [storage.DefaultStorageFinder] - Found System
environment variable GEOWEBCACHE_CACHE_DIR set to /home/ak/temp, using
it as the default prefix.
and I end up with the tiles and H2 database in the intended location.
Please check:
Do the log say anything ? Look for storage.DefaultStorageFinder
Did you restart the entire container after changing web.xml ?
Is the path writable for the container user ?
Are you sure the directive is not surrounded by comment tags (<!-- and
-Arne
Hello Arne,
   We are using Version 1.7.4. Any ideas? We are using the embedded
version of geowebcache.
Jim
Jim Meyer
Java Programmer
703.889.8434 [desk]
703.391.9041[fax]
Sent: Tuesday, August 11, 2009 11:24 AM
properly
Please include what version of GeoServer you are using?
-Arne
Hello,
   We have tried setting the GEOWEBCACHE_CACHE_DIR web.xml property to
a directory on my UNIX server.
   Even with this property set, GeoServer seems to be placing the
cache in /var/tmp/geowebcache.
   Is there are way to actually change that location?
Jim
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus
on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
Geoserver-users mailing list
