I can't get my "Or" filter working. Here's what I
want to use:
<ogc:Filter>
<ogc:Or>
<ogc:PropertyIsLike wildCard="*" escape="\"
singleChar="?">
<ogc:PropertyName>fename</ogc:PropertyName>
<ogc:Literal>I-*</ogc:Literal>
</ogc:PropertyIsLike>
<ogc:PropertyIsEqualTo>
<ogc:PropertyName>fetype</ogc:PropertyName>
<ogc:Literal>Hwy</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Or>
</ogc:Filter>
Unfortunately, it's not working. Each of these
filters work fine by themselves. But using "Or"
causes only one of them to be rendered (the
"PropertyIsEqualTo" is used, regardless of the order).
There are no errors in the log file - and I'm set to
FINEST.
Any suggestions on what I'm doing wrong? I'm running
this on geoserver 1.3.0-RC6 and pulling Tiger data out
of PostGIS.
Todd
The only "dumb question" is the one you were too afraid to ask.
________________________________________
Check out RouteRuler - Free software for runners, cyclists, walkers, etc.
http://routeruler.sourceforge.net
Get a handle on your data with "pocOLAP", the "little" OLAP project
http://pocolap.sourceforge.net
Yahoo! DSL – Something to write home about.
Just $16.99/mo. or less.
dsl.yahoo.com
Hi Todd,
I experimented with some SLD filters using an "or" filter to try and replicate your problem. Unfortunatley I could not. Here is what I did, I would suggess you try following similar steps to see if it works.
I setup the following SLD Rule:
<Rule>
<ogc:Filter>
<ogc:Or>
<ogc:PropertyName>state_name</ogc:PropertyName>
<ogc:Literal>Illinois</ogc:Literal>
<ogc:PropertyIsLike wildCard="*" escape="\" singleChar="?">
<ogc:Literal>N*</ogc:Literal>
</ogc:Or>
</ogc:Filter>
<PolygonSymbolizer>
<Fill>
<CssParameter name="fill">#FF0000</CssParameter>
</Fill>
</PolygonSymbolizer>
</Rule>
Using it to query the states layer it worked as expected.
Perhaps you can include the rest of your sld document, maybe something else is throwing the filter off.
-Justin
want to use:
<ogc:Filter>
<ogc:Or>
singleChar="?">
</ogc:Or>
</ogc:Filter>
FINEST.
of PostGIS.
Todd
__________________________________________ Yahoo! DSL – Something to write home about. Just $16.99/mo. or less. dsl.yahoo.com
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files
for problems? Stop! Download the new AJAX search engine that makes
searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
