[Geoserver-users] Help with geoserver-gwc resolutions and origin
Dear all,
I am having troubles to configure geowebcache integrated with geoserver 2.0.2. Geoserver is deployed in a Tomcat 6.0.20 in Linux Opensuse 11.1.
My first working wms request is this one: http://druidtest.gmv.es:8084/geoserver/wms?LAYERS=topp%3APO_CC_2007-2008&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fpng&SRS=EPSG%3A4326&BBOX=-8.94,42,-8.428,42.512&WIDTH=256&HEIGHT=256
The gwc demo works for this layer: http://druidtest.gmv.es:8084/geoserver/gwc/demo/topp:PO_CC_2007-2008?gridSet=EPSG:4326&format=image/png.
However, the following wms request (through gwc) fails: http://druidtest.gmv.es:8084/geoserver/gwc/service/wms?LAYERS=topp%3APO_CC_2007-2008&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fpng&SRS=EPSG%3A4326&BBOX=-8.94,42,-8.428,42.512&WIDTH=256&HEIGHT=256&TILED=True
The error obtained is:
"400: Requested horizontal resolution: 0.001999999999999995 , best match: 0.001373291015625 exceeds 10% threshold. Perhaps the client is configured with an incorrect set of scales (resolutions), or the DPI setting is off compared to the one in GWC ?"
I have checked the posts in the lists with similar problems, so I tried to solve it defining my custom configuration file with the resolution values that I got from the openlayers source code of the demo, assuming that these should be ok. I changed the bounds in the request for them to match as well: http://druidtest.gmv.es:8084/geoserver/gwc/service/wms?LAYERS=topp%3APO_CC_2007-2008&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fpng&SRS=EPSG%3A4326&BBOX=-8.793,42.031,-8.029,42.816&WIDTH=256&HEIGHT=256&TILED=True
This time I obtained this error:
* 400: X,Y values for the tile index were calculated to be {243.49439999999998, 187.77742222222224} which had to be rounded to {243, 188} and exceeds the threshold of 10%. Perhaps the client is using the wrong origin ?
The demo still works here with the new configured GridSubset: http://druidtest.gmv.es:8084/geoserver/gwc/demo/topp:PO_CC_2007-2008?gridSet=The%20Entire%20World&format=image/png
Could somebody point me in the right direction?.
Why should it work in the demos (OpenLayers) and not with a simple WMS query? I copy below the content of the geowebcache.xml config file.
Thanks in advance.
Héctor.
<?xml version="1.0" encoding="utf-8"?>
<gwcConfiguration xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
                  xsi:noNamespaceSchemaLocation="http://geowebcache.org/schema/1.2.2/geowebcache.xsd&quot;
                  xmlns="http://geowebcache.org/schema/1.2.2&quot;&gt;
  <version>1.2.2</version>
  <gridSets>
    <gridSet>
      <name>The Entire World</name>
      <srs><number>4326</number></srs>
      <extent>
        <coords>
          <double>-180.0</double>
          <double>-90.0</double>
          <double>180.0</double>
          <double>90.0</double>
        </coords>
      </extent>
      <alignTopLeft>false</alignTopLeft>
      <resolutions>
           <double>0.703125</double>
           <double>0.3515625</double>
           <double>0.17578125</double>
           <double>0.087890625</double>
           <double>0.0439453125</double>
           <double>0.02197265625</double>
           <double>0.010986328125</double>
           <double>0.0054931640625</double>
           <double>0.00274658203125</double>
           <double>0.001373291015625</double>
           <double>6.866455078125E-4</double>
           <double>3.4332275390625E-4</double>
           <double>1.71661376953125E-4</double>
           <double>8.58306884765625E-5</double>
           <double>4.291534423828125E-5</double>
           <double>2.1457672119140625E-5</double>
           <double>1.0728836059570312E-5</double>
           <double>5.364418029785156E-6</double>
           <double>2.682209014892578E-6</double>
           <double>1.341104507446289E-6</double>
           <double>6.705522537231445E-7</double>
           <double>3.3527612686157227E-7</double>
           <double>1.6763806343078613E-7</double>
           <double>8.381903171539307E-8</double>
           <double>4.190951585769653E-8</double>
           <double>2.0954757928848267E-8</double>
      </resolutions>
      <levels>20</levels>
      <metersPerUnit>111226.31</metersPerUnit>
      <tileHeight>256</tileHeight>
      <tileWidth>256</tileWidth>
    </gridSet>
  </gridSets>
  <!-- ============================== LAYERS ============================================== -->
  <layers>
    <wmsLayer>
      <name>topp:PO_CC_2007-2008</name>
      <mimeFormats><string>image/png</string><string>image/jpeg</string></mimeFormats>
      <gridSubsets>
        <gridSubset>
          <gridSetName>The Entire World</gridSetName>
          <extent>
            <coords>
              <double>-8.793</double>
              <double>42.031</double>
              <double>-8.029</double>
              <double>42.816</double>
            </coords>
          </extent>
          <zoomStart>9</zoomStart>
          <zoomStop>18</zoomStop>
        </gridSubset>
      </gridSubsets>
      <wmsUrl><string>http://druidtest.gmv.es:8084/geoserver/wms&lt;/string&gt;&lt;/wmsUrl&gt;
      <wmsLayers>topp:PO_CC_2007-2008</wmsLayers>
      <errorMime>application/vnd.ogc.se_xml</errorMime>
      <wmsVersion>1.1.1</wmsVersion>
      <transparent>true</transparent>
      <queryable>true</queryable>
    </wmsLayer>
  </layers>
</gwcConfiguration>
______________________
This message including any attachments may contain confidential
information, according to our Information Security Management System,
and intended solely for a specific individual to whom they are addressed.
Any unauthorised copy, disclosure or distribution of this message
is strictly forbidden. If you have received this transmission in error,
please notify the sender immediately and delete it.
Este mensaje, y en su caso, cualquier fichero anexo al mismo,
puede contener informacion clasificada por su emisor como confidencial
en el marco de su Sistema de Gestion de Seguridad de la
Informacion siendo para uso exclusivo del destinatario, quedando
prohibida su divulgacion copia o distribucion a terceros sin la
autorizacion expresa del remitente. Si Vd. ha recibido este mensaje
erroneamente, se ruega lo notifique al remitente y proceda a su borrado.
Gracias por su colaboracion.
It is hard to make valid tiled WMS requests by hand because the bbox should match exactly the extents of some tile. Naturally it is possible, it's only mathematics, but not any fun after the first success.
Openlayers is generating such requests as well as uDig if you add your GWC as WMSC service for it. Use Firebug or something and you can see and capture working requests sent by Openlayers. With uDig you should be able to see them in uDig logs. Copy and paste those working requests to browser if you want to test them that way.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: Héctor Hugo Pérez Alonso [mailto:hperez@anonymised.com]
Lähetetty: 3. helmikuuta 2011 13:27
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: [Geoserver-users] Help with geoserver-gwc resolutions and origin
Dear all,
Thanks in advance.
Héctor.
  <gridSets>
    <gridSet>
      <extent>
        <coords>
        </coords>
      </extent>
      <resolutions>
      </resolutions>
      <levels>20</levels>
    </gridSet>
  </gridSets>
  <layers>
    <wmsLayer>
      <gridSubsets>
        <gridSubset>
          <extent>
            <coords>
            </coords>
          </extent>
        </gridSubset>
      </gridSubsets>
    </wmsLayer>
  </layers>
</gwcConfiguration>
Special Offer-- Download ArcSight Logger for FREE (a $49 USD value)!
Finally, a world-class log management solution at an even better price-free!
Download using promo code Free_Logger_4_Dev2Dev. Offer expires
February 28th, so secure your free ArcSight Logger TODAY!
http://p.sf.net/sfu/arcsight-sfd2d
Geoserver-users mailing list
Good job figuring out how to define your own grid and looking at the source of the OL client.
But the demo OpenLayers client is automatically generated from the configuration of the layer. They'll always match (or you've found a bug).
If you define a new grid set / layer in XML, a new demo is created to match that grid definition.
You're not saying what client you are trying to use, but you should look at how the working demo client is configured and copy those settings to your client.
-Arne
ps. Don't post to both geowebcache-users and geoserver-users. Pick one, if you don't get a reply in a few days you can post to the other. Otherwise you're likely to make someone answer a question that has already been answered.
On 2/3/11 12:27 PM, Héctor Hugo Pérez Alonso wrote:
Dear all,
Thanks in advance.
Héctor.
   <gridSets>
     <gridSet>
       <extent>
         <coords>
         </coords>
       </extent>
       <resolutions>
       </resolutions>
       <levels>20</levels>
     </gridSet>
   </gridSets>
   <layers>
     <wmsLayer>
       <gridSubsets>
         <gridSubset>
           <extent>
             <coords>
             </coords>
           </extent>
         </gridSubset>
       </gridSubsets>
     </wmsLayer>
   </layers>
</gwcConfiguration>
