[Geoserver-users] How filters(in YAML or SLD files style) are proccessed by Geoserver?
Hi geoserver-community,
My name is David, this is my first post in the list and I feel curious about how SLD styling works in Geoserver. I am styling some layers using YSLD files and I am using filters in my rules. These filters look like this:
title: projects
feature-styles:
  • rules:
  • filter: ${ Attribute1 = ‘Value A’ AND status = ‘Ok’}
    symbolizers:
  • point:
    symbols:
  • mark:
    shape: circle
    fill-color: ‘#0000FF’
I have lots of similar rules and the statement Attribute1 = ‘Value A’ never changes.
I have used the following way for working with variables:
define: &attribute_name ${Attribute1 = ‘Value A’}
title: projects
feature-styles:
  • rules:
  • filter: *attribute_name
  • filter: ${status = ‘Ok’}
    symbolizers:
  • point:
    symbols:
  • mark:
    shape: circle
Would you know if Geoserver process these two types of styling in the same way? I mean, needs Geoserver to import the data twice when I use two filters in my rule instead of compounding the statements in only one filter?
The next thing may it be related or not but, I have tried to compare the SLD version using the Rest API(Geoserver version 2.10.2), and I couldn’t be able to get the SLD version of my style:
http://localhost:8080/geoserver/rest/resource/workspaces/myworkspace/styles/yaml_file_example.sld
Even though I am able to download the yaml version(native extension of the style) using the Rest API, I can not get the SLD (transformed) version of the style. I have the following answer from Geoserver:
Undefined resource path.
(However, I am able to get the SLD and YAML version of the example styles of Geoserver)
Thank a lot,
David
Deutsche Telekom IT GmbH
Technology Solution
David Lopez Villegas
GIS-mobile
Oberkasseler Strasse 2, 53227 Bonn, Germany
+49 228 18149623 (Phone)
E-Mail: david-lopez.villegas@anonymised.com
Internet: www.telekom.com
Life is for sharing.
You can find the obligatory information on www.telekom.com/compulsory-statement-dtit
Big changes start small – conserve resources by not printing every e-mail.
Notice: This transmittal and/or attachments may be privileged or confidential. It is intended solely for the addressee named above. Any dissemination, or copying is strictly prohibited. If you received this transmittal in error, please notify us immediately by reply and immediately delete this message and all its attachments. Thank you.
the rules here are a bit complex. In general GeoServer tries to make a single query per layer to the data source by combining in OR the various filters.
However, some data sources report errors or have very poor performance with large/complex filters, so there is a hard-coded limit
of 20 combined filters to be sent to the database, if we go above, only the BBOX filter is sent and all other filtering happens in memory.
This limit rarely needs tweaking so it’s not exposed in the UI or configuration, but if you need to change it, you can set a system
variable, servlet variable, or environment variable to alter it. It’s called MAX_FILTER_RULES.
For example, a system variable given to the JVM running GeoServer would look like this:
-DMAX_FILTER_RULES=50
On Tue, Apr 25, 2017 at 5:28 PM, <David-Lopez.Villegas@anonymised.com> wrote:
title: projects
feature-styles:
  • rules:
    symbolizers:
  • point:
    symbols:
  • mark:
    shape: circle
title: projects
feature-styles:
  • rules:
    symbolizers:
  • point:
    symbols:
  • mark:
    shape: circle
Thank a lot,
David
Technology Solution
GIS-mobile
E-Mail: david-lopez.villegas@anonymised.com180…de
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
