[Geoserver-users] How to disable Geoserver gdal extension
Have a small issue that I hope someone may be able to help with.
I am running Geoserver.war and Myapp.war both under an instance of Jetty.
Myapp requires the use of gdal occasionally but fails with:
Native library load failed.
java.lang.UnsatisfiedLinkError: Native Library C:\Program Files
(x86)\GDAL\gdaljni.dll already loaded in another classloader
This happens at gdal.AllRegister(), it seems that GeoServer has already
consumed gdal at startup. I have the gdal installation in my path.
I have tried to remove the jars that make up the equivalent of the gdal
extension plugin, but Geoserver produced some other errors and did not
startup.
I have also tried to remove gdal from the path and try to load it through
the Myapp application code but ran into some other dependency issues.
Another approach was to force Myapp to consume gdal at startup instead of
calling it as needed later in the execution, then somehow get Jetty to start
Myapp before Geoserver - but not sure how to get Jetty to fix the startup
order sequence. Seen some other posts about that problem.
Q: Is there a way to prevent Geoserver from consuming this native library so
that Myapp can use it instead ? I do not need to use the gdal extensions for
Geoserver. Alternatively, is there a way to share the gdal natives ?
Thank you.
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-to-disable-Geoserver-gdal-extension-tp4643713p4643713.html
please read below…
startup.
which geoserver version are you using?
Did you remove imageio-ext-gdal** from WEB-INF/lib? Which errors is throwing?
Please, let me know.
Daniele
Thank you.
This SF email is sponsosred by:
Try Windows Azure free for 90 days Click Here
http://p.sf.net/sfu/sfd2d-msazure
Geoserver-users mailing list
Ing. Daniele Romagnoli
Software Engineer
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://it.linkedin.com/in/danieleromagnoli
Thank you for your note.
I am running Geoserver 2.1.3 under Jetty 8.0.4 on Win 7
After removing the gt-imageio-ext-gdal-2.7.4 I get multiple startup errors
that include these messages in between jetty errors, and Geoserver fails to
run.
org.geotools.factory.FactoryRegistry scanForPlugins
WARNING: Can't load a service for category "GridFormatFactorySpi". Cause is
"NoC
lassDefFoundError: org/geotools/coverageio/gdal/jp2ecw/JP2ECWFormatFactory".
Caused by:
java.lang.IllegalArgumentException: Cannot find class
[org.geotools.coverageio.g
dal.BaseGDALGridFormat]
Caused by:
java.lang.ClassNotFoundException:
org.geotools.coverageio.gdal.BaseGDALGridFormat
Thank you.
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-to-disable-Geoserver-gdal-extension-tp4643713p4644917.html
please, try to restore the gt-imageio-ext-gdal geotools jar on WEB-INF/lib and try to remove the low level imageio-ext-gdal** only.
WEB-INF/lib changes
Keep it:
gt-imageio-ext-gdal-2.7.4.jar
Remove it:
imageio-ext-gdal-bindings-1.4.5b.jar
imageio-ext-gdal***-1.0.8.jar
Best Regards,
Daniele
run.
WARNING: Can’t load a service for category “GridFormatFactorySpi”. Cause is
“NoC
lassDefFoundError: org/geotools/coverageio/gdal/jp2ecw/JP2ECWFormatFactory”.
Caused by:
Caused by:
Thank you.
Software Engineer
Thank you.
I removed the 13 files and now Geoserver starts up without error.
Gdal extensions have been disabled and the new data source show a reduced
raster selection.
I tested Myapp and the gdal functions can now run successfully.
Thank you very much Daniele.
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-to-disable-Geoserver-gdal-extension-tp4643713p4645195.html
