[Geoserver-users] How to filter raster data (geotiff format) using geoserver?
Hello. I am GIS Newbie.
I am currently publishing satellite images as layers in geotiff format.
And I am requesting it in wms and displaying it on openlayers.
I want to filter by giving a range of pixel values.
For example, if the layer has values from 1 to 1000, I would like to filter values from 50 to 200.
I tried using the cql filter, but the result was not displayed.
Is there a way to filter raster data using geoserver?
Is there any good way to do this?
Thank you.
If you are only requesting it via WMS, then should you not just 'style' your layer in such a way that you only show 50-200 (and make the rest 100% transparent)?
See
https://docs.geoserver.org/stable/en/user/styling/sld/reference/rastersymbolizer.html
for more information about 'styling' your rasters.
I'm not sure what the status is of the sld-export of rasterdata of QGIS, but for vector I often style the layer in QGIS and then export it to sld, to have at least a starting point or some usefull (color) snippets. But as said: I'm not sure if this is handy for rasters, as I do not now if there is good raster-style-export-to-sld ...
Richard Duivenvoorde
If you are just starting out I highly recommend looking into css styling. It’s much easier than sld. The extension is very easy to install.
https://docs.geoserver.org/stable/en/user/styling/css/cookbook/index.html
Vee
On Sun., Jun. 28, 2020, 4:10 a.m. Richard Duivenvoorde, <rdmailings@anonymised.com> wrote:
If you are only requesting it via WMS, then should you not just ‘style’ your layer in such a way that you only show 50-200 (and make the rest 100% transparent)?
See
for more information about ‘styling’ your rasters.
I’m not sure what the status is of the sld-export of rasterdata of QGIS, but for vector I often style the layer in QGIS and then export it to sld, to have at least a starting point or some usefull (color) snippets. But as said: I’m not sure if this is handy for rasters, as I do not now if there is good raster-style-export-to-sld …
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
