[Geoserver-users] How to include WMS layer?
How to include WMS layer as base layer in my layer group?
Madhuri
View this message in context: http://old.nabble.com/How-to-include-WMS-layer--tp30296394p30296394.html
Ciao Madhuri,
I guess you are referring to WMS cascading.
That is available only on 2.1.x aka trunk. You can grab a nightly
build and test it.
Ciao,
Simone.
Notice that our office phone number has recently changed!
Please, update your records!
Ing. Simone Giannecchini
Founder
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
mob: +39 333 8128928
http://twitter.com/simogeo
On Wed, Nov 24, 2010 at 1:33 PM, Madhuri k <life.madhuri@anonymised.com> wrote:
Madhuri
Increase Visibility of Your 3D Game App & Earn a Chance To Win $500!
Tap into the largest installed PC base & get more eyes on your game by
optimizing for Intel(R) Graphics Technology. Get started today with the
Intel(R) Software Partner Program. Five $500 cash prizes are up for grabs.
http://p.sf.net/sfu/intelisp-dev2dev
Geoserver-users mailing list
Hi Ciao,
Thanks for replying.
I have developed map for a city. I want to add world map as a base layer to
the map I have developed. how can I do this?
Madhuri
Simone Giannecchini wrote:
Ciao Madhuri,
build and test it.
Ciao,
Simone.
Founder
fax: +39 0584962313
http://www.linkedin.com/in/simonegiannecchini
Madhuri
grabs.
View this message in context: http://old.nabble.com/How-to-include-WMS-layer--tp30296394p30308890.html
Hello,
I guess you must be using Open Layers.
For making the layer as a base use the following in your open layer code
  var political = new OpenLayers.Layer.WMS("layer name",
            "http://demo.opengeo.org/geoserver/wms&quot;,
            {'layers': 'layer name', transparent: true, format:
'image/gif'},
            {isBaseLayer: true}.
Hope this may help you
Regards
Aditya Kumar
Geo Spatial Application Developer
Madhuri k wrote:
Hi Ciao,
to the map I have developed. how can I do this?
Madhuri
Ciao Madhuri,
build and test it.
Ciao,
Simone.
Founder
fax: +39 0584962313
wrote:
Madhuri
grabs.
grabs.
View this message in context: http://old.nabble.com/How-to-include-WMS-layer--tp30296394p30308893.html
Hi
I am just starting to look at GeoWebCache (I'm with Geoserver-2.0.2) and see from the documentation that you can use Parameter Filters to handle CQL filters set by the client - which is just what I need. But the documentation is incomplete and refers the reader to the comprehensive configuration example and the XSD documentation. The configuration example also says TODO and there are no details. I cannot find relevant XSD documentation. Could anyone kindly give me some pointers?
Many thanks
Alan Hale
have a look at
https://github.com/GeoWebCache/geowebcache/blob/1.1.2/geowebcache/src/main/resources/geowebcache.xml
-Arne
On 11/26/10 3:24 PM, Alan Hale wrote:
Hi
Many thanks
Alan Hale
Increase Visibility of Your 3D Game App& Earn a Chance To Win $500!
Tap into the largest installed PC base& get more eyes on your game by
Many thanks Arne
So, if I understand correctly, I have to construct my own geowebcache.xml which will include details of any layer for which I wish to call GWC, and place under data_dir/gwc/.
Can I assume that (in <floatParameterFilter>) the <values> entries are optional? My values can be any one of over 6000 decimal numbers. In fact, am I expecting too much of GWC to cope with this in any case?
Regards
Alan
On 26/11/2010 15:03, Arne Kepp wrote:
have a look at
-Arne
Hi
Many thanks
Alan Hale
__________ Information from ESET Smart Security, version of virus signature database 5651 (20101126) __________
The message was checked by ESET Smart Security.
http://www.eset.com
Yes, you'll have to construct a configuration file. Make sure you give layers new names, otherwise you'll have a hard time finding errors.
If you want a wildcard filter you should use the regular expression filter, and set it up for the types of numbers your backend supports.
Note that GWC currently provides no facilities for seeding or removing tiles that use such filters.
-Arne
On 11/28/10 10:58 AM, Alan Hale wrote:
Many thanks Arne
Can I assume that (in<floatParameterFilter>) the<values> entries are
Regards
Alan
have a look at
-Arne
Hi
Many thanks
Alan Hale
grabs.
http://www.eset.com
Thank you Arne
I'm not sure I understand the second point. My filter looks like this: "specid=x" where x is a decimal value from one of over 6000 possibilities. They are all of the same format. I assume "specid" is entered within the <key> element tags.
Alan
-Arne
Many thanks Arne
Regards
Alan
have a look at
-Arne
Hi
Many thanks
Alan Hale
grabs.
http://www.eset.com
__________ Information from ESET Smart Security, version of virus signature database 5654 (20101127) __________
http://www.eset.com
The key is correct. The floatParameterFilter tries to avoid duplicates, but in order to do so it needs to know all the possible values*.
A regexParameterFilter just treats the numbers as a text, and matches it againt a pattern. So it doesn't need to know the 6000 values in advance.
-Arne
*: If you code, you know how you never compare floating point numbers directly, you just check that the difference is sufficiently small? This is the same idea.
On 11/28/10 12:53 PM, Alan Hale wrote:
Thank you Arne
entered within the<key> element tags.
Alan
-Arne
Many thanks Arne
Regards
Alan
have a look at
-Arne
Hi
handle
relevant
Many thanks
Alan Hale
Arne - thank you so much. Now I understand.
Alan
-Arne
Thank you Arne
Alan
-Arne
Many thanks Arne
Regards
Alan
have a look at
-Arne
Hi
handle
relevant
Many thanks
Alan Hale
__________ Information from ESET Smart Security, version of virus signature database 5656 (20101128) __________
http://www.eset.com
I'm still having trouble with this, so testing out with a simpler dataset. I can get the unfiltered data to display,but I can't get the filter to work.
This is the layer definition in my OpenLayers init() function:
var sppfilter = "taxa_taxon_list_id=3";
   // create WMS tetrads layer - individual species can be filtered on
   var wmstetrads = new OpenLayers.Layer.WMS(
            "Tetrads",
             "http://www.alanhale.co.uk:8080/geoserver/gwc/service/wms&quot;,
            {'layers': 'indicia_test:detail_occurrences', 'CQL_FILTER':sppfilter,'format':'image/png', 'transparent':'true'},
            {'opacity': 0.6, 'isBaseLayer': false, 'visibility': true}
And here is my parameterFilter in geowebcache.xml:
<parameterFilters>
<regexParameterFilter>
<key>taxa_taxon_list_id</key>
<defaultValue>1</defaultValue>
<regex>^(.+)$</regex>
</regexParameterFilter>
</parameterFilters>
Grateful for any further guidance
Alan
-Arne
Thank you Arne
Alan
-Arne
Many thanks Arne
Regards
Alan
have a look at
-Arne
Hi
handle
relevant
Many thanks
Alan Hale
http://www.eset.com
The key is CQL_FILTER in this case, "taxa_taxon_list_id=3" is the value (after URL encoding).
Check, using Firebug or something similar, that it is indeed sent as uppercase to the server.
-Arne
filter to work.
             "Tetrads",
<parameterFilters>
</parameterFilters>
Alan
values*.
advance.
-Arne
Thank you Arne
Alan
-Arne
Many thanks Arne
wish
Regards
Alan
have a look at
-Arne
Hi
handle
comprehensive
relevant
Many thanks
Alan Hale
http://www.eset.com
Oracle to DB2 Conversion Guide: New IBM DB2 features make compatibility easy.
Learn about native support for PL/SQL, new data types, scalar functions,
improved concurrency, built-in packages, OCI, SQL*Plus, data movement tools,
best practices and more - all designed to run applications on both DB2 and
Oracle platforms. http://p.sf.net/sfu/oracle-sfdev2dev
Thanks Arne
So, I have changed geowebcache.xml to look like this:
<parameterFilters>
<key>CQL_FILTER</key>
<defaultValue>taxa_taxon_list_id=1</defaultValue>
</parameterFilters>
and the request looks like this:
http://www.alanhale.co.uk:8080/geoserver/gwc/service/wms?LAYERS=indicia_test%3Adetail_occurrences&CQL_FILTER=taxa_taxon_list_id%3D3&FORMAT=image%2Fpng&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=-747655.7288,6443946.7458,-434569.661,6757032.8136&WIDTH=256&HEIGHT=256
But the filter does not work. I guess I am missing something obvious.
Regards
Alan
-Arne
filter to work.
             "Tetrads",
<parameterFilters>
</parameterFilters>
Alan
values*.
advance.
-Arne
Thank you Arne
Alan
-Arne
Many thanks Arne
wish
Regards
Alan
have a look at
-Arne
Hi
handle
comprehensive
relevant
Many thanks
Alan Hale
http://www.eset.com
__________ Information from ESET Smart Security, version of virus signature database 5672 (20101203) __________
http://www.eset.com
