After building the plugin by: mvn clean install -P netcdf
It seems to be build in the path: geoserver/src/extension/netcdf/target/gs-netcdf-2.24-SNAPSHOT.jar
Afterwards, I copy gs-netcdf-2.24-SNAPSHOT.jar to the path: geoserver/src/web/app/target/geoserver/WEB-INF/lib
Now after mvn jetty:run, the plugin is still not available in geoserver.
Would you please inform me what I should do?
Best regards,
Amirhossein Nikfal
jive
August 1, 2023, 2:33pm
2
Have a look at the pom.xml for web/app - you can see different profiles that add a dependencies for the different extensions and community modules.
You need to add a profile for your community module.
The alternative approach is to make a new web app, which is what I do for my customers.
There is some documentation in the developers guide
https://docs.geoserver.org/latest/en/developer/programming-guide/ows-services/implementing.html
Jody
Jody Garnett
You need to add the dependencies too. The release configuration tells you what they are. See https://github.com/geoserver/geoserver/blob/main/src/release/ext-netcdf.xml
Or you can just do the release build and install per the geoserver manual instructions.
Brad
Actually I was following the link below to include “netcdf” extension in the build:
https://docs.geoserver.org/latest/en/developer/maven-guide/index.html#building-extensions
I thought it should be straightforward according to the documents. It is interesting that after the compilation, the section below is added to the “Raster data sources”:
" org.geoserver.catalog.testreader.CustomFormat - Test custom coverage format - only visible with test jars in the classpath"
I wanted to make a small change to the netcdf plugin to make it support some other file suffixes besides “.nc”.
Brad
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
