Dear all,
I'm running geoserver 2.18.5 on tomcat and I can't make it work properly.
I can login as admin or any other registered user, but I can't navigate inside the geoserver GUI. If I try to save any modification (on workspace, layer, settings, ...) I receive a 400 error.
A similar issue has been discussed in the link below but without the ability to save any change I can't test the suggested solution:
https://stackoverflow.com/questions/66526411/geoserver-advice-please-http-status-400-bad-request
My (test) geoserver instance is available here: https://ears.bmdc.be/geoserver/
You'll see that it is not possible to navigate in the preview layer. I have the same error with geoserver 2.19.2.
I don't get any error message in the log.
Any suggestion?
Many thanks,
Nicolas de Ville
Belgian Marine Data Centre (BMDC)
OD-Nature, Royal Belgian Institute of Natural Sciences
02/627.42.79
www.bmdc.be
https://metadata.naturalsciences.be/
Dear,
For the record, I solved my issue with the correct definition of of the CSRF white list parameter in the web.xml file.
It was enable but with an error in it and the log doesn't give clues about it.
Hope this help!
Nicolas de Ville
On 19/10/2021 11:24, Nicolas De Ville de Goyet wrote:
Dear all,
https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fstackoverflow.com%2Fquestions%2F66526411%2Fgeoserver-advice-please-http-status-400-bad-request&data=04|01|ndeville%40naturalsciences.be|705f4c9e26b54c1d208508d992f8ad89|4da8d35db472419c9e15665786aadbfb|0|0|637702419584449021|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|3000&sdata=VynPA7h7RPkXHS0tSxwg1GFqhZHDMV%2Bi5WE6FRixJjY%3D&reserved=0
My (test) geoserver instance is available here: https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fears.bmdc.be%2Fgeoserver%2F&data=04|01|ndeville%40naturalsciences.be|705f4c9e26b54c1d208508d992f8ad89|4da8d35db472419c9e15665786aadbfb|0|0|637702419584449021|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|3000&sdata=jKh4Bm0irvkTp0pkm4ZDTNauqwk2rh4R0jxPQdbwERs%3D&reserved=0
Any suggestion?
Many thanks,
Nicolas de Ville
02/627.42.79
www.bmdc.be
Thanks for coming back and sharing the solution with the community!
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
