after I moved Geoserver's data directory Geoserver is not starting
anymore. When trying to access the Geoserver web interface I get an 503
error.
The GEOSERVER_DATA_DIR is pointing to the correct location. Owner and
Access rights stayed the same. My OS is Linux. It seems that there is a
problem with GWC. In the logfile I see the error (full log message at
the end)
java.lang.IllegalStateException: Could not locate a layer or layer group
with id LayerInfoImpl--fd40ab5:166e9af110c:-273f within GeoServer
configuration, the GWC configuration seems to be out of synch
There is a configuration like this in the gwc-layers folder. And that
points to a layer that does not exists anymore. My question is, as the
web interface is not starting and thus I can't really change anything
via API, can I safely delete this folder? The documentation [1] states
that these files should not be edited by hand, but does not state if
it's safe to delete them. Or could I even empty the whole gwc-layers folder?
Kind regards,
Steffen
[1]
https://docs.geoserver.org/stable/en/user/geowebcache/config.html#configuration-files
-- 8< --- 8< --- 8< --- 8< --- 8< --- 8< --- 8< --- 8< --- 8< --- 8< --
The full log message - I added line breaks for better readability and
snipped all the jar paths:
WARN [support.XmlWebApplicationContext] - Exception encountered during
context initialization - cancelling refresh attempt:
org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'geopkgGetMapOutputFormat' defined in URL [..]:
Cannot resolve reference to bean 'webMapService' while setting
constructor argument; nested exception is
Error creating bean with name 'wmsService2': FactoryBean threw exception
on object creation; nested exception is
bean with name 'wmsServiceInterceptor_CachingWMS' defined in URL [..]:
Cannot resolve reference to bean 'cachingWebMapService' while setting
bean property 'advice'; nested exception is
bean with name 'cachingWebMapService' defined in URL [..]:
Cannot resolve reference to bean 'gwcFacade' while setting constructor
bean with name 'gwcFacade' defined in URL [..]:
Cannot resolve reference to bean 'DiskQuotaMonitor' while setting
bean with name 'DiskQuotaMonitor' defined in URL [..]:
Invocation of init method failed; nested exception is
