[Geoserver-users] IIS and geoserver
Hi Users,
I have a .net application on IIS 7 server (port 80) and a Geoserver on Apache Tomcat 6 (port 8080). I would like to make IIS default Web Server and add Apache and GeoServer as secondary web server. Is anybody up there who had the same experience and can provide me some hints. I need to mention that in my application I used GeoExt and Openlayers for visualizing the maps.
Manouchehr
You can use the AJP13 ISAPI filter to setup tomcat behind IIS. Here's more info:
http://tomcat.apache.org/connectors-doc-archive/jk2/jk/iishowto.html
With this solution you're able to access tomcat/geoserver also on port 80.
Best regards,
Sjoerd Brandsma
CycloMedia
On Wed, Nov 9, 2011 at 11:15 AM, Amini, Manouchehr
<Manouchehr.Amini@anonymised.com> wrote:
Hi Users,
the maps.
Manouchehr
RSA(R) Conference 2012
Save $700 by Nov 18
Register now
http://p.sf.net/sfu/rsa-sfdev2dev1
Geoserver-users mailing list
Hi Users,
Manouchehr
We use this solution for our servers. On Windows 2008 R2 we have tried Application Reqest Routing but there were some problems. With AJP we don't have that problem.
Met vriendelijke groet,
Lucas Heezen
Covadis b.v.
t: 026 3616600
Geograaf 12
f: 026 3612317
6921 EW Duiven
e: heezen@anonymised.com
-----Oorspronkelijk bericht-----
Van: Sjoerd Brandsma [mailto:sbrandsma@anonymised.com]
Verzonden: woensdag 9 november 2011 11:57
Aan: Amini, Manouchehr
CC: geoserver-users@lists.sourceforge.net
Onderwerp: Re: [Geoserver-users] IIS and geoserver
Best regards,
Sjoerd Brandsma
CycloMedia
On Wed, Nov 9, 2011 at 11:15 AM, Amini, Manouchehr <Manouchehr.Amini@anonymised.com8...> wrote:
Hi Users,
on
Manouchehr
Save $700 by Nov 18
Register now
Save $700 by Nov 18
Register now
Hi Lucas,
Thanks for your response. I installed AJP (isapi_redirector) on tomcat following the steps given in http://tomcat.apache.org/connectors-doc/webserver_howto/iis.html. How should I set the workers.properties and uriworkermap.properties? It seems that IIS recognizes the tomcat and isapi_redirection is initialized.
Manouchehr
-----Original Message-----
From: Lucas Heezen - Covadis [mailto:heezen@anonymised.com]
Sent: Mittwoch, 9. November 2011 13:25
To: Sjoerd Brandsma; Amini, Manouchehr
Subject: RE: [Geoserver-users] IIS and geoserver
Lucas Heezen
Covadis b.v.
t: 026 3616600
Geograaf 12
f: 026 3612317
6921 EW Duiven
Best regards,
Sjoerd Brandsma
CycloMedia
Hi Users,
on
Manouchehr
Save $700 by Nov 18
Register now
Save $700 by Nov 18
Register now
Your uriworkermap.properties should look something like this:
/your.external.ip.address/geoserver/*=tomcat
/127.0.0.1/geoserver/*=tomcat
/*.your.hostname.com/geoserver/*=tomcat
your workers.properties shoud looke something like this:
/* ajp13 port should match the one you configured in tomcat */
worker.tomcat.port=9401
worker.tomcat.host=127.0.0.1
worker.tomcat.type=ajp13
Best regards,
Sjoerd Brandsma
CycloMedia
On Mon, Nov 14, 2011 at 8:46 AM, Amini, Manouchehr
Hi Lucas,
Manouchehr
Lucas Heezen
Covadis b.v.
t: 026 3616600
Geograaf 12
f: 026 3612317
6921 EW Duiven
Best regards,
Sjoerd Brandsma
CycloMedia
On Wed, Nov 9, 2011 at 11:15 AM, Amini, Manouchehr <Manouchehr.Amini@anonymised.com698...> wrote:
Hi Users,
on
Manouchehr
Save $700 by Nov 18
Register now
Save $700 by Nov 18
Register now
Save $700 by Nov 18
Register now
Hi Sjoerd,
Thank you for the tips. It works fine now
Best regards,
Manouchehr
From: Sjoerd Brandsma [mailto:sbrandsma@anonymised.com]
Sent: Montag, 14. November 2011 10:09
To: Amini, Manouchehr
Cc: Lucas Heezen - Covadis; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] IIS and geoserver
Best regards,
Sjoerd Brandsma
CycloMedia
On Mon, Nov 14, 2011 at 8:46 AM, Amini, Manouchehr <Manouchehr.Amini@anonymised.com8...> wrote:
Hi Lucas,
Manouchehr
Lucas Heezen
Covadis b.v.
t: 026 3616600
Geograaf 12
f: 026 3612317
6921 EW Duiven
Best regards,
Sjoerd Brandsma
CycloMedia
Hi Users,
on
Manouchehr
Save $700 by Nov 18
Register now
Save $700 by Nov 18
Register now
Save $700 by Nov 18
Register now
