Dear fellows,
Following https://docs.geoserver.org/2.19.x/en/user/community/imagemosaic-jdbc/index.html:
The “Image Mosaic JDBC” plugin for Geoserver version 2.22 is not available. In fact it is not available for versions 2.20 and higher.
Best,
Amir Nikfal
quoting from another thread:
the imagemosaic-jdbc plugin has been removed from the GeoServer source code,
after years without a dedicated maintainer.
See the full answer on a similar thread.
https://sourceforge.net/p/geoserver/mailman/geoserver-users/thread/61ddb27d-9187-bde0-34ae-48700befa703%40meggsimum.de/#msg37377981
Ian Turton
So what are we supposed to do for adding a Postgis raster data store?
According to docs, “Image Mosaic JDBC” plugin was necessary for such a task.
On Wed, Apr 5, 2023 at 5:13 PM Ian Turton <ijturton@anonymised.com.84…> wrote:
On Wed, 5 Apr 2023 at 16:09, Amirhossein Nikfal <ah.nikfal@anonymised.com> wrote:
Dear fellows,
Best,
Amir Nikfal
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ian Turton
support the module with time or cash. That’s the way open source works I’m afraid
Ian
Ian Turton
Read and apply this guide: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-fixes,-improvements-and-new-features-in-GeoServer
(pretty much what Ian already said, but a few with more details).
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
