[Geoserver-users] ImageMosaic Footprint Causing Black Lines At Borders
Hi Everyone,
I am using footprints in image mosaic plug-in to mask out NODATA regions as transparent. However, I noticed that between borders of images that got mosaicked together, there are black lines. The black lines move as I zoom in and if I zoom in far enough, the black lines will completely disappear along the border. Is this a rendering problem? Also, if I use footprint inset of a couple pixels, the black lines go away too completely at all zoom levels.
Danny
On Wed, Nov 12, 2014 at 7:49 PM, Danny Cheng <dcheng@anonymised.com>
wrote:
Hi Everyone,
zoom levels.
Which version are you using?
Reminds me of an issue in 2.6.0 that got recently fixed
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I am using 2.5.2 right now.
Danny
On Wed, Nov 12, 2014 at 7:49 PM, Danny Cheng <dcheng@…3836…> wrote:
Hi Everyone,
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Nov 12, 2014 at 9:33 PM, Danny Cheng <dcheng@anonymised.com>
Ok... in that case it does not ring a bell.
Any chance you can share a (small) dataset to reproduce the issue?
If so please open a ticket at http://jira.codehaus.org/browse/GEOS and
attach the data there (or link it).
Ing. Andrea Aime
@geowolf
Technical Lead
I have opened a JIRA issue with datasets for you to use to reproduce the problem.
http://jira.codehaus.org/browse/GEOS-6760
I made a note in the JIRA description, but please ignore any compression artifacts within the footprints.
Danny
Ok… in that case it does not ring a bell.
Ing. Andrea Aime
@geowolf
Technical Lead
