On 05/17/2011 12:50 PM, christian.mueller@anonymised.com wrote:
Quoting Mario Cavicchi <cavicchi@anonymised.com>:
Mario, you should stay on the mailing list, this mail was sent only to me.
Sorry for my error, I wrong the to press reply. Now I send on mailing list.
I talked about the xml file where you specify the database mappings, the
connection params and the coverage name and type.
My configuration files are like in the tutorial (more or less):
mainfile.xml:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<!DOCTYPE ImageMosaicJDBCConfig [
<!ENTITY mapping PUBLIC "mapping" "mapping.oracle.xml.inc">
<!ENTITY connect PUBLIC "connect" "connect.oracle.xml.inc">]>
<config version="1.0">
<coverageName name="classified"/>
<coordsys name="EPSG:32633"/>
<scaleop interpolation="1"/>
<verify cardinality="false"/>
&mapping;
&connect;
</config>
mapping.oracle.xml.inc:
<connect>
<dstype value="DBCP"/>
<username value="geoserver" />
<password value="password" />
<jdbcUrl value="jdbc:oracle:thin:@localhost:1521:geoserver" />
<driverClassName value="oracle.jdbc.OracleDriver"/>
<maxActive value="10"/>
<maxIdle value="0"/>
</connect>
connect.oracle.xml.inc:
<spatialExtension name="oracle"/>
<mapping>
<masterTable name="mosaic" >
<coverageNameAttribute name="name"/>
<maxXAttribute name="maxX"/>
<maxYAttribute name="maxY"/>
<minXAttribute name="minX"/>
<minYAttribute name="minY"/>
<resXAttribute name="resX"/>
<resYAttribute name="resY"/>
<tileTableNameAtribute name="TileTable" />
<spatialTableNameAtribute name="SpatialTable" />
</masterTable>
<tileTable>
<blobAttributeName name="data" />
<keyAttributeName name="location" />
</tileTable>
<spatialTable>
<geomAttributeName name="GEOM" />
<tileMaxXAttribute name="maxX"/>
<tileMaxYAttribute name="maxY"/>
<tileMinXAttribute name="minX"/>
<tileMinYAttribute name="minY"/>
</spatialTable>
</mapping>
I want to have a look at it to figure out a possible solution.
Christian
From my point of view, I would be nice if I can add the tag "timeAttributeName" ( or something) in the tileTable and, in the query to geoserver, I can specify a time range (start datetime, end datetime).
And finally, would be very nice add an option to gt-imagemosaic-jdbc.jar with option import to specify to acquisition date/time of the tiles imported.
Thanks and regards,
Mario Cavicchi
MEEO S.r.l.
Via Saragat 9
I-44122 Ferrara, Italy
Tel: +39 0532 1861501
Fax: +39 0532 1861637
http://www.meeo.it
"ATTENZIONE:le informazioni contenute in questo messaggio sono
da considerarsi confidenziali ed il loro utilizzo è riservato unicamente
al destinatario sopra indicato. Chi dovesse ricevere questo messaggio
per errore è tenuto ad informare il mittente ed a rimuoverlo
definitivamente da ogni supporto elettronico o cartaceo."
"WARNING:This message contains confidential and/or proprietary
information which may be subject to privilege or immunity and which
is intended for use of its addressee only. Should you receive this
message in error, you are kindly requested to inform the sender and
to definitively remove it from any paper or electronic format."
