[Geoserver-users] ImageMosaic location - URLs?
Based on my experimenting with this, and the limited documentation/search results I could find, I think I know the answer to this, but before I give up I wanted to just ask.
I have some data that I have in an ImageMosaic store that I want to retrieve with WCS. I’ve configured the layers to use a PostGIS database to store the file information. I have the location field pointing to files I have in a test directory for a few granules, and I am able to make the WCS requests I need for those files. However, this is only a small sample of the data; right now, the data files are located in an external location that I can access via FTP calls.
Is it possible to set up a configuration anywhere to allow the “location” field in the database to have URI values instead of filesystem path values, whether it be a built in configuration or a custom plugin (that I might need to write)? Or is local filesystem the only possibility? I’d prefer not to have to store the data in two different places, if possible (partly because there’s a LOT of data; basically, daily data files).
As always, thanks in advance!
Scott Lewis
NSIDC
I just did this yesterday. I followed the first two links in the index for COG documentation:
https://docs.geoserver.org/main/en/user/community/cog/index.html
The most relevant lines in indexer.properties are:
Cog=true
CanBeEmpty=true
I also chose to pre-populate granules, and define a layer afterwards. This helped with calculating the proper extent:
UseExistingSchema=true
Using a remote S3 bucket, however, is much too slow for such a large number of granules (~1000).
I will look for a local storage solution and mosaic indexing.
If your tiles are indexed by time, this might be a workable solution. However, for a horizontally tiled mosaic using remotely stored tiles might not be practical.
Scott Lewis
NSIDC
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
"remotely"is the key word here… the server GeoServer is running on must be in the same cloud, and in the same “region” of the cloud, as the bucket
its accessing, to get decent performance.
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
