Hi List,
I’m converting an ImageMosaic index from Oracle to PostGIS, but am having a problem.
My datastore.properties:
SPI=org.geotools.data.postgis.PostgisNGDataStoreFactory
host=example.com
port=5432
database=osmm
schema=example_schema
user=
passwd=
max\ connections=50
min\ connections=1
Fetch\ size=1000
Loose\ bbox=true
Estimated\ extends=false
validate\ connections=true
Connection\ timeout=60
preparedStatements=true
But when I try and get GeoServer to build the index, I’m getting the below exception (end of mail for full exception). It’s saying: “Schema ‘AP’ already exists”, except:
a) The schema isn’t AP, it’s example_schema. The table-name is AP.
b) While the table AP does exist, I get the same error even if it doesn’t exist, or if I change case.
The other heading section is:
20 Apr 15:58:21 INFO [org.geotools.gce.imagemosaic] - Stopping requested at file 1 of 3938 files
20 Apr 15:58:21 WARN [org.geotools.gce.imagemosaic] - Failure occurred while collecting the granules
org.apache.commons.io.DirectoryWalker$CancelException: Operation Cancelled
Does anyone have any thoughts?
Jonathan
20 Apr 15:58:21 ERROR [class org.geotools.gce.imagemosaic.Utils] - Schema ‘AP’ already exists
java.lang.IllegalArgumentException: Schema ‘AP’ already exists
at org.geotools.jdbc.JDBCDataStore.createSchema(JDBCDataStore.java:735)
at org.geotools.jdbc.JDBCDataStore.createSchema(JDBCDataStore.java:144)
at org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog.createType(GTDataStoreGranuleCatalog.java:554)
at org.geotools.gce.imagemosaic.catalog.CachingDataStoreGranuleCatalog.createType(CachingDataStoreGranuleCatalog.java:103)
at org.geotools.gce.imagemosaic.RasterManager.createStore(RasterManager.java:1263)
at org.geotools.gce.imagemosaic.ImageMosaicReader.createCoverage(ImageMosaicReader.java:1125)
at org.geotools.gce.imagemosaic.ImageMosaicConfigHandler.updateConfiguration(ImageMosaicConfigHandler.java:830)
at org.geotools.gce.imagemosaic.ImageMosaicWalker.handleFile(ImageMosaicWalker.java:210)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker$MosaicDirectoryWalker.handleFile(ImageMosaicDirectoryWalker.java:98)
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:367)
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:335)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker$MosaicDirectoryWalker.(ImageMosaicDirectoryWalker.java:114)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker.run(ImageMosaicDirectoryWalker.java:196)
at org.geotools.gce.imagemosaic.Utils.createMosaic(Utils.java:354)
at org.geotools.gce.imagemosaic.Utils.checkSource(Utils.java:1223)
at org.geotools.gce.imagemosaic.ImageMosaicReader.initReaderFromURL(ImageMosaicReader.java:516)
at org.geotools.gce.imagemosaic.ImageMosaicReader.(ImageMosaicReader.java:468)
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:483)
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:103)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1436)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1337)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1332)
at org.geoserver.wms.WMSValidator.validate(WMSValidator.java:44)
at org.geoserver.catalog.impl.CatalogImpl$CatalogValidatorVisitor.visit(CatalogImpl.java:1721)
at org.geoserver.catalog.impl.LayerInfoImpl.accept(LayerInfoImpl.java:239)
at org.geoserver.catalog.impl.CatalogImpl.postValidate(CatalogImpl.java:1672)
at org.geoserver.catalog.impl.CatalogImpl.validate(CatalogImpl.java:693)
at org.geoserver.catalog.impl.CatalogImpl.add(CatalogImpl.java:625)
at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:437)
at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:223)
at org.geoserver.config.DefaultGeoServerLoader.loadCatalog(DefaultGeoServerLoader.java:47)
at org.geoserver.config.GeoServerLoader.reload(GeoServerLoader.java:207)
at org.geoserver.config.GeoServerLoaderProxy.reload(GeoServerLoaderProxy.java:66)
at org.geoserver.config.impl.GeoServerImpl.reload(GeoServerImpl.java:452)
at org.geoserver.web.admin.StatusPage$5.onClick(StatusPage.java:157)
at org.apache.wicket.ajax.markup.html.AjaxLink$1.onEvent(AjaxLink.java:68)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:177)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:300)
at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:119)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:138)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:620)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:76)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1040)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Unknown Source)
at org.apache.commons.io.DirectoryWalker.checkIfCancelled(DirectoryWalker.java:395)
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:368)
