[Geoserver-users] ImagePyramid plugin and interpolation method
Hi
I'm not able to set a layer specific interpolation method (the one in the publishing tab of the layer) when using the image pyramid plugin (didn't try other raster stores): The standard interpolation method choosen in the the drop down is ignored and it uses the interpolation method set in the Services-WMS menu. Is this on purpose?
regards
Stefan
Mit freundlichem Gruss
Stefan Ziegler
Leiter amtliche Vermessung
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
032 627 75 96
On Sat, Aug 27, 2011 at 2:25 PM, Ziegler Stefan <Stefan.Ziegler@anonymised.com> wrote:
Hi
Ah, that panel only affects WCS, does not have anything to do with WMS.
Controlling interpolation on a per layer basis in WMS... hmmm... would
not be easy if
there is more than one raster in the same map.
I guess it could be a new feature. It would require changes in the
GeoServer configuration,
GUI, rendering setup code, and Geotools rendering subsystem. It's
likely that it needs
funding to be implemented.
regards
Stefan
Stefan Ziegler
Rötistrasse 4
4501 Solothurn
032 627 75 96
EMC VNX: the world's simplest storage, starting under $10K
The only unified storage solution that offers unified management
Up to 160% more powerful than alternatives and 25% more efficient.
Guaranteed. http://p.sf.net/sfu/emc-vnx-dev2dev
Geoserver-users mailing list
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
