How can I raise the logging level, I need to make some settings in Geoserver?
I read Raster Data Optimization — GeoServer Training.
](https://geoserver.geo-solutions.it/edu/en/enterprise/raster.html)
I understand well that for 23 Gbyte Geotiff and ImagePyramid don’t make difference?
Thanks.
Joe
On Monday, June 3, 2019, 3:43:34 PM GMT+3, Daniele Romagnoli daniele.romagnoli@anonymised.com wrote:
Any chance to raise the logging level and see if some more explicit message get reported?From that line of code it looks like the granule loading is unable to setup any raster image.
Daniele
On Mon, Jun 3, 2019 at 10:29 AM vizes dzso via Geoserver-users <geoserver-users@lists.sourceforge.net> wrote:
Geoserver run on Linux (Debian 9.3) Geoserver version 2.12.2 .
On Monday, June 3, 2019, 10:40:35 AM GMT+3, Russ Hore <russ@anonymised.com> wrote:
It is worth replying to the list so everybody knows what you have tried.
Are you on Linux/Windows?
Russ
On 3 Jun 2019, at 08:23, vizes dzso <vizes_dzso@anonymised.com> wrote:
Thanks Russ.
I check the path and path is OK. Something else not working.
Joe
On Monday, June 3, 2019, 10:16:54 AM GMT+3, Russ Hore <russ@anonymised.com> wrote:
Have you checked the path to the files?
Failed to load granule file:/home/mapbender/pyramid/0/sfgh_001_001.tif
Russ
On 3 Jun 2019, at 07:21, vizes dzso via Geoserver-users <geoserver-users@anonymised.comurceforge.net> wrote:
Hello,
I have a big 27Gbytes Geotif. I load it and publish, cached layer ect. and works.
I like to try as ImagePyramid.
From QGIS I made pyramids with gdal_retile.
Create a ImagePyramid Store. No problem, next screen shows available layers to publish within the store. When I click on a layer to publish, it gives:
See attachment (Error.txt)
<imagepyramid_publish.txt>_______________________________________________
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
