[Geoserver-users] Images and Pyramid problems
Hi, I’m working with GeoServer (via WMS) and OpenLayers on my work, when I add the NavigationControl to the OpenLayers.Map the images don’t display…
I try these things:
-Add the css (I copy it from GeoServer preview)
-Add my own Images.
But I cant display it.
Other problem that I’ve is with the ImagePiramid plugin, I follow all the tutorials that I found but I can’t make it work.
I’ve always this exception:
Could not list layers for this store, an error occurred retrieving them:
Unable to acquire a reader for this coverage with format: ImagePyramid.
If someone has a solution, please I’ll appreciate it.
Regards.
TSU. Amador Cuenca
Are you certain that you have the image pyramid extension enabled in the version of geoserver running?
On 10-06-16 6:24 PM, Amador Antonio Cuenca wrote:
Hi, I'm working with GeoServer (via WMS) and OpenLayers on my work, when
I add the NavigationControl to the OpenLayers.Map the images don't
display...
I try these things:
-Add my own Images.
Other problem that I've is with the ImagePiramid plugin, I follow all
the tutorials that I found but I can't make it work.
I've always this exception:
If someone has a solution, please I'll appreciate it.
Regards.
TSU. Amador Cuenca
ThinkGeek and WIRED's GeekDad team up for the Ultimate
GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the
lucky parental unit. See the prize list and enter to win:
http://p.sf.net/sfu/thinkgeek-promo
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
