| Hi, I’ve created a image pyramid using gdal_retile.py, following the tutorial. When creating a new store, using the image pyramid plug-in, I keep getting the message: “Could not list layers for this store, an error occurred retrieving them: This plugin accepts only File, URL and String pointing to a file” The directory structure of the url of the connection parameter is pointing to (file:data/art_pyramid) consists of 4 dirs, ‘0’ to ‘4’, each containing the tif files and a prj, shp, dbf and shx file. I’ve try changing file permissions, change the location, etc. geoserver 2.0.2 tomcat 6.0.20 debian squeeze Thanks! |
Hi Erwin,
there are few things you can provide us with in order to help you:
you can check out geoserver log files, and see if there is some more informative error there. Increasing log level in geoserver should help.
can you provide sample of data? (you can send it privately)
Ivan
On Wed, Feb 9, 2011 at 11:56 AM, Erwin Poeze <erwin.poeze@anonymised.com> wrote:
geoserver 2.0.2
tomcat 6.0.20
debian squeeze
Thanks!
The ultimate all-in-one performance toolkit: Intel(R) Parallel Studio XE:
Pinpoint memory and threading errors before they happen.
Find and fix more than 250 security defects in the development cycle.
Locate bottlenecks in serial and parallel code that limit performance.
http://p.sf.net/sfu/intel-dev2devfeb
Geoserver-users mailing list
Ivan Grcic
Software Engineer
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 328 0559267
http://www.youtube.com/user/GeoSolutionsIT
Hi Ivan,
Thanks for your reply. I attached the log file and the directory structure the url in the Connection parameters is pointing to.
I will create a new example which is small enough the send by mail.
Erwin
To: Erwin Poeze erwin.poeze@anonymised.com
Sent: Wed, February 9, 2011 10:23:39 PM
Subject: Re: [Geoserver-users] importing image pyramid fails
Hi Erwin,
Ivan
geoserver 2.0.2
tomcat 6.0.20
debian squeeze
Thanks!
Ivan Grcic
Software Engineer
error_log (43.9 KB)
dir_list (2 KB)
On Thu, Feb 10, 2011 at 8:53 AM, Erwin Poeze <erwin.poeze@anonymised.com4…> wrote:
Hi Ivan,
Ah right right, this is Tomcat breaking the JAI plugin loading mechanism:
java.lang.NoClassDefFoundError: it/geosolutions/imageio/stream/input/FileImageInputStreamExtImpl
at it.geosolutions.imageio.stream.input.spi.FileImageInputStreamExtImplSpi.createInputStreamInstance(FileImageInputStreamExtImplSpi.java:143)
at javax.imageio.ImageIO.createImageInputStream(ImageIO.java:347)
The solution can be found in this blog:
http://geo-solutions.blogspot.com/2010/05/fix-geotools-and-geoserver-not-able-to.html
Ing. Andrea Aime
Tech lead
mob: +39 333 8128928
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Thanks Andrea,
I modified the mentioned line in server.xml to
I error message remains unchanged, but the log is different now. Please find the log file attached.
Erwin
Cc: Ivan Grcic ivan.grcic@anonymised.com; geoserver-users@lists.sourceforge.net
Sent: Thu, February 10, 2011 9:30:52 AM
On Thu, Feb 10, 2011 at 8:53 AM, Erwin Poeze <erwin.poeze@anonymised.com> wrote:
Hi Ivan,
Ing. Andrea Aime
Tech lead
error2.log (45.4 KB)
