I noticed that when you enable the option, a POST request is sent with the form data: tabs:panel:refreshed-values:statistics: on
If you disable the checkbox, the request will be sent without a parameter.
As a result, the server returns a 403 Forbidden error and statistics continue to be collected, and the checkbox becomes enabled again.
It seems to me that when the checkbox is disabled,
tabs:panel:refreshed-values:statistics: off
should be sent, by analogy).
I am aware of GEOSERVER_CSRF_WHITELIST and my domain is added to this list in the web.xml file.
