[Geoserver-users] INSPIRE compliance
Hello list,
I didn't find enough information about the INSPIRE plugin, and I need to know if GeoServer is now INSPIRE compliant for View Service (WMS).
Anyone of you already tried to use GeoServer for a View Service?
Have you tried to validate the services through the INSPIRE geoportal?
Is it possible to create a multilingual, INSPIRE compliant, service with the INSPIRE plugin?
Thank you
Francesco
Hi Francesco,
we are using GeoServer 2.1-SNAPSHOT (including INSPIRE plugin) for our INSPIRE View Service (http://www.statistik.at/gs-inspire/ows?service=wms&version=1.3.0&request=GetCapabilities). We have validated our service with the INSPIRE Resource Tester (http://inspire-geoportal.ec.europa.eu/INSPIREWebServices/) and are already in the INSPIRE Geoportal.
The INSPIRE plugin makes the getCapabilities document INSPIRE conform. There is the section about the languages (supported, default, response language) that is required. As we only support German I am not really deep into that.
Sibylle
Von: Francesco D'Alesio [mailto:francesco.dalesio@anonymised.com]
Gesendet: Donnerstag, 01. Dezember 2011 09:31
An: geoserver-users@lists.sourceforge.net
Betreff: [Geoserver-users] INSPIRE compliance
Hello list,
the INSPIRE plugin?
Thank you
Francesco
All the data continuously generated in your IT infrastructure
contains a definitive record of customers, application performance,
security threats, fraudulent activity, and more. Splunk takes this
data and makes sense of it. IT sense. And common sense.
http://p.sf.net/sfu/splunk-novd2d
Geoserver-users mailing list
_______________________________________________________________________
Die Bundesanstalt Statistik Österreich sowie alle Mitwirkenden an den
beigefügten Unterlagen haben deren Inhalte sorgfältig recherchiert
und erstellt. Fehler können dennoch nicht gänzlich ausgeschlossen
werden. Die Genannten übernehmen daher keine Haftung für die
Richtigkeit, Vollständigkeit und Aktualität der Inhalte, insbesondere
übernehmen sie keinerlei Haftung für eventuelle unmittelbare oder
mittelbare Schäden, die durch die direkte oder indirekte Nutzung der
angebotenen Inhalte entstehen.
Korrekturhinweise übermitteln Sie bitte an die absendende Stelle.
Diese Nachricht ist ausschließlich für die in der Anschrift genannte
Person bestimmt. Sollten Sie dieses E-Mail irrtümlich erhalten haben,
verständigen Sie bitte die absendende Stelle und vernichten Sie
die Nachricht inklusive aller Anhänge. Danke.
Bundesanstalt Statistik Österreich, 1110 Wien, Guglgasse 13
Tel. +43 (1) 71128-0, Fax +43 (1) 71128-7728
E-Mail: office@anonymised.com, Internet: www.statistik.at
Firmenbuch: FN 191155k, Firmenbuchgericht: Handelsgericht Wien
Firmensitz: Wien, Gerichtsstand: Wien, UID: ATU37869909, DVR 0000043
Thanks Sibylle, some additional info from the developer.
The INSPIRE plugin is a great step towards INSPIRE compatibility but you have to do additional configurations. The needed features will be in the next geoserver version 2.1.3, or you can install a nightly build of 2.1.x. With the current release 2.1.2, you can not achieve 100 % INSPIRE compatibility. (According to our experience)
Looking at the documentation
http://docs.geoserver.org/stable/en/user/community/inspire/using.html
I see a link to tutorial at the bottom of the page.
http://location.defra.gov.uk/wp-content/uploads/2011/07/Data-Publisher-How-To-Guide-Setting-up-GeoServer-on-a-Windows-Machine.pdf
@Sibylle, can you cross check this tutorial with our configuration.
Christian
Zitat von SAUL Sibylle <Sibylle.Saul@anonymised.com>:
Hi Francesco,
Sibylle
Hello list,
the INSPIRE plugin?
Thank you
Francesco
This message was sent using IMP, the Internet Messaging Program.
2.1.x nightly builds and trunk is. I've used the test suite provided by Dutch organization Geonovum to verify.
No multilingual services as yet possible though but Inspire does not mandate that.
Also no harmonized layer names but those are due end 2012 IIRC.
Bart
Sent from my iPhone
On Dec 1, 2011, at 12:31 AM, Francesco D'Alesio <francesco.dalesio@anonymised.com..> wrote:
Hello list,
the INSPIRE plugin?
Thank you
Francesco
Hi Bart, we also had headaches about the harmonized layer names. Does it make sense to open a JIRA issue describing the problem ?
The same holds true for multilingual services, but this is only a wish.
Christian
Zitat von Bart van den Eijnden <bartvde@anonymised.com>:
Bart
Sent from my iPhone
On Dec 1, 2011, at 12:31 AM, Francesco D'Alesio <francesco.dalesio@anonymised.com> wrote:
Hello list,
the INSPIRE plugin?
Thank you
Francesco
Hi Christian,
sure it makes sense to open up a JIRA tickets for them and discuss further there.
Justin and Gabriel have already talked about possible solutions for the harmonized layer names, but it is actually quite complicated if I have understood correctly.
Best regards,
Bart
OSGIS - http://osgis.nl
Christian
2.1.x nightly builds and trunk is. I’ve used the test suite provided by Dutch organization Geonovum to verify.
Bart
Sent from my iPhone
On Dec 1, 2011, at 12:31 AM, Francesco D’Alesio <francesco.dalesio@anonymised.com> wrote:
Hello list,
I didn’t find enough information about the INSPIRE plugin, and I need to
the INSPIRE plugin?
Thank you
Francesco
Geoserver-users@anonymised.comists.sourceforge.net
Hi list,
thank you very much for your answers and examples.
The “harmonized layer names” problem means that GeoServer cannot name layers as INSPIRE requires? I think I misunderstood this point.
I’m sorry for this newbie question, but we’re evaluating the feasibility of an INSPIRE project.
Thank you
Francesco
Hi Francesco,
In GeoServer you can change the name of the layer to the harmonized layer name as required by INSPIRE. But in the getCapabilities XML the layer name is always combined with the name of the store. You can’t get rid of the store name: store:harmonized_name…
Sibylle
Von: Francesco D’Alesio [mailto:francesco.dalesio@…4550…]
Gesendet: Freitag, 02. Dezember 2011 09:46
Betreff: Re: [Geoserver-users] INSPIRE compliance
Hi list,
Thank you
Francesco
Il 01/12/2011 16:27, Bart van den Eijnden ha scritto:
Hi Christian,
Best regards,
Bart
Christian
Zitat von Bart van den Eijnden <bartvde@…671…>:
Bart
Sent from my iPhone
On Dec 1, 2011, at 12:31 AM, Francesco D’Alesio <francesco.dalesio@…4550…> wrote:
Hello list,
the INSPIRE plugin?
Thank you
Francesco
Hi Francesco,
Sibylle
Von: Francesco D’Alesio [mailto:francesco.dalesio@anonymised.com]
An: geoserver-users@anonymised.comge.net
Hi list,
Thank you
Francesco
Hi Christian,
Best regards,
Bart
Christian
Bart
Sent from my iPhone
Hello list,
the INSPIRE plugin?
Thank you
Francesco
