Is there a wiki to provide step wise installing process of Geoerver? I will be installing Postgres with PostGIS extension using the following wiki. So I need to install Geoserver and then connect to this Postgres.
The reason I am separately installing Postgres is because I am not able to access the PostGIS 2.4 extension. If I can Install both together, I would appreciate if you could provide that link.
Thanks & Regards
Smaran Harihar
http://docs.geoserver.org/stable/en/user/gettingstarted/postgis-quickstart/index.html
follow the above link
regards,
Imran
On Fri, May 25, 2012 at 8:52 PM, Smaran Harihar <smaran.harihar@anonymised.com> wrote:
Thanks & Regards
Smaran Harihar
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
Geoserver-users mailing list
I.R
No Imran, I do not wish to add a PostGIS table. I am installing the complete Geoserver Open Suite again but last time I installed Open GeoSuite I had issues with the PostGres PostGIS extension. So i will now be installing the complete Postgres with PostGIS using the following wiki on Ubuntu 12.04.
So this what I need,
- Wiki which documents the installation process of OpenGeo Suite with Postgres having PostGIS 2.4 extension for Ubuntu 12.04.
- If there is no wiki for (1) then wiki which documents installation process without Postgres and how can I separetly add the installed Postgres with PostGIS 2.4 extension to Geoserver on Ubuntu 12.04
On Fri, May 25, 2012 at 9:12 AM, Imran Rajjad <rajjad@anonymised.com> wrote:
regards,
Imran
Thanks & Regards
Smaran Harihar
I.R
Thanks & Regards
Smaran Harihar
Just one more question,
- Is it better to install the complete opengeo suite or should I install the geoserver, Postgres with PostGIS 2.4 extension separately?
---------- Forwarded message ----------
From: Smaran Harihar <smaran.harihar@anonymised.com>
Date: Fri, May 25, 2012 at 9:19 AM
Subject: Re: [Geoserver-users] Install Geoserver
To: Imran Rajjad <rajjad@anonymised.com>, geoserver-users <geoserver-users@lists.sourceforge.net>
regards,
Imran
Thanks & Regards
Smaran Harihar
I.R
Thanks & Regards
Smaran Harihar
Thanks & Regards
Smaran Harihar
On Fri, May 25, 2012 at 7:00 PM, Smaran Harihar <smaran.harihar@anonymised.com> wrote:
This mailing list is just about GeoServer, not the OpenGeo suite nor postgis installation.
I believe you’re more likely to get an answer if you ask on the OpenGeo suite own support forum
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
