[Geoserver-users] Installation on server with low memory
i`m installing geoserver in tomcat7 on an Ubuntu 12.04 Server with only 512mb RAM
This all went fine, but now tomcat7 crashes even before geoserver can be started. Simply a matter of memory.
I have set the max/min PermGen to 512 and Xms /Xmx also to 512.
Is there any possible way to run geoserver on so little memory?
thanks for any tips or tricks
Robert
Hi Robert,
Refer to
http://docs.geoserver.org/stable/en/user/production/index.html
regards,
Imran
On Thu, Oct 4, 2012 at 11:06 AM, Robert Buckley
<robertdbuckley@anonymised.com> wrote:
512mb RAM
Robert
Don't let slow site performance ruin your business. Deploy New Relic APM
Deploy New Relic app performance management and know exactly
what is happening inside your Ruby, Python, PHP, Java, and .NET app
Try New Relic at no cost today and get our sweet Data Nerd shirt too!
http://p.sf.net/sfu/newrelic-dev2dev
Geoserver-users mailing list
I.R
Thanks for the link.
I am aware of the production environment settings. I also know that it is recommended to use 1gb upwards of RAM.
I was looking for a few tips or tricks regarding running in a sub-optimal environment. I have set tomcat7 JAVA_OPTS as written in the production documentation
but geoserver still crashes after a few seconds.
INFO: validateJarFile(/var/lib/tomcat7/webapps/geoserver/WEB-INF/lib/servlet-api-2.5.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
04 Oct 06:51:29 WARN [config.CustomEditorConfigurer] - Passing PropertyEditor instances into CustomEditorConfigurer is deprecated: use PropertyEditorRegistrars or PropertyEditor class names instead. Offending key [org.geotools.util.Version; offending editor instance: org.geoserver.platform.util.VersionPropertyEditor@anonymised.com
Oct 04, 2012 6:51:30 AM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
04 Oct 06:51:30 ERROR [geoserver.global] -
  • GEOSERVER_DATA_DIR: /home/geoadmin/geoserver_data_dir/data
This the end of catalina.out
maybe there is another issue here.
yours,
Rob
Von: Imran Rajjad rajjad@anonymised.com
An: Robert Buckley robertdbuckley@anonymised.com
CC: “geoserver-users@lists.sourceforge.net” geoserver-users@anonymised.come.net
Gesendet: 8:19 Donnerstag, 4.Oktober 2012
Betreff: Re: [Geoserver-users] Installation on server with low memory
Hi Robert,
Refer to
regards,
Imran
512mb RAM
Robert
Don’t let slow site performance ruin your business. Deploy New Relic APM
I.R
Robert,
first remove every service you do not need, no WPS, no format that you do
not access, only datbases you need try to make the installation as lean as
possible.
Next starting with 128 MB PermGen/MaxPermGen, (may be even 96 MB) and go up
in 32MB steps, if 128 does not suffice. Try to minimise the PermGen. Give as
much as you can to the heap.
There was a link on this list from somebody pointing to:
http://opengeo.org/publications/geoserver-production/
which is a nice summary of geoserver configuration for production.
Then monitor the memory use of the VM :
-Xloggc:somewhere\gc.log
-XX:+PrintGCDetails
I do appreciate the sportsmanship of this attempt to get away with 512 MB
RAM, however, compared to the work involved isn't it cheaper to go to to the
next shop get some RAM and stuff it in the box?
Christian
____________________________
Dr Christian Maul
Project Manager
Information Services Branch
Department of Sustainability and Environment
Level13, Marland House, 570 Bourke Street
Melbourne 3000
PO Box 500, East Melbourne Vic 3002
Telephone: +61-3-8636 2325
Telefax: +61-3-8636 2813
View this message in context: http://osgeo-org.1560.n6.nabble.com/Installation-on-server-with-low-memory-tp5006291p5006518.html
You probably don’t need 512MB for PermGen. If I needed to run GeoServer in 512MB of RAM, I would start by setting JAVA_OPTS like: “-Xmx128M -XX:MaxPermSize=192M” and reducing the size of the Tomcat thread pool (to limit the number of concurrent requests GeoServer will try to serve. You can also do this in a more fine-grained way with the control-flow module:
http://docs.geoserver.org/stable/en/user/extensions/controlflow/index.html, but that would be adding more code and contributing to the pressure on PermGen.)
You can also use JConsole or JVisualVM to keep an eye on memory usage. This is probably most effective if you are also controlling a client, so you can correlate increases in memory consumption with operations (and then configure GeoServer not to offer those operations if you don’t need them.)
http://docs.oracle.com/javase/6/docs/technotes/guides/management/jconsole.html
http://docs.oracle.com/javase/6/docs/technotes/tools/share/jvisualvm.html
Note that both JConsole and JVisualVM can operate through an SSH tunnel, so you don’t need to expend much of the server’s RAM on running them.
David Winslow
OpenGeo - http://opengeo.org/
On Thu, Oct 4, 2012 at 7:22 PM, cmaul <Christian.Maul@anonymised.com> wrote:
Robert,
possible.
-XX:+PrintGCDetails
RAM, however, compared to the work involved isn’t it cheaper to go to to the
Christian
Dr Christian Maul
Project Manager
Melbourne 3000
