GeoServer Users
I recently purchased a newer Lenovo T400 with Windows 7 and am unable to
connect to http://localhost:8080/geoserver
Receive the following error
HTTP ERROR: 404
NOT_FOUND
RequestURI=/geoserver/web/
Powered by jetty://
Anyone have any ideas what the issue is.
The only log files I find is a wrapper.log
STATUS | wrapper | 2010/01/28 20:32:03 | GeoServer 2.0.1 installed.
Jeff Reichman
I had a problem on Windows 7 too. I had to change the permissions on my GeoServer directory in windows for it to work. Don’t know if that is the same problem though.
Jon
On 29 Jan 2010 03:18, “Jeff Reichman” <reichmanj@anonymised.com> wrote:
GeoServer Users
HTTP ERROR: 404
NOT_FOUND
Powered by jetty://
Jeff Reichman
The Planet: dedicated and managed hosting, cloud storage, colocation
Stay online with enterprise data centers and the best network in the business
Choose flexible plans and management services without long-term contracts
Personal 24x7 support from experience hosting pros just a phone call away.
http://p.sf.net/sfu/theplanet-com
Geoserver-users mailing list
What's the content of that log file when you start the Geoserver service? (start menu -> programs -> geoserver -> start)
Iván Sánchez Ortega <ivan@anonymised.com>
Jon,
What did you need to change to get things working on W7? If you're using the Windows installer, and permissions are not being set correctly, please file a JIRA for it, and I'll see what I can do.
Mike Pumphrey
OpenGeo - http://opengeo.org
Jon Britton wrote:
I had a problem on Windows 7 too. I had to change the permissions on my GeoServer directory in windows for it to work. Don't know if that is the same problem though.
Jon
On 29 Jan 2010 03:18, "Jeff Reichman" <reichmanj@anonymised.com <mailto:reichmanj@anonymised.com>> wrote:
GeoServer Users
HTTP ERROR: 404
NOT_FOUND
Powered by jetty://
Jeff Reichman
Geoserver-users@lists.sourceforge.net <mailto:Geoserver-users@lists.sourceforge.net>
ALCON
In a nut shell I had to set the JAVA _HOME and GEOSERVER_HOME environment
variables and also change the Geoserver service variable from "Manual" to
"Automatic." Seems to work now. The wrapper (??) doesn't seem to work
requiring me to double click of the Startup.bat and Shutdown.bat files.
Jeff
-----Original Message-----
Sent: Friday, January 29, 2010 11:38 AM
To: Jon Britton; geoserver-users
Subject: Re: [Geoserver-users] Installing GEOSERVER WINDOWS 7
Jon,
Mike Pumphrey
Jon
GeoServer Users
to connect to http://localhost:8080/geoserver
HTTP ERROR: 404
NOT_FOUND
Powered by jetty://
Jeff Reichman
--------- The Planet: dedicated and managed hosting, cloud storage,
colocation Stay online with enterprise data centers and the best
network in the business Choose flexible plans and management services
without long-term contracts Personal 24x7 support from experience
The Planet: dedicated and managed hosting, cloud storage, colocation Stay
On Fri, Jan 29, 2010 at 4:15 PM, Jeff Reichman <reichmanj@anonymised.com> wrote:
ALCON
If you are using the startup/shutdown files then the service set up
should be irrelevant, Mike?
Ian
Ian Turton
Actually no, surprisingly. The startup/shutdown batch files in the Windows installer are actually different from the .bin flavor, and are generated during the install. For instance, the startup.bat on my (service) install of 2.0.1 has the line:
call "C:\Program Files\GeoServer 2.0.1\wrapper.exe" -t wrapper/wrapper.conf
So, in short, I'm still not quite sure what's going on.
Mike Pumphrey
ALCON
requiring me to double click of the Startup.bat and Shutdown.bat files..
Ian
I just joined this forum and thanks to the hints posts above, I was able to
install GeoServer 2.0.2 on a Windows 7 system this evening.
The problem for me was as follows:
1. The GEOSERVER_HOME environment variable was set by the installer to
"C:\Program Files (x86)\GeoServer 2.0.1" . I changed this to "...\GeoServer
2.0.2" .
2. The JAVA_HOME environment and system variables were pointing to an
earlier update of the Java Runtime Environment. (This was probably my
fault, because I hadn't uninstalled the earlier updates.) I changed the
path to the most recent update from Oracle. [I'm not sure if this was
100% necessary, though.]
3. The "wrapper.log" file was complaining (Fatal Error) that some of the
"dll" files were not accessible, even though they were found where they were
supposed to be. I changed the permissions for the "C:\Program Files
(x86)\GeoServer 2.0.2" folder so that they would be more accessible.
I also set GeoServer to load as a Windows service.
These changes seem to have done the trick. I can now access GeoServer on my
browser.
Howard Yamaguchi
Mike Pumphrey-2 wrote:
Jon,
Mike Pumphrey
View this message in context: http://old.nabble.com/Installing-GEOSERVER-WINDOWS-7-tp27366730p29568574.html
