Thanks for your reply. I’ve attached an openlayers request trace below from the geoserver log, and the URL is:
Let me know when you’ve had a look, I’ll need to firewall the machine again.
Right now it isn’t a drama, since only a few layers are published - but later we need to be able to shift data around with confidence. I’ll try the same procedure on a newer geoserver (2.9.1) today as well. So we can easily republish everything on this particular geoserver, I’d just prefer not to.
re. rsync:
On 6 Jul 2016, at 6:04 PM, Andrea Aime <andrea.aime@...1107...> wrote:
Hi Adam,
this seems really weird, as the error occurs only if the layer could not be found:
https://github.com/geoserver/geoserver/blob/2.7.0/src/web/core/src/main/java/org/geoserver/web/data/resource/ResourceConfigurationPage.java#L110
There is a bug there, the return page is yet not set, but what the code was trying to do was to was to return
you to the layer list page and telling you the layer could not be found.
The layer preview error is basically telling the same story, the particular layer could not be located (do you have by any chance the stack trace
for that one, and the full URL for the openlayers preview?).
There is one thing that I don't understand, but I'm not much of a rsync user... calling this command:
rsync -av /path/to/geoserver/data /path/to/new/place/
Shouldn't it make a copy of the geoserver data directory in "/path/to/new/place/" as opposed to "/path/to/new/place/data"?
On Wed, Jul 6, 2016 at 3:47 AM, Adam Steer <Adam.Steer@...7673...> wrote:
Hi all
I’ve just moved a data directory for a geoserver 2.7.0 install, as follows:
stop tomcat
…constructing ' /path/to/new/place/data’, with the tree still owned by tomcat.
…then I added '/path/to/new/place/data’ to the GEOSERVER_DATA_DIR context parameter in web.xml
…then I restart tomcat.
After the move everything seems to be in place, defined users can log in, data stores and layers are all listed - but I get a Java error whenever I try to view details for a layer:
layers -> click layer name -> org.apache.wicket.WicketRuntimeException: Can't instantiate page using constructor …
If I go to layer preview, clicking an openlayers link results in downloading a bit of XML:
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE ServiceExceptionReport SYSTEM "http://130.56.244.241:80/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd"> <ServiceExceptionReport version="1.1.1" > <ServiceException code="LayerNotDefined" locator="layers">
Could not find layer ITEM:ITEM...
</ServiceException></ServiceExceptionReport>
This seems really similar to an old issue (see https://sourceforge.net/p/geoserver/mailman/message/32008598/), but:
- there was nothing in the layergroups directory
- I can make layergroups from the missing layers, and preview those
I’m by no means a Java ninja - so I’m struggling to decode what the error message and the geoserver log file actually mean - geoserver’s output around the event of clicking a layer name and throwing the Java error is copied below.
Any help is appreciated!
Thankyou
Adam
2016-07-06 11:37:22,329 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-07-06 11:37:22,329 DEBUG [org.geoserver] - Thread 40 locking in mode WRITE
2016-07-06 11:37:22,329 DEBUG [org.geoserver] - Thread 40 got the lock in mode WRITE
2016-07-06 11:37:22,332 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.7.0.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-07-06 11:37:22,333 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.7.0.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-07-06 11:37:22,333 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.7.0.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-07-06 11:37:22,334 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.7.0.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-07-06 11:37:22,334 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.7.0.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-07-06 11:37:22,334 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.7.0.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-07-06 11:37:22,340 DEBUG [org.geoserver] - Thread 40 releasing the lock in mode WRITE
2016-07-06 11:37:22,340 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-07-06 11:37:22,341 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-07-06 11:37:23,319 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-07-06 11:37:23,319 DEBUG [org.geoserver] - Thread 42 locking in mode WRITE
2016-07-06 11:37:23,319 DEBUG [org.geoserver] - Thread 42 got the lock in mode WRITE
2016-07-06 11:37:23,320 ERROR [org.apache.wicket.RequestCycle] - Can't instantiate page using constructor public org.geoserver.web.data.resource.ResourceConfigurationPage(org.apache.wicket.PageParameters) and argument name = "[ITEM_REL_mosaic_1987_2015]" wsName = "[ITEM]"
org.apache.wicket.WicketRuntimeException: Can't instantiate page using constructor public org.geoserver.web.data.resource.ResourceConfigurationPage(org.apache.wicket.PageParameters) and argument name = "[ITEM_REL_mosaic_1987_2015]" wsName = "[ITEM]"
at org.apache.wicket.session.DefaultPageFactory.createPage(DefaultPageFactory.java:212)
at org.apache.wicket.session.DefaultPageFactory.newPage(DefaultPageFactory.java:89)
at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.newPage(BookmarkablePageRequestTarget.java:305)
at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.getPage(BookmarkablePageRequestTarget.java:320)
at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.processEvents(BookmarkablePageRequestTarget.java:234)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:138)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:76)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
at org.apache.coyote.ajp.AjpAprProcessor.process(AjpAprProcessor.java:188)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2522)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2511)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedConstructorAccessor120.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
at org.apache.wicket.session.DefaultPageFactory.createPage(DefaultPageFactory.java:188)
... 107 more
Caused by: java.lang.IllegalArgumentException: Argument page must be not null
at org.apache.wicket.request.target.component.PageRequestTarget.<init>(PageRequestTarget.java:43)
at org.apache.wicket.RequestCycle.setResponsePage(RequestCycle.java:768)
at org.apache.wicket.Component.setResponsePage(Component.java:3248)
at org.geoserver.web.data.resource.ResourceConfigurationPage.<init>(ResourceConfigurationPage.java:113)
at org.geoserver.web.data.resource.ResourceConfigurationPage.<init>(ResourceConfigurationPage.java:92)
... 111 more
2016-07-06 11:37:23,323 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.7.0.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-07-06 11:37:23,323 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.7.0.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-07-06 11:37:23,324 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.7.0.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-07-06 11:37:23,324 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.7.0.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-07-06 11:37:23,324 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.7.0.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-07-06 11:37:23,325 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.7.0.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-07-06 11:37:23,328 DEBUG [org.geoserver] - Thread 42 releasing the lock in mode WRITE
2016-07-06 11:37:23,328 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-07-06 11:37:23,329 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-07-06 11:37:25,919 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-07-06 11:37:25,919 DEBUG [org.geoserver] - Thread 39 locking in mode WRITE
2016-07-06 11:37:25,919 DEBUG [org.geoserver] - Thread 39 got the lock in mode WRITE
2016-07-06 11:37:25,921 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.7.0.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-07-06 11:37:25,922 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.7.0.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-07-06 11:37:25,922 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.7.0.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-07-06 11:37:25,923 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.7.0.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-07-06 11:37:25,923 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.7.0.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-07-06 11:37:25,923 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.7.0.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
Attend Shape: An AT&T Tech Expo July 15-16. Meet us at AT&T Park in San
Francisco, CA to explore cutting-edge tech and listen to tech luminaries
present their vision of the future. This family event has something for
everyone, including kids. Get more information and register today.
http://sdm.link/attshape
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
