[Geoserver-users] Inverted Hartebeeshoek94/lo19 coord system
Hi
I am new to the GIS world, please could you help me out with a problem that i have been struggling to fix an dont understand some of the solutions posted on the mailing list.
I am uploading shapefiles into Geoserver and set the coordinate system to EPSG: 2048 Hartebeeshoek94/Lo19 for the South Africa (Cape Town).
My shapefile negative coordinates, resulting in the features/maps being upside down.
How can i correct this?
Do i need to create my a new EPSG and how?
or is there a simple way of editing the properties of the current EPSG: 2048 Hartebeeshoek94/Lo19 .
Please help me out.
Thank you
Your shapefile should come with a “prj” file, or you can override it with the correct settings as you describe. If EPSG:2048 is not matching your data you should check your data again?
When drawing a map with WMS you can request the map in any coordinate system and GeoServer will figure out what to draw.
You can add your own “epsg” code to GeoServer, but it is very rarely needed:
Check with your data provider before going to such trouble.
Jody Garnett
On Fri, Jun 20, 2014 at 2:03 AM, Keke Malekela <keke.malekela@anonymised.com> wrote:
Hi
Please help me out.
Thank you
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
Geoserver-users mailing list
Hi Keke,
Does the shapefile come with a projection (it will be in the “.prj” file)? Is it 2048? If so GeoServer should pick it up automatically.
Jonathan
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 19 June 2014 17:03, Keke Malekela <keke.malekela@anonymised.com> wrote:
Hi
Please help me out.
Thank you
