這樣 算我剛好有血腥照 不算個懶叫臉
d1grfy39ztai4o.cloudfront.net/sites/default/files/images/membership/benefits/acp-email-sig-master-rgb.png
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4WvVpxjs39JiWs0DlQpEDVPkVE8zWQ_yXGWqg_yEb6vXZ24BowbRPs17KvXc9aKbwA2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4R628Y5kGJdc_10NW9GpxbnhgdGNZ5xMbT1jQXXNPJtTfWjtvy3ThXWoYVLCI27w4w2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4cCq_IplesTWlVAxoy-Qwa-HNYukWA6f5lglWxqhjzsLN40nJWtXRp7PtdrYsRjrJA2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4VkVFopYiUkfc_mv8OKLoAoR909AjIzeIUx9625jzV_yoXv6146rjwe1lJJVLk5wLw2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4R84IGhhWCaLLvo-yKkiNIzGZKZJrKlz1iH2RqD8QWbQLyiBBx7HsvfqPFv1KM9HYw2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4btk7hYWQg1z2kX5nceTBeZl0CLQkuqczRh2CGMVyUH-4i4SvXVCXqKsa-Sqund4EA2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4bKB9i5JcPA7K-SjEXcuPVVVrXzaRGTMZefhtJAvGOh_zYa1TCmaxzxu3qmE3tiZUg2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4accNHXz-lYTJ0NRgvdwv3rDVqRv_U1pjJYM7_07_QhiIWx0Zp-n-gfXbi5Y0t6Lfw2
https://membersuite.aala.org.au/Sys/Profile/PhotoGallery/43401/0/226431?memberId=57474101&dh=24&cppr=0
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4XveGEGMqpC9PNldWuG5ANmeZvBlYhDALnTvm6iu4LT-ulT1E8T_YB2KqDhbT4JycA2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4SzN0476R5hPkVEPdTqOAxxFFbFR4EgPlN7QOlUJPjATmSA-zBgdW12y7WlxWjYZ8w2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4UDQ-nLw95DqsZJ7pTPY6Aq0i-7l-_Su8wILhkl6AgsfQLe5fdN8OQsPzD4bPp9EWQ2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4bXgChfdh9AR9OAygHxsGgXdxfZCPNqwdaL_9of_lRbiPcTwkJMRd4ZG-CCW7Ewh4Q2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4amezH8y5IVXnoHqq2yY0mfBMRVjI6PXuWJyGoPinVNxhy_JWn2aLpz1HmrHwA3EeQ2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4dwBgTDB2jyXS_kePhssCzESNnQRrQh_sjZzo2sVjCwAg5zg-ZiqKieioz_Uog545Q2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4SqvOZfWLrRfNy_78c_wIcXrn5ZuRQpiM2nx_mNeBfUcYciShWD06cT2fO6wCY_MkA2
https:royalairforcesassociation.my.site.comcommunitysmy-details ID:00597651
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4eNGxo-iDlx56HJskPvqiCgSwf09BXS9R6u9s_iz4HlVFpFNCS2VqbU4CKumISoOHA2
在 2024年4月25日 星期四 下午06:13:20 [GMT+8], Armando Forlaniarmando.forlani@anonymised.com 寫道:
Hi Jody,
I’ll have a look at how I can contribute to the doc. This is however a temporary solution as the Windows service method was the easiest way to get this up and running quickly.
Having a user to start the service so that GeoServer has access to the network folders shared with this one user… it’s not really a solution. There must be a way in Windows to somewhat allow folders access to the service itself rather than a particular user (security may be an issue with this).
Having said that, we’ll likely deploy GeoServer as a TomCat servlet (I believe this is the preferred options suggested in the documentation) and setup LDAP logins (as authentication provider) making use of existing AD groups and all that. Am I right to assume GeoServer would see the folders/mapped drives of the user logged into it? Even if GeoServer was started as a service (TomCat webapp)? In other words, does GeoServer delegate shared folder access to Windows through LDAP?
Please note that, although the intention is to couple a database with GeoServer (either Oracle or PostgreSQL), I find the use of GeoPackage files on network folder a really good addition to GeoServer and invaluable to visualise the output of small projects/analyses.
Armando
Sent: 24 April 2024 18:07
To: Armando Forlani Armando.Forlani@anonymised.com
Cc: Andrea Aime andrea.aime@anonymised.com; geoserver-users@anonymised.comts.sourceforge.net
Subject: Re: invisible mapped/share drives in Store creation
So it was an operating system permission issue? if you have guidance to add to the docs it would be appreciated …
Jody Garnett
On Fri, Apr 19, 2024 at 8:20 AM Armando Forlani <Armando.Forlani@anonymised.com978…> wrote:
Hi Andrea and Jody,
I RESOLVED my issue taking clues from this
https://superuser.com/questions/1758898/service-is-not-able-to-access-a-network-drive-mapping-despite-running-under-the
…which led to this:
https://learn.microsoft.com/en-us/answers/questions/1168194/how-run-windows-services-as-the-current-user-when
…and tried a few things but essentially the Windows service has to be started as the user logging in the machine and has access to the shared folders (default is ‘Network Service’):
Go to the Service console via services.msc
Locate the GeoServer service
Set manual start/stop and stop the service
Properties à Log On
Change ‘This account’ value…
Click ‘Browse’ and check only the ‘User’ box in the object type list
Enter ‘<your username>’ in the ‘Enter the object name to select’ and validate it by clicking ‘Check Names’
OK
Start service
Hopefully I was the only one experiencing this issue, but if there are others… this should be of some use.
Armando
Original issue:
I’m creating a new Store using a GeoPackage file as data source (database). It works fine with a gpkg file saved locally i.e. anywhere on the C: drive. I’m unable to make it work with files stored on a share drive, either the full path or a logical drive letter.
file://J:/folder/data.gpkg
Error creating data store, check the parameters. Error message: Unable to obtain connection: path to ‘J:\folder\data.gpkg’: 'J:' does not exist
file:\J:\folder\data.gpkg
file:////DOMAIN.LOCAL/SHARED/shared_folder/folder/data.gpkg
Error creating data store, check the parameters. Error message: Unable to obtain connection: [SQLITE_CANTOPEN] Unable to open the database file (unable to open database file)
file:\\DOMAIN.LOCAL\SHARED\shared_folder\folder\data.gpkg
It is also impossible making use of the ‘Browse…’ link next to the ‘database’ edit box. It won’t list any mapped drives in the drop down list. Only ‘Data directory’, ‘Home directory’, A:, ‘OS Disk (C:)’, D:\ are shown.
Moving data locally is not an option.
Running:
Windows 10 Enterprise
VMware Virtual Platform
Eclipse Adoptium: 17.0.10 (OpenJDK 64-Bit Server VM)
GeoServer 2.24.2 as a Windows service
Any help would be really appreciated.
Armando
This message has been scanned for malware by Forcepoint. www.forcepoint.com
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
