Hi All,
I’m trying to define a Tile Matrix Set for https://www.linz.govt.nz/data/linz-data-service/guides-and-documentation/nztm2000-map-tile-service-schema. But I’m having some trouble trying to set the origin correctly to get the correct WMTS TileMatrixSet TopLeftCorner defined for each TileMatrix entry. I need each zoom level to define TopLeftCorner as the origin of the tile grid i.e 10000000.0 -1000000.0, but when I set the min X = -1000000.0 and max y = 10000000.0 I get a WMTS capabilities document with the following:
https://gist.github.com/palmerj/a8499f4f352556c327dc3fd946347bd2
At the moment I have setup the grid as per this screen shot:
I’ve defined this same grid in other software before, like mapproxy and it’s worked ok.
NZTM:
srs: EPSG:2193
origin: nw
bbox_srs: EPSG:2193
bbox: [-1000000, 3087000, 3327000, 10000000]
res: [8960, 4480, 2240, 1120, 560, 280, 140, 70, 28, 14, 7, 2.8, 1.4, 0.7, 0.28, 0.14, 0.07]
Any help would be greatly received.
Jeremy
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info@…3296…) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
