[Geoserver-users] Issue with Geoserver 2.5 and Oracle SQL View layers
Dear all,
I’ve been working on SQL View layers based on Oracle NG datastore.
I’m currently testing similar layers with a Geoserver 2.5 instance, and i’m facing several issues (tests with Geoserver layer preview):
  • some features are not rendered in WMS for some zooming levels (i clarify that i’m using the default polygon style without any SLD zoom scale rule)
  • some features disappear by moving the map
  • GetFeatureInfo does not seem to work (empty output)
In the past, i was using Geoserver 2.2 for which it was working perfectly.
I’m wondering if;
  • any user is experimenting the same kind of problem with Oracle NG or other of DB datastore?
  • some hints could be provided to better track the source of this problem?
  • or if possibly a bug has been yet identified by developers?
Many thanks in advance for your help,
Emmanuel
Emmanuel Blondel
GIS Consultant
Engineer in Agronomy & Environment
Geographic Information Systems
in Agronomy - Environment - Fisheries
Email: emmanuel.blondel1@anonymised.com - Emmanuel.Blondel@anonymised.com
View my LinkedIn profileView my LinkedIn profile
Hi Emmanuel,
the issue is overall new to me. Just to be sure, are you using 2.5.0 or 2.5.1?
It would be best if you tried the latter
On Wed, Jun 11, 2014 at 6:04 PM, Emmanuel Blondel <emmanuel.blondel1@anonymised.com> wrote:
Dear all,
I’m wondering if;
Emmanuel
Emmanuel Blondel
GIS Consultant
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I think I’ve seen this before using Oracle. I fixed it, but I can’t remember what did the trick! It might be something to do with the Loose BBOX setting - do you have this enabled?
On Wed, Jun 11, 2014 at 9:04 AM, Emmanuel Blondel <emmanuel.blondel1@anonymised.com> wrote:
Dear all,
I’m wondering if;
Emmanuel
Emmanuel Blondel
GIS Consultant
It seems 2.5.0
Exact information is:
  * Version 2.5
  * Révision Git 8cf3edcf5f61db010f7ad3fcb4613e7c0eabeaff
  * Build Date 18-Mar-2014 16:08
  * Version de GeoTools 11.0 (rev fb9a2d3f88315d076523788cb8196ec89bb253f9)
  * Version GeoWebCache 1.5.1 (rev
    1.5.x/64246c20a4ada1c954b17d23b9447408d1c5432f)
Le 11/06/2014 18:20, Andrea Aime a écrit :
Hi Emmanuel,
On Wed, Jun 11, 2014 at 6:04 PM, Emmanuel Blondel <emmanuel.blondel1@anonymised.com <mailto:emmanuel.blondel1@anonymised.com>> wrote:
    Dear all,
    I've been working on SQL View layers based on Oracle NG datastore.
    I'm currently testing similar layers with a Geoserver 2.5
    instance, and i'm facing several issues (tests with Geoserver
    layer preview):
    - some features are not rendered in WMS for some zooming levels (i
    clarify that i'm using the default polygon style without any SLD
    zoom scale rule)
    - some features disappear by moving the map
    - GetFeatureInfo does not seem to work (empty output)
    perfectly.
    I'm wondering if;
    - any user is experimenting the same kind of problem with Oracle
    - some hints could be provided to better track the source of this
    problem?
    - or if possibly a bug has been yet identified by developers?
    Emmanuel
    -- *Emmanuel Blondel*
    GIS Consultant
    <mailto:emmanuel.blondel1@anonymised.com> - Emmanuel.Blondel@anonymised.com
    <mailto:Emmanuel.Blondel@anonymised.com>
    <http://fr.linkedin.com/in/emmanuelblondel1&gt;
    Solutions
    <mailto:Geoserver-users@lists.sourceforge.net>
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea,
Maybe the information below can help?
I have enabled geotools logging in Geoserver, and after doing a layer preview wms request, this is what i get in the log:
2014-06-11 18:48:28,479 DEBUG [org.geotools.jdbc] - Failed to unwrap connection using java 6 facilities
java.lang.AbstractMethodError: org.apache.commons.dbcp.PoolingDataSource$PoolGuardConnectionWrapper.isWrapperFor(Ljava/lang/Class;)Z
     at org.geotools.data.oracle.OracleDialect.unwrapConnection(OracleDialect.java:557)
     at org.geotools.data.oracle.OracleDialect.readGeometry(OracleDialect.java:502)
     at org.geotools.data.oracle.OracleDialect.readGeometry(OracleDialect.java:492)
     at org.geotools.data.oracle.OracleDialect.decodeGeometryValue(OracleDialect.java:455)
     at org.geotools.jdbc.JDBCFeatureReader.next(JDBCFeatureReader.java:314)
     at org.geotools.jdbc.JDBCFeatureReader.next(JDBCFeatureReader.java:74)
     at org.geotools.data.store.ContentFeatureCollection$WrappingFeatureIterator.next(ContentFeatureCollection.java:145)
     at org.geotools.data.store.ContentFeatureCollection$WrappingFeatureIterator.next(ContentFeatureCollection.java:125)
     at org.geotools.feature.collection.BridgeIterator.next(BridgeIterator.java:31)
     at org.geotools.feature.collection.BridgeIterator.next(BridgeIterator.java:18)
     at org.geotools.renderer.lite.StreamingRenderer.drawPlain(StreamingRenderer.java:2516)
     at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:2066)
     at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:837)
     at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:483)
     at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:251)
     at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:123)
     at org.geoserver.wms.GetMap.executeInternal(GetMap.java:509)
     at org.geoserver.wms.GetMap.run(GetMap.java:253)
     at org.geoserver.wms.GetMap.run(GetMap.java:124)
     at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:328)
     at sun.reflect.GeneratedMethodAccessor161.invoke(Unknown Source)
     at java.lang.reflect.Method.invoke(Method.java:483)
     at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
     at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
     at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
     at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
     at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
     at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:61)
     at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:35)
     at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:73)
     at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:54)
     at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:54)
     at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
     at com.sun.proxy.$Proxy26.getMap(Unknown Source)
     at sun.reflect.GeneratedMethodAccessor160.invoke(Unknown Source)
     at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
     at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
     at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
     at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
     at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
     at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
     at javax.servlet.http.HttpServlet.service(HttpServlet.java:618)
     at javax.servlet.http.HttpServlet.service(HttpServlet.java:725)
     at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:301)
     at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
     at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
     at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
     at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
     at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
     at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70)
     at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
     at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
     at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
     at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
     at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
     at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
     at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
     at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
     at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
     at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
     at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
     at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
     at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
     at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
     at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
     at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
     at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
     at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
     at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
     at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
     at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
     at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
     at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
     at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
     at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
     at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219)
     at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
     at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:503)
     at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:136)
     at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:74)
     at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:610)
     at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
     at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:526)
     at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1017)
     at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:652)
     at org.apache.coyote.http11.Http11NioProtocol$Http11ConnectionHandler.process(Http11NioProtocol.java:222)
     at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1575)
     at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1533)
     at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
     at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
     at java.lang.Thread.run(Thread.java:745)
Same log is mentioned in http://comments.gmane.org/gmane.comp.gis.geoserver.user/41561
Could this be related to the issues i've reported?
Another important note: the geoserver in question is deployed on Tomcat 8 / JDK 8. Any advice either if it is suitable for a geoserver 2.5.0 / 2.5.1?
(Many) Thanks in advance
Emmanuel
Le 11/06/2014 18:39, Emmanuel Blondel a écrit :
It seems 2.5.0
  * Version 2.5
Hi Emmanuel,
    Dear all,
    layer preview):
    (i clarify that i'm using the default polygon style without any
    perfectly.
    I'm wondering if;
    problem?
    Emmanuel
    GIS Consultant
    Solutions
Ing. Andrea Aime
@geowolf
Technical Lead
*Emmanuel Blondel*
GIS Consultant
View my LinkedIn profileView my LinkedIn profile <http://fr.linkedin.com/in/emmanuelblondel1&gt;
On Wed, Jun 11, 2014 at 6:59 PM, Emmanuel Blondel <
Andrea,
Normally this happens if you have the oracle driver both in GeoServer
web-inf/lib, and in the web container
shared libs (e.g., tomcat/lib).
Make sure you have it in a single place
You are totally on your own I'm afraid, JDK 8 is not supported, we just
moved to support JDK 7 on the
GeoServer dev series (will become 2.7.x in September). May work, may not.
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks for your prompt and valuable remarks,
I will liaise with colleagues that were recently in charge of deploying this new instance of geoserver:
- to make up your valuable comments about JDK support.
- to check the location of the oracle driver
Thanks again for your support
Emmanuel
Le 11/06/2014 19:08, Andrea Aime a écrit :
On Wed, Jun 11, 2014 at 6:59 PM, Emmanuel Blondel <emmanuel.blondel1@anonymised.com <mailto:emmanuel.blondel1@anonymised.com>> wrote:
    Andrea,
Normally this happens if you have the oracle driver both in GeoServer web-inf/lib, and in the web container
You are totally on your own I'm afraid, JDK 8 is not supported, we just moved to support JDK 7 on the
Ing. Andrea Aime
@geowolf
Technical Lead
*Emmanuel Blondel*
GIS Consultant
Dear Andrea,
I come back to you on this issue, doing some local tests:
- I've set-up a geoserver 2.5.0 with Oracle datastore, based on JDK6 --> The rendering issues i've initially reported disappeared. However i've still the GetFeatureInfo not working.
- then, on your advices, i've moved to 2.5.1 --> the GetFeatureInfo now works perfectly
In conclusion, tests were successfull with the following Tomcat 6 / JDK 6 / Geoserver 2.5.1.
A last question: if existing, could you point me to a JIRA ticket about the GetFeatureInfo issue? Before moving 2.5.1, i've noticed that i had the same issue as reported here http://osgeo-org.1560.x6.nabble.com/Geoserver-puts-wrong-srid-to-the-spatial-filter-query-td5107048.html
Thanks in advance
Emmanuel
Emmanuel
    Andrea,
Ing. Andrea Aime
@geowolf
Technical Lead
*Emmanuel Blondel*
GIS Consultant
*Emmanuel Blondel*
GIS Consultant
On Thu, Jun 12, 2014 at 10:20 AM, Emmanuel Blondel <
Dear Andrea,
works perfectly
/ Geoserver 2.5.1.
Eh, I don't see a specific issue for that unfortunately, so the change be a
by-product of some other fix
Btw, Java 7 is safe to use on 2.5.x, we have several deployments of 2.5.x
and 2.4.x on that JDK, haven't found specific issues with it.
Ing. Andrea Aime
@geowolf
Technical Lead
