[Geoserver-users] Java heap space java.lang.OutOfMemoryError: Java heap space
HI
I have going through geoserver error where geoserver 2.17.2 - getting Java heap space java.lang.OutOfMemoryError: Java heap space . But here we have port 8080 working fine but port 8443 showing below error.
Is there any way to identify the main issue it is related to Tile service issue or connection pool or Java memory issue.
Caused by: java.io.UncheckedIOException: java.io.FileNotFoundException: C:\geoserver-2.17.2-bin\webapps\geoserver\data\gwc\postgis_layer_p\metadata.properties (Access is denied) at org.geowebcache.storage.blobstore.file.FileBlobStore.putLayerMetadata(FileBlobStore.java:669) at org.geowebcache.storage.blobstore.file.FileBlobStore.persistParameterMap(FileBlobStore.java:572) at org.geowebcache.storage.blobstore.file.FileBlobStore.writeFile(FileBlobStore.java:557) at org.geowebcache.storage.blobstore.file.FileBlobStore.put(FileBlobStore.java:477) at org.geowebcache.storage.CompositeBlobStore.lambda$put$6(CompositeBlobStore.java:182) at org.geowebcache.storage.CompositeBlobStore.lambda$readActionUnsafe$20(CompositeBlobStore.java:504) at org.geowebcache.storage.CompositeBlobStore.readFunctionUnsafe(CompositeBlobStore.java:486) at org.geowebcache.storage.CompositeBlobStore.readActionUnsafe(CompositeBlobStore.java:501) at org.geowebcache.storage.CompositeBlobStore.put(CompositeBlobStore.java:182) at org.geoserver.gwc.ConfigurableBlobStore.put(ConfigurableBlobStore.java:225) at org.geowebcache.storage.DefaultStorageBroker.put(DefaultStorageBroker.java:85) at org.geowebcache.layer.TileLayer.saveTiles(TileLayer.java:545) at org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:654) … 115 more Caused by: java.io.FileNotFoundException: C:\geoserver-2.17.2-bin\webapps\geoserver\data\gwc\postgis_layer\metadata.properties (Access is denied) at java.io.FileOutputStream.open0(Native Method) at java.io.FileOutputStream.open(FileOutputStream.java:270) at java.io.FileOutputStream.(FileOutputStream.java:213) at java.io.FileOutputStream.(FileOutputStream.java:162) at org.geowebcache.storage.blobstore.file.FileBlobStore.putLayerMetadata(FileBlobStore.java:665) … 127 more 28 May 16:36:50 INFO [geoserver.wms] - Request: getServiceInfo 28 May 16:36:50 INFO [geoserver.servlets] - OutputStream was successfully aborted. 28 May 16:36:51 INFO [geoserver.wfs] - Request: getServiceInfo 28 May 16:36:58 ERROR [renderer.lite] - Java heap space java.lang.OutOfMemoryError: Java heap space 28 May 16:38:09 INFO [geoserver.servlets] - OutputStream was successfully aborted.
Other error when accessing geoserver layer is attached.
HTTP ERROR 500 Problem accessing /geoserver/web/wicket/bookmarkable/org.geoserver.web.data.layer.LayerPage. Reason: Server Error Caused by: javax.servlet.ServletException: org.springframework.web.util.NestedServletException: Handler dispatch failed; nested exception is java.lang.OutOfMemoryErro at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:168) at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) at org.eclipse.jetty.server.Server.handle(Server.java:505) at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:370) at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:267) at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:305) at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:427) at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:321) at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:159)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1610) at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201) 5/28/24, 11:15 PM Error 500 Server Error https://localhost:8443/geoserver/web/wicket/bookmarkable/org.geoserver.web.data.layer.LayerPage?filter=false 2/3 at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1602) at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:540) at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146)
Vinay K
HTTP ERROR 500 Problem accessing geoserver java heap.txt (21 KB)
Allocate more Java heap space to your container for a start
Graham H
Sent: Wednesday, May 29, 2024 10:09 AM
Subject: [Geoserver-users] Java heap space java.lang.OutOfMemoryError: Java heap space
You don’t often get email from vinay1992geo@anonymised.com. Learn why this is important
HI
Vinay K
There is another error ” java.io.FileNotFoundException: C:\geoserver-2.17.2-bin\webapps\geoserver\data\gwc\postgis_layer\metadata.properties”
I wonder if it could trigger the heap space issue.
-Jukka Rahkonen-
Lähettäjä: Vinay Kumar vinay1992geo@anonymised.com
Lähetetty: keskiviikko 29. toukokuuta 2024 3.09
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: [Geoserver-users] Java heap space java.lang.OutOfMemoryError: Java heap space
HI
Vinay K
