I'm using Windows XP, java (version 1.4 and 1.5), Geoserver 1.5.1 and I'm
looking for help about a blocking problem.
I create various Shapefiles/FeatureType/ Styles.
While adding the layers in Web Map Server Configuration:
1) When I Generate the SRS I obtain the error: could not determine CRS
identifier!
I solved correcting manually the SRS (EPSG:4326).
2) After the second/fourth layers' apply/save, after the save, happens this
error (see attachment 1.txt):
GeoServer - Exception
The following exception was thrown:
java.lang.ArrayIndexOutOfBoundsException: 0
3) After that the "Geoserver start" ends always in error (see attachment
2.txt) and I had to reinstall Geoserver.
4) After the installation Geoserver shows various messages (depending on how
many shapefiles I created):
test_shp:test org.vfny.geoserver.global.ConfigurationException:
FeatureTypeInfo test_shp:::test could not be used - DataStore test_shp is
not defined!
and I had to rewrite from scratch all shapefiles/feature/style/layers.
Does anyone know how to solve this problem ? Is it possible to recover the
previous shapefiles, etc. ?
http://www.nabble.com/file/p11946696/1.txt 1.txt
http://www.nabble.com/file/p11946696/2.txt 2.txt
Franco
View this message in context: http://www.nabble.com/java.lang.ArrayIndexOutOfBoundsException%3A-0-tf4200422.html#a11946696
franco_t ha scritto:
identifier!
I solved correcting manually the SRS (EPSG:4326). 2) After the second/fourth layers' apply/save, after the save, happens this
not defined!
Hmm... somehow the service.xml file got ruined, don't know why (will have a look and see if I manage to reproduce the issue). It should be enough to replace that one, leaving the rest untouched.
If you already replaced catalog.xml too, then you'll have to reconfigure
all of your shapefiles I fear...
Btw, which version of GeoServer are you using?
The GeoServer version is 1.5.1.
This time first of all I make a copy of services.xml.
Then I add a new layer and the apply/save went fine (apart the error: could
not determine CRS identifier!).
When I add a second layer (the fourth in total), after the save, I got the
error: java.lang.ArrayIndexOutOfBoundsException: 0.
Restoring services.xml saves the previous work.
At this point, I can save my work but (after many attempts) I'm not able to
go beyond the third layer.
Franco
identifier!
this
how
not defined!
the
Geoserver-users mailing list
View this message in context: http://www.nabble.com/java.lang.ArrayIndexOutOfBoundsException%3A-0-tf4200422.html#a11948724
Hmm... Franco, it seems you're configuring a basemap (group) layer, since the code where the thing breaks is storing the basemap layers exactly.
But I don't understand how do you manage to get there... can you
send me the layers you're configuring by private mail, as well as
what how you configured them (one by one)?
