[Geoserver-users] java.lang.NoClassDefFoundError
Dear subscribers and supporters
Sorry for bothering you all, but I am still facing the same problem, I
am desperate:
At http://syringa.ethz.ch:8080/geoserver/ using Geoserver 1.3.0 on Sun
Solaris 8 using Java2SE SDK 1.5.0_06 as well as 1.4.2_11 (changing
versions doesn't help) and having environment variables set as follows:
JAVA_HOME=/usr/java
export JAVA_HOME
GEOSERVER_HOME=/export/disk024/geoserver
export GEOSERVER_HOME
GEOSERVER_DATA_DIR=/export/disk024/geoserver/conf
export GEOSERVER_DATA_DIR
CLASSPATH=/export/disk024/geoserver/server/geoserver/WEB-INF/lib
export CLASSPATH
... I keep obtaining error messages alike in the attached textfile (log
from a short session calling the demo WMS page
http://syringa.ethz.ch:8080/geoserver/data/demo/popup_map/index.html).
Is there anyone who is able to help?
Many thanks, I appreciate your effort very much!
Regards, bd
nohup_out.txt (13.9 KB)
Hmmm... It seems like you are just missing some important files. Have you tried reinstalling GeoServer? Also you could try running the GeoServer war download in tomcat or something, then you shouldn't need to do any exports, at least not initially.
And is there a geoserver.jar in WEB-INF/lib ? You could also do a 'jar xf' on the geoserver.jar, and see if the AbstractService class file is there. If it is then something is just not picking it up right....
best regards,
Chris
am desperate:
JAVA_HOME=/usr/java
export JAVA_HOME
export CLASSPATH
Regards, bd
GEOSERVER DATA DIR is /export/disk024/geoserver/conf
14:36:01.807 EVENT Checking Resource aliases
14:36:04.790 EVENT Starting Jetty/4.2.21
14:36:04.860 EVENT Started ServletHttpContext[/]
14:36:04.874 EVENT Started SocketListener on 127.0.0.1:8081
14:36:04.875 EVENT Started org.mortbay.jetty.Server@anonymised.com
14:36:05.094 EVENT Starting Jetty/4.2.21
14:36:05.674 EVENT Started WebApplicationContext[/geoserver,GeoServer]
14:36:23.697 EVENT Started SocketListener on 0.0.0.0:8080
14:36:23.698 EVENT Started org.mortbay.jetty.Server@anonymised.com
14:39:56.916 EVENT Started HttpContext[/]
14:42:52.792 WARN!! Error for /geoserver/wms?LAYERS=tiger:giant_polygon,tiger:poly_landmarks,tiger:tiger_roads,tiger:poi&FORMAT=image/png&TRANSPARENT=TRUE&HEIGHT=406&REQUEST=GetMap&WIDTH=810&STYLES=,&SRS=EPSG:4326&VERSION=1.1.1&BBOX=-74.02924949245278,40.70060354838641,-73.9883552568504,40.72110115289822
java.lang.NoClassDefFoundError: org/vfny/geoserver/servlets/AbstractService$ServiceStrategy
  at java.lang.ClassLoader.defineClass0(Native Method)
  at java.lang.ClassLoader.defineClass(ClassLoader.java:539)
  at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:123)
  at java.net.URLClassLoader.defineClass(URLClassLoader.java:251)
  at java.net.URLClassLoader.access$100(URLClassLoader.java:55)
  at java.net.URLClassLoader$1.run(URLClassLoader.java:194)
  at java.security.AccessController.doPrivileged(Native Method)
  at java.net.URLClassLoader.findClass(URLClassLoader.java:187)
  at org.mortbay.http.ContextLoader.loadClass(ContextLoader.java:197)
  at org.mortbay.http.ContextLoader.loadClass(ContextLoader.java:170)
  at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302)
  at java.lang.Class.forName0(Native Method)
  at java.lang.Class.forName(Class.java:141)
  at org.vfny.geoserver.servlets.AbstractService.class$(AbstractService.java:131)
  at org.vfny.geoserver.servlets.AbstractService.<clinit>(AbstractService.java:131)
  at org.vfny.geoserver.wms.servlets.WmsDispatcher.doResponse(WmsDispatcher.java:131)
  at org.vfny.geoserver.wms.servlets.WmsDispatcher.doGet(WmsDispatcher.java:115)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
  at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:358)
  at org.mortbay.jetty.servlet.WebApplicationHandler$Chain.doFilter(WebApplicationHandler.java:342)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:122)
  at org.mortbay.jetty.servlet.WebApplicationHandler$Chain.doFilter(WebApplicationHandler.java:334)
  at org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:286)
  at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:567)
  at org.mortbay.http.HttpContext.handle(HttpContext.java:1807)
  at org.mortbay.jetty.servlet.WebApplicationContext.handle(WebApplicationContext.java:525)
  at org.mortbay.http.HttpContext.handle(HttpContext.java:1757)
  at org.mortbay.http.HttpServer.service(HttpServer.java:879)
  at org.mortbay.http.HttpConnection.service(HttpConnection.java:790)
  at org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:961)
  at org.mortbay.http.HttpConnection.handle(HttpConnection.java:807)
  at org.mortbay.http.SocketListener.handleConnection(SocketListener.java:197)
  at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:276)
  at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:511)
14:44:24.978 WARN!! Error for /geoserver/wfs/GetFeature
java.lang.NoClassDefFoundError: org.vfny.geoserver.servlets.AbstractService
  at java.lang.Class.getDeclaredConstructors0(Native Method)
  at java.lang.Class.privateGetDeclaredConstructors(Class.java:1618)
  at java.lang.Class.getConstructor0(Class.java:1930)
  at java.lang.Class.newInstance0(Class.java:278)
  at java.lang.Class.newInstance(Class.java:261)
  at org.mortbay.jetty.servlet.Holder.newInstance(Holder.java:176)
  at org.mortbay.jetty.servlet.ServletHolder.getServlet(ServletHolder.java:293)
  at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:333)
14:44:24.989 WARN!! Error for /geoserver/wfs/GetFeature
14:45:06.479 EVENT Shutdown hook executing
14:45:06.481 EVENT Stopping Acceptor ServerSocket[addr=localhost/127.0.0.1,port=0,localport=8081]
14:45:06.492 EVENT Stopped SocketListener on 127.0.0.1:8081
14:45:06.496 EVENT Stopped ServletHttpContext[/]
14:45:06.497 EVENT Stopped org.mortbay.jetty.Server@anonymised.com
14:45:06.500 EVENT Stopping Acceptor ServerSocket[addr=0.0.0.0/0.0.0.0,port=0,localport=8080]
14:45:06.503 EVENT Stopped SocketListener on 0.0.0.0:8080
java.lang.IllegalAccessException: Class org.vfny.geoserver.servlets.FreefsLog can not access a member of class org.geotools.data.arcsde.ConnectionPoolFactory with modifiers "public static synchronized"
  at sun.reflect.Reflection.ensureMemberAccess(Reflection.java:57)
  at java.lang.reflect.Method.invoke(Method.java:317)
  at org.vfny.geoserver.servlets.FreefsLog.destroy(FreefsLog.java:109)
  at org.mortbay.jetty.servlet.ServletHolder.stop(ServletHolder.java:244)
  at org.mortbay.jetty.servlet.ServletHandler.stop(ServletHandler.java:470)
  at org.mortbay.jetty.servlet.WebApplicationHandler.stop(WebApplicationHandler.java:163)
  at org.mortbay.http.HttpContext.stop(HttpContext.java:1978)
  at org.mortbay.jetty.servlet.ServletHttpContext.stop(ServletHttpContext.java:145)
  at org.mortbay.jetty.servlet.WebApplicationContext.stop(WebApplicationContext.java:504)
  at org.mortbay.http.HttpContext.stop(HttpContext.java:1949)
  at org.mortbay.http.HttpServer.stop(HttpServer.java:732)
  at org.mortbay.http.HttpServer.stop(HttpServer.java:700)
  at org.mortbay.jetty.Server$1.run(Server.java:455)
14:45:06.555 EVENT Stopped WebApplicationContext[/geoserver,GeoServer]
14:45:06.556 EVENT Stopped HttpContext[/]
14:45:06.557 EVENT Stopped org.mortbay.jetty.Server@anonymised.com
Chris Holmes
The Open Planning Project
thoughts at: http://cholmes.wordpress.com
